Change contour label numbers
Hello
I don’t understand, you use Grasshopper
So no problem, use the addition component to add 13, it will be done for all values.
If you want to find the maximum value of Z in a list you can sort the Z and take the last value using a -1 index.
And if you want better answer, it could be better you post the file and some others explanations.
