Not commenting on the banter, but to be fair it is in the guidelines of this forum:
Specifically this
Many of us like to help, but it’s good to see effort on our part being matched by effort on your part. Questions in the form of “ I need to do X but cannot be bothered to try and learn the software ” will (and should) go unanswered.
Similarly, questions in the form of “ How do I quickly recreate this facade that took a team of skilled professionals four months to figure out? ” have a very low success rate.
Also OP says he tried some stuff so he should post it like guidelines suggest
If you have a
ghfile you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from aghfile. You can use the Internalise Data menu option to cut everything to the left of a parameter:
@ifle7516 from your post it seems you have something but without thickness. Without seeing how far you have gotten all I can suggest is to look at thicken mesh from weaverbird. You could do this whole tower by cell and boxmorph logic via minimal surface type cells pretty easily, take a look at the Pufferfish example files as there is some stuff in this flavor.
