Help Us Help You
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be succinct but clear in your wording
People need to know some details about your problem in order to understand what sort of answers would satisfy you, but nobody cares about how angry your boss or how bad your teacher or how tight your deadline is. Talk about the problem and only the problem. If you don’t speak English well, you should probably post in your native language as well as providing a Google or DeepL translation of your question.
3. Attach minimal versions of all the relevant files
If you have a gh file you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from a gh file. You can use the Internalise Data menu option to cut everything to the left of a parameter:
If you are referencing curves or breps or meshes from Rhino, you can also internalise them so you won’t have to post a 3dm file as well as a gh file. If you’re unsure whether all the relevant data is internal to the gh file, try opening it in an empty Rhino. Does it work? Good. No? You’ll need to internalise more.
4. Include a detailed image of the file if it makes sense
If your question is about a specific (group of) components, consider adding a screenshot of the file in the text of the post. You can use the Ctrl+Shift+Q feature in Grasshopper to quickly create nice screenshots with focus rectangles and embedded viewports such as this:
5. Include links to online resources if possible
If you have a question about Schwarz Minimal surfaces, please link to a website which talks about these.
6. Create new topics rather than continuing old ones
It’s usually better to start a fresh question, even if there’s already a discussion that kinda sorta tangentially touches upon the same issue. Please link to that discussion, but start anew.
7. This is not a do-my-work-for-me group
Many of us like to help, but it’s good to see effort on our part being matched by effort on your part. Questions in the form of “I need to do X but cannot be bothered to try and learn the software” will (and should) go unanswered.
Similarly, questions in the form of “How do I quickly recreate this facade that took a team of skilled professionals four months to figure out?” have a very low success rate.
Help with modeling this
Split data
How to change start and end of the curve(open)
Assign geometry (cross) to series of points
Moderators
How can I make this pattern?
Grasshopper
Possible Stupid question 😂 Curvature Graph
Sweep 1 - Multiple section curves in both ends of multiple rail curves
Geodesic lines on a Mesh
I need help for a job at the university
How to use gradient on flat surface?
Move to a point
Drawing patterns
Flipping line order
Extrude 2 d image automatically
Curve side works not correct
Item Index
Unfolding sheet metal
How can I convert one polysurface to a surface?
Modify an upload stl file
Need help in grasshopper
Herzog & de meuron building
From the true&false list, I would like to check if there is the true element"
How to cut off the plane
Streets growing into a Tower
Anyone can answer my question please
Create parts
Mesh to Brep?
Roofing structure
What code to do a Dir and make all Dir one direction?
Extrude polylines with point cloud
Shooting lines at a geometry and finding the points
Remove duplicate geometries
TypeError: 'NurbsCurve' object is not iterable in python in grasshopper
Voronoi (3D) Ring
Creating Triangle surfaces from 2 curves
Resizing and fitting a group of rectangles so that they do not leave any space in between each other
Merging curves in all the unit grid region
Unrealistic Energy simulation values
How to construct an untrimmed surface for my poly surface
Circular panels on surface
Surface between lofts
Multiple sweep 2
Creating a grasshopper pattern
How can I fix the distortion of the junction points in this lattice structure?
Slicer to convert linear interpolation to Arch and G02
Reorder list
Rotate a grid inside a surface/mesh
How to extract all solutions with best fitness value?
Using hops for populate geometry
Can't get Region Union or Solid Union to work on these curves
What does the "U V W" in surface morph mean? And how can I set them?
Soft morphable solid?
Vb script unroll
Need to create a surface to close this polysrf
Creating multiple surfaces
Mesh Definition from grasshopper intralaticce
Parametrice this
Grasshopper
Looking for low latency reading and writing of large data sets from Excel
Sorting/selecting points according to line collisions
Select Points on Geodesic Dome
Help - Curves to one open curve for Gcode
Offset curve issue
Why does an Z array of curves not have the same start/stop point order
Trouble with triangular surfaces and lunch box
Wanted to make a cloth/fabric surface on top of a brep
Nesting section from a circular shape with opennest
Set min and max radius for perforated circle pattern from image sampler
Help, very Beginner
Does Rhino 6 have asymmetrical "filletedge"? and does Rhino 6 have better export to Solidworks?
Insufficient faces in the x-direction
Mountain Dwellings in Grasshopper
Divide surface by distance
How to select only the end points?
Facade louvre design (contours)
FIND & PLACE Point on middle of surface that is rotated in space?
Copy Brep to points and rotate them toward a central point
Create diagonal list of points
How i can make this
Best way to test if two curves are tangent?
Making a Chart in grasshopper
Cookie pot
Successive Increase in distance between Objects
Reorganizing tree branches by z factor domain
Filter Out the False 4th line in a row of a list
Trying create multiple faces of my design so that way it makes a tower
Loft curves
Arc direction at 90 to rotating line
How to get points(type of point3d) by curve.contains method
Index error while writing rules in wasp help urgent
Work with open nesting
CSV file from Iterations' Result
Trouble with Delaunay Mesh [Grasshopper]
Generating Wooden floorboards + balustrades that intersect with a pattern
Split Brep while Rotating
How to change the list of an area?
Rhino Grasshopper Run Error
How to create a 3d surface using curves
Parametric Facade Panelization
Reassigning an order to a linear array
Help me trim that surface
HELP - New forms
How to make rocking chair?
Please tell me how to fix it :(
Fabric like pattern on facade!
Create surface between polylines or points
Quad Remesh Problems
Create a list of points with same z coordinates
Populate list of length Y with X number of items?
Boolean Union Set doesn't work
Create curve from space enclosed by surface?
Triangular grid with equilateral triangles without the excess trims at the boundaries
If condition is met then perform solid difference
Help please ABOUT GRASSHOPER! SOLVED
Rhombus - curves
Line attract point problem
Surface controlled with control points - help
Finding intersection points
Biomorpher Plugin
Mesh from Lines
List management
Grasshopper triangular wall
How to sort list of surfaces by number of vertices?
Pufferfish- tween through surfaces component
Surface Extrusion
Mascara Brush
Need some Help!
How can I randomly divide a list of surfaces in 3 separate lists?
How can i create this geometry?
Marc Fornes, Maxima.. How do I start?
HEY, Could this design that consists of this concept be made in grasshoper?
How to take out the overlap parts of curves
How to change all axis of lines to be the same?
Mesh from closed polyline when it fails to make a mesh?
Rotate 3D multiple plane, and there are some randomly rotate upside down
Project curves or surfaces to XY plane for Laser Cut?
Help Making Cylinder
Differences between a extrusion object, solid and closed polysurface?
Select objects
Arraying members across a paraboloid
Deconstruct Brep Adds more Surface
Extrusion Value Matching List of Layers
Python linking grasshopper with Etabs api
Replace number with given numbers
Need help for pattern
Attractor curve that affects the space between objects
Triangulate loft
Big VB component (involuntarily) runs in a loop
Removal of Points with Identical X Coordinates
Grasshopper
Black texture, not the first, or even tenth time having this issue
Distributing spheres gradiently towards a single attractor point
Orient circles on normal
Rays/ Lines when exporting image views
Hexagonal Grid on 3D Curved Surface
GH help? voronoi
Create solids from curves
RhinoInside Revit Facade: Flex Curtain Panel
Not lofting properly in triangle B
Remove points out a brep or keeping only on brep
Basic python code - how to wrap value in "for i in" loop with conditional?
Problem with my open Circle Packing Script
Different Cull Pattern For Each Branch Of A Tree
How to use Deconstruct Face
Pattern Generation in Grasshopper
Distribute / Orient on surface
Having troubles on Sweep
Is there a way to analyse a [dens] mesh for 3D printing compatibility?
Grasshopper modeling
Why is there a problem with the distribution of the points of the front line and the last line of my line?
Create multiple rectangles from a list of points (center points)
Hatch areas
Transfer data from one list to another when name is the same
How to Connect Points from 3 Data Sets
Bulge Brep
Create surface by loft of curves having problems with wild curves in some parts
Move object on the surface
Dimension font size, or why I hate dimensions
Repeat Same Surface Without Copying
Group points in the list based on x coordinate value range
Surface order
Proximity HELP please
Prevent pipe breaks?
Orient curve
Rotation of Lines with limited Range of Radius
Asking for help, question of array
Density map of Points in Grasshopper
Creating surface from hexagonal grid
How can I tag and label beams in triangle grid?
Shuffling length values ,grasshopper
Geometry multiplication along surface
Control the angles of voronoi on grasshopper
Proximity 3D analysis between two surfaces (mesh)
Check whether the polygon(curve) is within the boundary
Random lists of numbers from a data pool
Daylight optimization using Hobeybee and Galapagos
Selection Settings - problems with selecting objects in front of other objects
Help! GH for historical Architecture
Sort object according to another object
Exporting excel date to grasshopper
Unrollsrf not keeping properties for points
How to use Elk to extract building heights
Parametric spiral staircase
How should I go about trimming several triangles out of this trangulated surface?
Iterate through list
Definition for Facade Panelization
How to deform a solid that is part of a grid that has been adjusted using attractor points
Expression problem
Tryng yo use ball pivot, cloud to mesh
How to create such reliefs, patterns?
Sunlight hours analysis provides an error
Galapagos, Skipping some cases
How to Morph an object from Flat Mesh to a 3D Mesh Using UV Coordinates
Create a delaunay mesh from evaluate surface
Variable Piping Multiple Curves with Curve Attractor
Shatter component / Crv-Crv intersection: does not always work
Subdivide Surface by Repeating Module
Closest points with same distance issue
Flow command
How can I group points by their Z value and draw a nurbs curve between them?
Scale problem
Rhino 6 Wall Volumen
Warping Ribs - lines when I curve array
Attrcator Point
Attrcator Point
Vray failed to initialize
Incremental array of cirlces in a box
Visibility analysis
Solid Difference not working
Creating dynamic circle pattern
Post-command control over object selection: new, old, both, all, none etc
Harsh Shadows all of a sudden
Remaining issues/requests with Rhino (architecture students at University of Melbourne)
Shatter curves at intersection points
How to create parametric patterns in grasshopper
Grasshopper Shoebox model
File Type not Supported for Rhino, Quelea
Random points connection on a structure
Tiling grasshopper
Tiling grasshopper
How do I re-create a similar structure like this, porous architecture
Straight corners appear rounded in print display mode
Issue Timer Component
Bending and twisting of a paperstrip with adjustable length and width
How to create a grid
Figuring out what kind of surface I have?
1:1 print/pdf of Rhino drawings
Square pattern with variable arc and color
Multiplication component bug
Non-uniform Offset
Manipulating adding a list to another list
Rectangular box cube fit
Elefront:Define multiple blocks from a list of breps/geometries
Any interpretation for the Lisbon Oriente Station?
Tween Fail
Ring! Help!
Pruning branches by content
Moving the points to the edge curve
Use A-Star Algorithm (Shortest Path) in a 3D environment (networkx module)
Grasshopper and *conic* corners for a rectangle
Getting bounding curves from a cell?
Trying to sort a list based on a position and remove repeated elements
Trim a line
Silk Pavilion
Wallpaper Rendering As Black Screen in Rhino For Mac Version 6 -- Not an Issue in Windows
Find corner surfaces in a divided surface
Intent failure of flow parameter
3d textures on lofted surface
How can i add dashed lines to shape
Delete informations from a panel
List item selection
Parametric Grid Structure Around a Organic Form
Square spiral on a contour
Pursuit curvature pillars
Joining Brep-Tiles via Connectivity
Unable to convert Surface to Brep Geometry?
Advice for a new student
How to automatically create an infill / negative volume surface
Grasshopper truss beam
Finding corners of reference text on Rhino
Wrap curved spline into circle
Grasshopper- How to 3D panel on surfaces going in a certain direction
Retrieve single item from different branches
How to make surfaces out of curves
Cull out points from grid based on pattern rows/columns
How to create this paneling using Grasshopper
How to create gaps in twisted fins in grasshopper
Mapping textures on curved surface (road and pavement)
How grasshopper makes such a wave of wave shape
How does the grasshopper array replicate different objects and place a shape
Avoid overlap between surfaces
Dispatch Arcs into Clockwise and Counter Clockwise Arcs
IntraLattice Planter pot question
Stretch geometry from center line
Extrude curve for tubular shape issue
Creating ribbed features in Rhino?
Crear tuvo con corte y rellenar de voronoi
Noob question #004? immutable objects
Gradient, from square to pentagon
Line transform
Named Selections WIP SubD
Creating joints between pipes for 3d printing
Area from intersection of Mesh and plane
How can I do?
Rename text with grasshopper
Orange peel
Displace surface with an object
Trimming excess on loft
How could I make a maze cube on Grasshopper?
Tapered extrusions non planar curves
Can't Find Grasshopper Component
Generate curves around a circle
Rhino window deactivating
How to Create the first Scherk Surface
Sweep not working based on input curves
Arrange brick along Circle
Ask for divide the curve by list of numbers
Array Rectangle Within a Boundary
Circular Lettering Definition
Lofting multiple curves from array of curves HELP!
1. Data conversion failed from Point to Brep
Solid mesh from brep creation problem
Spiral staircase
I need help with text effects
Cell portrait, pattern
How can i twist brick towers into each other?
Gradual Modification of Multiple Curves Based on Target Curve
Deleting inner walls in building
Selection of building footprints, and region union not working
Geometry optimization stopped
Lattice structure for shoe sole body
Camera clipping bugs when I try to render
Creating Specific List
Selecting surfaces on similar or identical centroids
Random Range Method
Lists matching
Grasshopper how to copy
Dispatch first and last index
Need help on making a dictionary with point coordinates
Voronoi polygon boundary
Sphere Lighting Proposal
Mismatched knots Repair failed
Smart Roof-challenge_Parametric surface out of modelled element_Unsolved
Polygonal structure
Interpolate curve through points in data tree
Offset option
Offset curve on grasshopper
Create a Single Surface out of Multiple Surfaces
Hammer tenons Help
Conic SPM structure: evaluate surface
Extracting cut curves after a boolean diff
Change the orientation of each frame using a vector list
Or, And Gate
Need help please for this im a student in need
Issue while nesting multiple crv
Chess board matrix annotations eg. B3, E6
How to assign colours to a different lists in a tree?
Offset Array with defined rotation transforms
Design honeycomb structure
Creating Surfaces Between Lines
Kengo Kuma Timber construction
Need stairs definition for rhino 6
Measure angles in a 3d model
Length of Line SDL not matching input data from csv
Indexing by geometry
Help: rhino modelling to maxsurf, problem with surfaces (willing to pay a little)
Grasshopper surface from planar curves
Sweep beam
Dividing Surface distortion!
Asking efficient questions Grasshopper?
Round to nearest but always to smaller value
It does not work
How make hole? (Porosity)
View capture to file: black image
Metal pavilion design
Merging polylines
Merging polylines
[NOVICE] Uneven Isotrim
Reference boxes are not orienting properly
Failure in a section follows shapes
Draw line through the Voronoi elements
Generate Local Rx Ry Rz Values To Transform a Plane into a Target Plane
Create outside surface from lattice structure
Data Visualization from CSV file
How to convert brep from loft to surface and divide into panels and provide mechanism component
Edit a mesh
Indexing a point list in python component
Mesh split losing part of mesh?
Grasshopper close brep naked edges from extrusion
How to extract the coplanar extraction of 2 groups of irregular cubes
Basic - Connecting Points Along a Circle to Form a Polygom
How do I achieve this AI generated image through grasshopper rhino
Evaluate component: renames input variables when reloading script
How to model is two cupboard legs can anyone help?
Find matching branches in Tree
Automatically bake to a layer and coerce
A point in the grid is null
Change text to a number
Hexagon.turn
Color coding by Gradient a group of surfaces by height of their apex
Adjusting bridge deck stiffeners within tolerance of a set distance (from a point)
Geometry Not Showing for Printed Text Holder
If multiple curves are in the Brep return 1 else return 0
Optimization of diagonals in truss structures
Outline / Boundary around 2d linework
Parametric steel joint in Grasshopper
Rhino crashes when I use 'Custom' Direction with the SectionTool
Simple things are hard for me to do
How to group same points from different branches within the same tree and not loose the path information?
Problems with attractor point catchment area - overlapping catchment areas
How to join edges visual gaps of surfaces
Problem with scaling of BREP: keeping the upper part
Mover o dividir curva en dos longitudes o 2 distancias diferentes en forma de serie
Scaling in file changes ability to extrude curves and cap extrusions
Move two points by their respective directional vectors to a fixed offset distance from a line?
Isotrim Loft Surface using Geodesic Curves
Lofting a deck on a bridge
Color gradient based on z coords of geometry
Window color scheme
Improve the previous Design Honeycomb structure
Projecting and cutting holes using Grasshopper
Weird Lofting,
C# Grasshopper how to handle with combobox
Move multiple groups to closest point
Sorting List of Pts & Conecting with line
Mesh/Surface/Curves from 3dGrid
Space frame for my masterthesis project- urgent
Make a Box Out of Bricks in GH
Create Voronoi pattern on custom surface
Organic tree parametric skyscrapper - guidence needed
Get intersection indices
University Help
Strange results from geometry move - different preview and bake locations
How to grow/expand curves (polygons) until touch each other
Variable Mesh Edges Thickness (Horizontal, Vertical, Diagonals)
Nesting laser cut lay out
Distribution of points along a line
Preparing for 3d print
How do I shift a dash pattern on an open curve?
Unable to copy it properly in grasshopper
Control Spacing of circles in Hex Grid
Sequential / unique serial numbers
Elliptical wing trouble for RC glider
Creating one clean surface from multiple overlapping surfaces!
Arbitrary curve to an arbitrary plane
Project curves onto breps loses tree structure
Fix pattern inside curve for multiple units
Mesh Inverse
GH Python - Intersect List of Curves and get a List of Point3D
Placing an obstacle inside bunch of curves
Make pins with holes
Bending surface [Novice]
Generate solid from points
Replace line with curve
Very basic question
Attractors exercise in Grasshopper Primer
Workflow for working for mesh
Rhino 8 GH1 Playground/Sandbox/Discussion Thread
Paneling a free-form surface with Same squares
Rhino 6 to illustrator CC18 export or print. Either options causes Illustrator to crash
How to spread curves for laser cutting
How to recreate the facade on ZAHA’s Innovation Tower?
Ladybug, Radiation Analysis to design Louver
Accessing Specific Information From a List (Multiple Times)
Intersection points over surface from which perpendicular lines start
Colour Gradient - Above and below 1?
Colorizing pointclouds
Black, yellow, and red dot appearing in render window!
Grasshopper is slow
Raising a shape with each corner at a different height
Stuck on Grasshopper Script Solution
Paneling Tools problem with panel results
Connecting inter cell vertices of offset polygons
Filter surface direction
Multiply sections from one script
Orient multiple solids to a CPlane
Please help me regarding the OpenStudio error, I have a deadline
Runtime error (IndexOutOfRangeException): index out of range: 0 Traceback: line 3, in script
Honeybee failed to download the files needed to run EnergyPlus with Openstudio error
Locally transform multiple meshes
How to alter /control different in height of the curve
Pull points to closest curve
Unwanted Points after Move component
Center Line of solid
Sort duplicate values
Create surfaces from lines
Delete duplicated points
Pattern attraction/repulsion along curve
Resizing and moving vertical surfaces in one direction
Item lists
Make curves equal of Pyramid cone
Close the top and bottom of hollow object
Bool stack of boxes with one object
Private void RunScript error
Created script to do 2D Mosaic
Automating grasshopper / rhino from command line with arguments?
Panels on a double curve surface
Creating reference points on a topography
Intersection for two curves
Horizontal frames divisons
How to grasshopper this effect?
Join independent polygons simultaneously
Loft with radius
How can I connect each of those edge point with a singular line?
Created MOSAIC
Filter Circle with Diameter/Radius smaller than
Edge Surface component generates surfaces with random UV orientation
How to manually choose which points to form a polyline?
Voronoi curve trim with surface
What is the best way to close hole in mesh?
Brick wall pattern
Position purlin on curve
Grouped Text with a closed curve from Rhino in Grasshopper
Extrude the series of profiles to form a one solid model
Classification of points based on the result of ClosestPoints command
Closing a set of contour lines and filling with contour gradient
Connecting Galapogos and Graph mapper
Dividing branches based on pattern or same values in branch
Unable to join planar curves
Grasshopper/python - reference objects dynamically/load all objects
Offsetting points along individual plans
Necklace and jewelry grasshopper
Which components can model such a texture?
Rhino export to cad, hatch has no area info
Different point numbers
Help to make a pattern in cylinder with grasshopper
Remove points in dense areas to create 3D volume surrounding from points
Filter index from a list between two values
I broke the NumberSlider
Constructing Attractors for Rotation
Scaling Multiple Circles from Centerpoint
Invalid mesh
Loft or sweep for multiple cross sections on one path
How to scale in different ways
How to attach random geometries to the panel grid?
Cable catenary prediction
Does anyone have any scripts that are similar to this? Struggling to wrap my head around it
Replacing points depending on size of original list HELP WITH INDEX
How to populate text from Grasshoper to Rhino?
Repeated rotations
Copying Object Using Python-Grasshopper
A problem with OpenNest
Multiple Curve Lofts
Intralattice
Evolute Tools Expert: Is there an evolute tools expert to refer from?
Finding the difference between two sets of referenced geometries
Loft in Grasshopper works different to the loft in Rhino?
How to read the numeric data out of the image sampler
How to fix this stairs script for curves
Voronoi with attractor points gh surface
Ruled Surface between two curves
Voronoi wont project onto a surface; Help
Experimenting with grid matrix pattern based on photo
Rewrap surfaces together
Help with fillet on planar geometry
Customizing the transform/morph/surface box
Python Simple problem boolean difference loop
Merge overlapped (colinear) curves to single one
Rafters roof using grasshopper
Hexagon Grasshopper
Polyline and rectangular areas from given points - GSA Grid Area Loads and Polylines
HELP! Surface from Grid Trouble! - null point in grid
How to Optimize Floor Space
How to create a random volum?
Https://discourse.mcneel.com/t/rhino-6sr10-the-block-command-does-not-apply-to-vray-light-vray3-6-3/73622
ASAP Modeling help with a 3D packaging
Latitude / Longitude Drone flight recording to Node / flight path & more
Deformate a starting mesh with kangaroo preserving angles of mesh faces
Hull boat design doubt
How to select the last items from the lists on a tree with three branches
How to this hanging cables ceiling in grasshopper?
Hundreds of Null but when I export them nothing wrong
Help with "bookworm" by Nuru Karim
Voronoi and then offset error
Please Help... newbie to GRASSHOPPER!
Move geometry from one point
Grasshopper Dispatch
Creating spiral flowers that can open up
Retrieve datatree
Help In creation of a specific geometry
Opacity Gradient from Attractor Point
Copy element in center of hexagon
Recommendation for organizing pieces for laser cutting
How to create a rotating mesh with grasshopper for population?
Having trouble with the Item Index component and its driving me nuts
Vertical array
Scale of rhino
Basic tutorial for 3D mesh structures
Exception has been thrown by the target of an invocation
Sorting data by different keys
Custom Shape on Perp Frames in order to loft
Extruding height from excel data on grasshopper
About Moving points
Attractor curve
Find points on intersection surface
Grouping points into paths based on curve inclusion
Masharabiya definition for surface tessellation
Making surfaces from two curve
Replace self intersecting curve
I want the class to follow the topic when selecting it, does anyone have a script to help me?
Move point
Help sos! from grasshopper to rhino
Trim 3D Curve Form with Plane
Facade driven by data in grasshopper, please help
The file what I recieved from the consultant company .it looks like this.why?
Transform and remove original geometry
Ellipsoid Workspace Path - How to Create?
Help with grasshopper/rhino
How to get support on the ShapeDiver forum
Can you help me (image sampler)
I would like to print Nylon and FPE by G-Code .. someone can help me with the setting of the G-CODE?
Create such a this pattern in grasshopper
Brep - Brep list intersection
Pattern Generation/ Perforation
Proportion geometry
Can anyone help me with this texture
Grasshopper blocks
Modelling a geometric/ crystal display
Treat Many Surfaces as One
Calculating surface area of shadow casted from an object to another one
How to thicken the surface(Edge surface) in Grasshopper
How to solve the problem with the exoskeleton and curves
How to create horizontal lines?
Image sampler
Dividing irregular area
Change zeros to ones in a list
Delete duplicate data from a list
Wind form wrapping around Breps
Add items to branches of a tree
Splitting shoe in grasshopper
1. Curves should only be trimmed with a closed Brep
Python List Output into Grafted Trees
Attraction parametric
Rotate multiple elements randomly around own centre
Sequencing of curves
Stream with conditional value list
Do you know this super cool pattern!?
Orienting object Along a 3D Helical Ramp
How to use the "Facet" battery to make a geometric surface on a curved surface?
Nurbs polysurface looks like polygons
Basic Data Structure Question
How to move brep
How can I colour a mesh from a list of colours RGB?
Surface splitting
Gradient Diagrid with Lunchbox
How to make this structures? And more like this
How can i use solid difference in the following case?
UVeditor - too small surfaces
How to create boundary from joined boxes
Grasshopper Vornoi 3D
Wave-like surface definition
Grasshopper loft error, curve orientation
Nobody likes kinks in hoses, but I do
Lace pattern grasshopper
Type Of Connection needed for this project?
Automatically select all mesh faces facing up
Read File (File) component not working
LINQ is not working properly
Convert grasshopper script into python
Gridstructur with certain line lenght
Cocoon Mesh Error
Adding text into gcode
How to make 'Planarsrf' in grasshopper
How can I sort this unorganised geometry in grasshopper
Untrimmed control points on new surface
Structure to create different stories in Grasshopper
Recreating Model
Random mass rotate in place
Filter plots According to shape and Area
Multiple attractors of different strengths
Collision detection - Boreholes
Extracting points and using them in Grasshopper
Area moment of inertia
Connect meshes
Sun responsive facade
New to Karamba
Need some help with using grasshopper [beginner]
How i can generate form like this please
Tangent lines from a pipe
Modifying Volumes in X/Y/Z Directions
Need help with python component
Scale a geometry in rhino using grasshopper
Cast shadows in Grasshopper
Projecting lines on a curve Perpendicular
Terrain model script, architecture
Looping Energyplus simulation
HELP! Offset going to different direction!
Invert selection of points after random reduce
Thesis help
Rhino Grasshopper Python Error
Command to draw a curve on Brep?
Schwarz minimal surface
Data conversion failed from point to curve
Help, Wall configurator
Help on Cellular growth simulation
Data tweaking to link specific points between a set of polygons
Unrolling Using Grasshopper
How can I make this in Rhino 8 Grasshopper
Asking Help: How to pop out data using index in branches?
Grasshopper - Arrayed Curves on surface at specified distance parallel to existing line
Complicated Nonplanar 3D Infill Pattern Creation Help
Split and sum specific index values
Data management - Lines within Circle
Grasshopper software ( Rhino 7 ) is freezing and crashes
Is it possible to do it in grasshopper?
V8, GH1 - area calculation bug (again)
How could I reoder my point list?
Trouble with VPipe
Creating Loft, grasshopper
Custom Preview Grasshopper
Grasshopper two lines overlapping don’t understand why
Get boundry curves of these curves
Sort array of rectangles to cluster colours together
Split mesh with curve
Automating prefab wood framing
GH Offsetting Brep Surfaces
Add connection curve between horizontal curve
Separate triggering points for the different columns
Create bayonet joint on round tube
Grasshopper hole cutting problem
Loft doesn't work - single surface merge
Angle precision in Grasshopper/Rhino
Fence/Wire Mesh Design in Grasshopper
Geometry overlay
Rotate vector gives wrong result
Grasshopper memory problem
Voronoi: solution exception, points must at least contain 1 point
Loft Issue
Why are some of these list items juxtaposed?
How to make sure perp frame Z axis is upwards?
Duplicate a geometry with different sizes with grasshopper
Random distribution within 3D shapes
Curve alignment
ReOrganisizing curves index by another sorted list (their middle points)
Creating mesh for further FEA analysis
FactorZ Grasshopper Not Working?
Inherited Values Changing to Locally Defined Values
Help with this glass frame
Complex Curve Blend
Problem with joining points on a surface
HELP! panels don't follow the building floor
Creating Linear Growth
Trying to make a oloid, giving me this problem
Smooth Wall deform around podium help
Fillet around extruded surface in Grasshopper
Get mesh faces' indices after getting mesh strips
Grasshopper, Data conversion failed from Brep to Surface
Points Connection using Anemone?
Selecting the desired points
Intercepting resultant movement vectors
Red error ?!
Remap the distance between tangent points
Problem with creating a printpath
N Lines with N offset Values with Single Output
How to create a surface from overlapping curves?
Draw line through a grid
Sort points to make a wave curve
Larger than, smaller than, equality function not working properly
Variable offset / thickness
Morphosis Sejong M-Bridge Façade Script
Volume of voronoi structure with overlapping meshes
Dividing a surface by spacing between points rather than U and V count
Randomize the spheres and now doesn't inflate
OpenNest packing curves on top of one another
Connecting values from a list with lines or curves
Properties of voxels in Crystallon
Tween Surface 3 to one surface
Trying to do a hull, with fabrication in mind
How to create 3D single or multiple building template in rhino/grasshopper?
1. Data conversion failed from Brep to Rectangle
Excluding points intersecting solid
Drawing lines perpendicularly from curve to curve
Split a tree into more than two lists
Gradient colouring from excel data
Create a windows randomized system but with fixed grid inside
Invert Cull Pattern
Planar spline converts to a vector in Z direction?
Split solid problems
Rhino Grasshopper Sweep1 Still Sucks?
How to create an elevated root system?
Twist in curve / parabola
Offset or move curves with different distance
Sweep2 with grafted Lists
Multi surfaces project curve
How do I remap curve length to isocurve density?
How can I divide surface with contour?
Use the inside space
Bathroom tiles
My first grasshopper project
Exoskeleton on One Thousand Museum
Grasshopper
Rotate Multiple Geometries Randomly in their X,Y Z planes about centroid
Creation of closed vectors with an offset and a layer from the Excel list
Python Grasshopper
Pull point on a surface
Unreliable SolidUnion
Grouping curves that have different z coordinations into branches
Create Surface from Points in Rhino Python, Message: expected IEnumerable[Point3d], got list
Need help with "Point in Brep"
Problem with voronoi pattern on Pipe
Trying to make a perforation script for a surface but having trouble
Help me understand why this component transforms the tree this way
Loft Simplification *SOLVED*
Need help achieving contour like structure
3D Grid development with attractor curve
How can we make this kind of pinged effect
My open nest scripting doesnt work anymore
Pipe and curve problem
About rotation xyz axis
Split list into equal partitions, with random items in each partition
Brick Raking Stretcher Bond
How to render Custom Preview before python script
Grasshopper isn't formulating points into the Brep
Python code sometimes work and sometimes doesn't, same input
I have a university project and want to know what is the gh plugin is this?
Voronoi on non rectangular surface
How to keep data structure in OpenNest
Curve To Mesh Grasshopper
Expression x-1 or -x or 1-x
Grasshopper Python: Can't Move objects on one different Layer
Triangular Blanket Extrusion
Pick curves
Map rectangle on multiple plane
Rotating multiple elements at once (not as groups)?
Kangaroo goal to open a mesh
How to force a meshbrep node to make loops where i want them?
Parametric modeling
Divide Closed Curve into Cells with Python or Efficient Method
Solid difference
Filter content
Why does my Make2D not work?
Triangular pattern texture
Choosing the outline of the divisions
Regenerating points conditionally
Scale a closed Curve and the Lengths between control Points
Curve to Volume Error
Offset x-1 Simple question
David chipperfield facade
Bug squish
Polygons from curves problem
Pattern help
Land plots area based on data from Excel
Opening 3dm file in Revit 2022
How to sort surfaces by z coordinates in ghpython
Need help with an algorithm
Variable spacing of copies along curve or surface
Projecting list item numbers on corresponding object
The curve louvre is not connected to the curve
Maintaining Accuracy With Angled Sections Along a 3D Curve
Draw line between sidelong points
Issue with lofting two closed curves
Problem with selecting every other curve/list sorting
Bi-objective vertex-edge weighted steiner tree problem
Check if Breps are "Box-like"
Drawing with Python
Grasshopper shape contour, magnetic field, 2D Drawing
I don't understand why it works
Geometry definition
Can't cull pattern by true/ false
C axis in gcode
Grasshopper branche
Filter a Data Tree (that is actually a table)
Re-parametrizing given pointsets
Liste management
How to fit a plane according to multiple points?
Urgent Help Needed with Wallacei / Galapagos in Grasshopper Script
Brick layout to excel
Parametric wall design tutorial
Lofting probleme
(Annoying) Display Problem with Custom Preview [MAC]
Error in aligning rectangle
Set Area Parameter
Distribute objects on a curve automatically, with a Min and Max distance
Need insights understanding component output
Link between GH and Rhino file lost
Proxy Mesh
Check multiple items for presents across multiple lists
Extrude or Sweep Closed Curve Along Closed Curve
Dichotomy "while" loop fails - Rhinoscript in Grasshopper Help
Using Boolean Union to create a solid out of 7 solids
Mesh problem
Cross between shell and extrude with taper
Creating a mesh or surface between polylines/arcs and a polygon
How can I remove a specific part of a brep?
How to synchronize CAD ? C# or python in GH
Brick wall with extrusion of some bricks
Rotating parts in grasshopper with the plugin wasp
Find length of all chopped pipes, and create a quantity count range
Can't cap this
C# component error when running in wallacei
Lines between intersections, wo/ same x or y values?
Creating the shigeru ban pomiduo center using grasshopper
Scale Length according to distance to plane
Wandering Cube - Grasshopper Script
How to connect adjacent edges of two angled panels, which are composed bumpy geometric pattern
Copying or Dupplicating Grasshopper objects
Grid shell offsett surface
Surface area
Stadium seating
Image Sampler - Script Scale Adjustment / Rotation of Lines
If loop kind in grasshopper
How to get intersection of two mesh
Loft with Multiple Curves Input Error into Surface
How to: Ripple effect texture with dissolving edges & selected side
Making items when you have the design
Series of Element
Small architecture surface
Won't machine a simple slot [RhinoCam]
Please delete this post
Calculate number of the point on the face
OnCurve + SortAlongCurve
Display item /data conversion failed text to surface-How can I replace items with making it to text?
Using of Scale NU - keeping the upper part instead of the bottom part
Wave louver facade with multiple attactor curves
Help to a grasshopper newbie to create a text output please
HELP with Freeform Roof Structure
Area Calculation Error
New in Grasshopper - help with the pattern
Lunchbox paneling on multiple surfaces
Visualization problem in ladybug
Surfaces have different uv values
SpinForce Issue
Align (or superimpose) two sets of points
I painstakingly hand modeled, I want to automatize in grasshopper
Create a 4 points surfaces from two consecutive points of two list points
Trying to create uniform spline between 2 polygons
Grasshopper
How can I make a planecut in grasshoper like this
How to make House of Panda from Bjarke Ingels Group in GH?
Dim+Text to blocks loses Annotation Style
Need help creating a pavillion
How to do array and random reduce
Offset non planar Curve
Invalid surface input GhPython - Sine wave on surface
SIMPLE - Selecting every second panel in grid fassade
Wallacei places the same geometry for different solutions on the grid
Array Series of Blocks Side-by-side
Create randomly organic closed curves
Implicit Cycles Preventing creating a Dictionary?
Data list to CSV with separate columns
Lofting Trapezoid to Rectangle with Planar Surface
How to Loft Between Circles in GH-Python
XZ Plane can't do data conversion from integer to point
Create Lines between List points
Loft-Project-Curve Related Grasshopper Control Problem
Multiple layers
Tensile foam, can't grab point I made
Compare (and label) branches of tree
Distance between all curves and points?
G-Code Generator How to slow down the speed in corner?
Trying to understand constructing this in GH
2 input / 4 input are visible
Internalized Geometry in Hops not being recognized
Extruir superficie desde cara con grasshopper
Remesh With Fixed Vertex and Edges
Convert a Rhino-block into a mesh
Render Heat Map on 3D Mesh / Surface in Rhino
Please I need to learn this for a project
Choice item from list
Any ideas on how to do this
Parametric window rotation
Parabola curved structure
Help which line i need to connect for make thick
Offset on surface
Curve division optimisation
Flat waffle slab structure
Connect 2 circles with tangent lines + remove inner parts
Modifying brep by Moving One Point
Moving lines along a closed curve clockwise
Tree Branch component: SLOW
How can I project all points onto a surface?
Looking to cull points along edge of a subdivided surface
Connect Multiple Lines
Project individual curves onto separate planes along Z axis
Creating railing for bridge
Conversion from string to float
Donut pattern
Obtaining the middle surface from intersecting curves
Grasshopper Facade detail different shape
Dividing a curve with a graph mapper based on specific constraints
How to open .ghdata file?
Rotating a curve based on surface elevation
Fail creating faces out of TriRemesh component
Bypass warning messages
Basic form for adaptive components
Flow along surface problem
Item index and cull pattern
(HELP) Making Inflatable facade by Grasshopper
Surface Tiling
Sweep 1 Not working in grasshopper
Hexagon Pattern with Chevrons
Panelization on a curved pavilion
Rhino inside Revit - Direct Shapes geometry is empty
How to group point with same Plane or same X,Y or Z
Help with orientation of multiple planes
Sorting list
Overlapping surfaces
Using Jitter To Shuffle Multiple Branches in a Tree Differently
Need help on grasshopper
Morph multiple mobius ribbon extrusion at specific points
Preserve tree structure when dividing curve
Y-shaped pattern
Use graph mapper of lenghts
Split Geometry
Changing slope txt output from xx% to fraction (1/xx)
Swept geometries with tree structure
How to optimize Drape's mesh effect in grasshopper
Mesh strips from bouncysolver
How to cull point list like this?
Scale a curve proportionally to another curve
Change the order of points
Perforated Panel - Waves
Manipulate list of lists
How to merge Brep with surface
Array to follow variable curve
Help my voronoi pattern won’t get trimmed
How to create a pattern in all faces of this rectangle
HELP, PLEASE How to properly trim a Hexagonal Grid to a circular boundary
Color Gradient on Curve by the Slope in %
Question: Input Geo Keeps Moving Miles Away with no Transform
How to flip the direction of surfaces fastest
Grasshopper Array with Multiple Line to Control Spread Density
Attractor-Based Extrusion
Offset Points on Curve in Grasshopper
Distribute different geometries randomly on points on a line
Grasshopper split command not working
Ribbing on vase
Ribbing on vase
Automate trimming surfaces with curve using GH
How to orient object to the center of dome?
Mesh cavity detection in grasshopper
Morph/Flow Surface along Curve or Surface
How to find intersection points between a circle (curve) and a polyline
Boolesche Vereinigung schlägt fehl, Ausrufezeichen werden angezeigt
List sorting
Extrude with Random Factor from Predefined Values
"fillet edge" works only on one edge?
Columns in a building which change depending on geometry
Creating a spiral on a curved surface in 3d
Surface morph
Interpolate section curves between rails with adaptive spacing
Data Tree problem
Help creating a solid folded panel
Partition and Split list
Eliminate the numbers of a slider with an output of another slider
Grasshopper pattern
How can i model this building?
Facade Integrate to My Own Model
Create Rectangle of Best Fit for Polygons
Change contour label numbers
Brick wall pattern
Can't make a solid difference out of a collection of breps
Grasshopper weird offset curve
How to make objects organize in a grid
Randon line pattern with dots
Sorting Breps
Splitting a Brep with a polyline
"Parametric Bench"
Is it possible to calculate the length of a Brep using Grasshopper?
Fillet A Cuboid's Edges w/ Different Radii
Select object by location
Help me Merge tree branches
How do you create these parametric structures?
3d cracked voronoi pattern
Merging two surfaces together to create a uniform surface
Merge closest points 3d voronoi
Trusses for non-rectangular surfaces
I’m trying to use veronol 3d but my points in brep aren’t working
Creating something like organic landscape architecture?
When selecting 2 Arcs for lofted surface one gets rejected!
Inconsistency with BBX (now with file, apologies)
Split box into triangular parts
Mero joint
Offset and fillet unjoined curves
Help me please
When I ran this code, it kept the same z coordinate. What I want is for t
Create a random yet regular pattern
Find closest point in 2 directions from a given point
Adding a list into a list with a pattern
Fillet Edge Tree Management
Help for Translation/rotation pattern
Extracting a specific integer from a series
Cutting an arch into an ellipsoid surface
Culling anchorpoints
Isolate lines parts which overlap
Simplify the repeating script
Curve closes point from a point on a previous curve in a series of curves
Topography Terrain generation error
Adjust closed surface seam in Grasshopper
Apply List Length to each of the divided point
Contour connection
I need Help
Diamond Facet Surfaces
Can you help me please grasshopper-rhino 8
Connecting Stairs and Plattform to Each Other and the Building
Grasshopper parallel lines on round curve
Normal orientation into angle a, b, c regarding x, y, z-plane
Elefantenhaus at Zoo Zürich
Mesh edges display bug
Smooth Cream-like Wavy Surface
Anyone knows about how to cull the lines inside a boundary?
How do I create a script for this kind of building
How to create meta coin parametric with laser cut files
This form is how to do?
Turning Mesh into Nurb Surface - something going wrong
Rhino and Grasshopper stop responding
Errors of components in grasshopper
Which component will be helpfull or the ideal to do this?
Duplicated Tree Unflatten per grafted branch
Planar Boundary gives error (not planar) but IS PLANAR
Limit arc curve generation from 0,0 to 90 deg in GH + List driven slider?
Heron example files
How to generate random 2D shapes with random angles and curves as sides?
Tributary area of a beam/line in GH
Send dwg revit to grasshopper
How to connect At-tractor points to Geometry
Definition
Lofting curves in seperate lists
Huge circular Victoria Amazonica lilly leaf pattern
Type Create
Hexagon Facade / planar and equal size + adaptiv triangles
Setting a vector in Human UI and and a point
Closed Curve as boundary for random points on a plane
Code exist for smallest curve between two points with slope?
Trouble importing .wrl file
Mesh Pattern Help Please
How to make like these images' facade
Asymmetrical scaling of curve lattice geometry
Variable folding of an object
Joining two surfaces at a point
Allign geometry to xy plane
List Reorder
What does Rank mean in Tab2 'Selection'?
Extending a Mesh to a Curve
Creating Voxels/Twisted Box between two Surfaces in Grasshopper
Does anyone know how to get a pattern like this
How can I generate the solid model form loft
Superficie loft su curva
Input Area from Excel -> create exact Surface Area/Volume for each Floor
Intralattice: Computer Limitations?
Hexagonal Fading Pattern
How to make 90 degree holes from curves
Cull curves inside or otuside
Split/transform surface with image texture in Grasshopper
Trying to sweep multiple seperate rails with the same cross-section
Divide Curve into segment length
Cant trim Surface, grasshopper automatically full it
1st day at Grasshopper, orientation question
Help! I need help with ABM simulating silkworms
The formula I made according to the picture, but the result is slightly different from the actual one, I don't know what the reason is? Can you help me tell what went wrong?
Polylines from Crvs within Same Branches
Linear regression function
Grasshopper
Rhino, help!
Sphere pattern strips
Describe this force field type pattern please
Attractor points in a surface
Grasshopper
Find an index of maximum value in the list
Linking groups
How to make twisted/rotated louvers on a non-planar surface
How to close out curve made from "Divide Curve"
Parametric brick pattern
A technical problem on grasshopper
How to add and display the 0,1 values of the panel in grasshopper
Revit to Rhino
Re-organizing tree branches
Pufferfish - Tween 'Implicitly'
Dynamic populate
Help for Deconstructing Brep
Array 3 different object randomly in one path
How to make minimal surface like Daniel Piker?
Join polylines efficiently
Wrap a surface on a volume
SRFSPLIT fails at small tollerance
Transparent png import in Grasshopper
Optimizing panel arrangement
Retrieval of intersection points of 2 circles using GH Python?
Duplicate lines in rhino
How to close a volume?
Geometry is not moving to the correct position
Irregular spiral staircase grasshopper
Thickening multiple surfaces / mesh
Extracting row/columns on a grid of points
Interpcurve
I tried to contour a sphere in grasshopper but it failed
Assigning colors to surfaces base on the area name
Perforated sheet
Subtract a list from another bigger one
Extrude object along two curves
Sweep and Spine
How to find center curve of face with Grasshopper
How to model shading structure grasshopper
Texture leaves
Parametric object placement based on line lengths
List item identifies different edge on each element
Wind component
HoneyBee: OpenStudio error
I want to line up a bunch of irregular holes and use them for processing
Import coordinates from an excel file
Help (optimize solar radiation & day light &wind)
Lofting two rectangles correctly
Multiple list with vector
Creating triangular grid from existing list of points
Loft of several curves
How to set joine rhinosurfaces in to grasshopper surface
Selection Filter
Measure distance along curve from starting point to a given point in the curve
Lines between vertices
Honeycomb Definition
Tangent , between to different shape (surface )
Optimalization of a robotic machine assembly for mansory
Heeeelp me plz How to anemone loop
Removing surfaces
URGENT: Grid on trimmed surface
Displace pattern on mesh
Convert mesh to surface
Orient rectangular to line direction
Different results for angle
Loft problem
Join lines, sequence incorrect. Lofting gets messy
Sweep Profile on Tween Curves just once
Brep-Brep intersection
Why does this cluster run by itself when GH file is launched?
Matching components
How to create wave balcony in grasshopper
Export from revit to rhino Revit Linked Models
Cant open Cluster anymore
Screw head bevel and arc
Points list display
Isovist 3d
Me podrian ayudar con este ejercicio?
Construct a polyarc like structure with constraints
What can trigger Geometry Pipeline component refreshing?
Find highest point on a mesh
V-Ray + Grasshopper Scatter for more than one surface
How to make this surface?
Multiple point attractors
Grasshopper: Select all items assigned to render colour, then mesh?
Italian Pavilion Expo
Curve Diagrid Lines
Series component order problem
I want to do this
The direction of curves on surface
Help parametric design
Recursive data changes to a list with on demand iterations
BMW Vision next 100
Error with Multiplying text within leaders
Split curves into straight lines
I need help to create an algorithm for this example
Massing building from 2D plans
About Moving points
Select closed curves by area
Solid Difference Issue
Smoke effect
How to make a minimal surface?
3D pattern across a curved surface
ORIENT or SNAP to surface
Generative lattice/voxel pattern
Controlable Points on surface
User's distribution of geometry populate points
How can i make Triangle facade surface
Separate a part of the mesh
Populate new tree to match size of existing tree
Blending meshes
Simple Parametric Human Body
Split polysurface into halves
Set Curves as Boundary in Grasshopper
About the intersection of Brep object and point cloud data
Average distance between points
List from list patern
Angle between two Vector3d, Vector Direction of a Line3d
Deconstruct Brep is duplicating faces
Fill the closed curve with fixed shapes
Goldberg Polyhedra Pattern on Ellipsoid
Can kangaroo stimulate this model
Offset trim and fillet curves
Connecting points on two different curves using path mapper
Grasshopper Diagrid Structure Error
Blocks management in Grasshopper
Polyline in elevation.. pls help
Grasshopper points to Rhino Geometry
Grasshopper paneling tools script issue
Contour along curve
Material in grasshopper
Attach a parametric facade to a solid
Cannot trim or project onto a surface
HELP with grasshopper to make waves project
My Vector Display EX doesnt work
Grasshopper Intersect Breps with multiple planes
Finding a specific function
Parametric with for rectangles
Connecting open beams of trimmed lattice structure
Logarithmic Spiral Along Truncated Cone
Smooth staircase handrail challenge (normal vectors in Y)
Vertical Arch hangers
Create windows between two parallet meshes
Adding areas of same height surfaces
Slider with expression in RH8
Bouncysolver question
Origami Structure
Brick design
How do I cull mesh items based on area?
Square Piping Orientation Help
Data conversion failed from Revit Host Type to Component Type
Fillet between two geometries
Gradient by diameter
Can't restore the numbering order of elements
Help please ! Split Brep Problem
Help with making a simple 3D shape with curved and straight edges
Voronoi 3D Weaverbird Thickened Mesh Invalid
The amount of numbers must be a multiple of three
Sweep2 but with array
Group Colliding Object with Grasshopper
Offset Surface issue
Even numbers from float random numbers
Two types of rotation on Grasshopper - parametric fan
ISOVIST not working on ghpython
Mesh/ net modeling for 3d printing
A question Helppppppppppp
Align all curve normals
Plugging vector list into vector display doesn't work
Diamond grid based on points
Road Design - Continous Slope Evaluation between points on curve
The loft isn't working
Help to create Lamellas on surface
How do I create a facade / create texture to a geometry?
Close the opening between multiple pipes
Water wave-like surface with multiple wave center points
Honeybee in grasshopper
How to shape an object between two curves
Tangents of one curve at division points
Boundary Surface - Isoline
Set height in Grasshopper and connect in Rhinoceros
How to make such vases
Separating odd from even numbers
Search for specific items in a data tree and create two new ones
How to represent the entire path by a token in path mapper?
Equal distance between the points of three different curves
GH run very slowly for thousands of geometry
Spiral curve on surface we have 4 isocurve divided
Combine two grasshopper to one file
Matching tree lists, assigning each x its y
Sweeping 2 Data Trees
Rhino Wallacei problem
Division of a terrain mesh into sections, problem with data tree
Bricks random pattern
Color grading based on one point
How to Rebuild the surface but not affecting the 4 corners - grasshopper
GH - Why doesn't Join Curves Join Curves? Bug?
Mesh need help
Updates Grasshopper from Revit
Grasshopper Sweep1 Multiple Curve Problems
How to select a part of a mesh in order to panelize it for digital fabrication?
Data tree question
Remapping Tree based on discreet values
BASICS: Elegant way to truncate list using Z coord as criteria
Free form Model to 3D Lines
Transforming already modelled surface into creased surface
Grasshopper Extrusion and Training Suggestion Inquiry
Age of Air in Grasshopper
Are two points the same?
Parametrical facade paneling, perforated facades
Apply pressure on multiple surfaces
Scattering the squares of different size using grasshopper
Just installed Rhino7 & Grasshopper component library files are empty
How to prevent or cut extra points made during lofting
Grasshopper Rhinoceros, what can I do with these?
Join and Loft not working in Grasshopper
How to select surfaces according to boolean list
How's the best way of doing this type of building?
How to sweep a phyllotaxis in a desire section
Recreating a sound to form definition
Shadows "wireframe tracing"
Need help to Cull inner lines of the voronoi pattern
Pattern Rationalization
Removing rectangles that are below the required area
Input a series of Tyson polygons into a python script as an array
Cut surface in grasshopper/rhino
Geometric Pattern
Polygon clipping and offset
Changing pore measurements in a cube
Drawing Nurbs Curves in DrawViewportWires
Invert attractor effect
Extrude curves from a sweeped surface perpendicular
Something like this in Grasshopper? (Waffle structure follows curves)
Excuse me, why is there an error here。。
Grasshopper Construct Mesh
Trouble creating sweeps in grasshopper
I don't know how I can match these lists
Introducing Graphics Overrides in Rhino.Inside.Revit
Changing only the seeds in an array
How to make a surface curve upwards
Isometric triangulation a weird shape
Problem with graft when i do multiple windows but i can’t see where
Custom preview doesn't work well
Grasshopper script help
How do I remove one branch from JoinCrv result before feeding into Boundary Surfaces?
Simplify curve. Keep features
How to draw an array of rectangles with respect to two curves?
Ask about kangaroo
Parametric 2d room analysis + area calculating
Vertical shading in window
Twisted surface on kangaroo 2, need help
Revit to Rhino
Variable Voronoi mesh size
Modify contour
Rules generator doesn't work wasp
How to select the whole list without the first 5 lines?
Remove duplicate numbers from a list
Bug with the catenary component where it goes in the opposite direction
NEED HELP URGENT: help for college project
I am trying to make this pattern
Irregular diagonal pattern
Meshing in Rhino
Incremental rotation of elements in branch
Performance improvement of a GH_Python script
Any help, please?
Help in parameterizing a wooden ceiling
Extract Center of Rectangle
Is there a similiar command for this in rhino ( Quadfill)
Curvilinear shapes on rhino
Points dependent on sine curve and distance to point
Pattern along Curve direction
Nurbs surface is reconstructed based on arbitrary scatter
Tangence curve
How to reorder grasshopper tree points
Complex surface with point end on Grasshopper
Create a volume between surfaces
Pointy Merging Piping Command Issue in Grasshopper
Problems with column structure on grasshopper skyscraperg
Ayuda, malla en tubo [Help, tube mesh]
How to create macro to Convert any suface to patched surface
Creating a circular, hexagonal fading pattern with paneling tools curve attractor
Rotational Analysis For Brick Facade
Waffle structure not aligned
Making Lighter 3D pattern with certain boundary
Line between 2 points with the shortest distance
Guidance in trimming shape
Vectors don't go around spin forces
Edit: Array a surface at along a set of points
Select lines within the closed curve
Parametric window modelling
Filter curve by color
Manipulation of only certain parts of a mesh to fine tune final shape
New to Grasshopper, don't know how to save shape
Anemone loop duplicates first item
Merge edge/join edge grasshopper
Ridiculous moderating?
Curve array, number, pitch and location on curve
Error from assemble model
How to create recursive systems in Python
How to move point up and down to alter initial geometry
Getting data from a list
How to separate branch Surface and how to change dispatch direction
Sweep1 fails where extrude along doesn't but orientation wrong
How to recreate this mesostructure pattern with Grasshopper
How to combine data of 3 different panels into one panel?
Filtering Frames Above a Plane
Quick way to import points in Rhino
How to do parametric column
How I can create 3d Section on Human UI?
Several surfaces calculation
Creating Close Surface to generate interaction diagram
Scaled version of closed curves
Multicurve Attractor on a curved surface
Grasshopper Parametric Extrusion
Connect the points to form bridge piers
Need help here
How are all open breps combined by Simple mesh component
Help me, my brothers
Evaluating unjoined distanced surfaces as one
Help Us Help You - Rhino.Inside.Revit Edition
Cocoon split surface
Sweep1 "roadlike" inside grasshopper
Hypotenuse length problem
Grasshopper Custom Preview Controlling Others In Rendered View
Algorithm for Fascade
Problem with origami kinetic facade grasshopper
Projection of a geometry onto a plane creates invalid line
Is there an easier way to implement these series of precise arcs?
Is it possible to split a list of 3D points?
Draw line between points(problem solved)
Grasshopper frames on rails issues
How can I add up items in a branch?
Connection Problem line-surface in Rhino 6 with Karamba
Multiplying indexes in Relative Item offset
Gradually increase distances between elements in Z direction?
How can I connect triangles' points but with closed polylines?
How to pixelate a form in grasshopper
Design Seashell
Move curve to specific Z value
Grasshopper - grid with local extrusion and spacing control
How to rebuild organic curve to segmented polyline
Dispatch surfaces based on whether they are positioned on the XY plane
Boolean union of closed Breps in Grasshopper
Script for wood pattern
Adjusting geometry breaks array
Rearrange data tree
Organize tree branches according to culled list
Displaying temperature values as colored mesh
Find external surface area and orientation of cluster of blocks
Elliptical+surface challenge
How to erase/hide a this square
Grasshopper school project. Need help
Orienting and arraying a Brep on the middle of a surface
Subtracting non-intersecting solids
Perforated Screen ( Jitter)
Grasshopper rules
Tree operations python Grashopper
Subdivide a surface into pentagonal shapes in Grasshopper
How to fillet edges of solid union intersections
GH Run slow when slide the parameter for wallacei solver
Trouble with Voronoi on Surfaces
Divide closed curve into several closed curve by split lines
Creating rectangles from a divided curve
Surfacing and fillets
Input parameter for component
Script for Straightening Plans
Help in creating a shell!
Pattern Based Image Sampler
Grasshopper parametric tables
Tiling script / Grasshopper
Select unique cube configurations
Order path list
Closing Surface from Points
Scale object distance non-uniform from point
Create curve from points
Map curve to surface
How to find a specific DATA PATH and rearrange the combined data
Trouble selecting a specific intersection point
Loop de loop surface in grasshopper
OpenNest - Can't use closed curves
Assigning material randomly
GH Tesselation Challenge
Adding items by branch from a list to another list
Select points with highest Z value per (X, Y) coordinate
Close a Brep
Calculating angles with a condition
Lofting a cloned and rotated curve vs a cloned and translated curve
Help me with school assignment asap using grasshopper
Select objects based on properties
OffsetMesh no working properly
Spreading Contour Lines Starting in a Single Plane by a Set Interval
Help with attractor perforation
Changing the diameter of colums, angle and height
Help us create a parametric model on rhino using grasshopper!
Pull Point working on X axis instead of vertical axis
Serialized breps to nesting
Im trying to make this module in grasshopper for a week, bit challenging
How to extract the vector from each segment
Attractor crvs for multiple crvs
Sorting edge points laying on inclined plane
Split list + average elements from a sublist
Rhino 7 wip for windows
