Welcome to Serengeti
Serengeti is named after the largest African Savanna where Rhinos grow.
Shape Rhino’s future.
Try the next version early and share feedback. Download Rhino BETA.
As a Rhino 8 owner, you can download the weekly work-in-progress (BETA) builds. These include all current features and experiments, even ones that may never be released. You also get access to developer discussions, notes, and the issue tracker.
We look forward to your input. To stay in touch with the developers, post here in Serengeti.
Here is most everything we are working on.
Change log.
More details:
  • CAUTION: These are weekly BETA builds. Often they are not stable or production-ready.
  • Do NOT uninstall your Rhino 8.
  • The Rhino WIP file format is changing. To be safe, Save As Rhino 8 often.
  • All Rhino 8 plugins should work with Rhino WIP; let us know if they don’t.
  • Existing Grasshopper definitions should work with Rhino WIP. Let us know if they don’t.
Enjoy!
Educational License download RH50 to RH6B
Vector 2D view
Python improvements in Rhino WIP
Suggestions for GPU renderer and graphics card (possibly for Mac with Razer Core)
Grasshopper components display as blank - no icons, no name labels, no wire nubs. How to find missing graphics?
T-splines and Rhino 6
How Do I Actually Download Rhino WIP?
Rhino 7 WIP - Raytrace Rendering
Raytraced (Cycles) shader progress
Try the Rhino WIP
Layout & UV Mapping
How to union a series of planar surfaces into a single surface?
Class A surfacing tools
Rhino V6 timeline
How long should the wait be for 2D drawing create?
Welcome new Rhino WIP users!
Few questions about Cycles
Pull curve to mesh with loose option problem
M1X & Monterey
Cylinder mesh - Quad only
WIP - RH5 license key used by someone else
WISH: Add "only visible geometry OSNAP" mode
Rhino 8 WIP Feature: Constraints
Cycles for Rhino 0.0.2
V8: Toolbars and SVG
Yak stats for packagemanager
Workflow optimizing for product design
New Layer with random color
Rhino PythonScript commands slower than equivalent VBScript?
How to straighten control points row
Text properties is buggy
Rhino 8 Feature: Improved UV Mapping
Wish - Folders in Layout Panel
Downloading V6 with an Educational Lab License?
Rhino 8 Feature: USD (Universal Scene Description) Export
Dim angle doesn’t work on a curved surface
Sernegetti
TextObject - Wishlist
YAK - install plugin requires re-start of Rhino
PointCloudContour origin
SubD Symmetry?
SubD - Local Face Division
Brep.Trim with flipped Brep as cutter
A few more suggestions
Convert to SubD, problem with creases
OSnap Toolbar / Panel
Cap command is corrupting the surface
Bug CurveBoolean
Rhino 8 WIP boolean behaviour
Wirecut vs boolean difference
Wish: Coloured control points
Direct 3D still needs attention
Minor osnap/filter list ui bugs
Hide subdivision faces
How to untrim one of trim edges while keep inner loops in C#?
Rhino BETA Feature: New Audit3dmFile…Graphically
WIP (8) feedback
Command history F2
Wish: SubD Retopo tool and SubD Flatten points tool
Extractsubcrv and subobjects
Percentage along curve
Insert edge problem, bug?
EndBulge enhancements request
WISH: specialized gumball for control points
Cannot export OBJ or FBX meshes in V7
Hotkey Nudge Direction
Bug: "Select Object Layer"
ProjectCurveToMesh bug on triangle edges
(Mac-) Macroeditor (Bug) double-quotes
BUG : Printing layout broken - Rhino 8 WIP
Rhino 8 Feature: SectionTools Integrated
Command Prompt Cannot Be Shown from UI
Rhino 8 Beta opens two notifications panels
Transaction Failure in Scripted C# Component
Curves from DraftAngleAnalysis vs. TestSilhouette
Layer States Panel Behavior
Set CPlane to Object has a Bug
FlowAlongSrf history breaks
Text dialog initial bug
BUG? - CurveOffsetCornerStyle.None produces bad result
Full Layer Names in object properties and status bar
V8 ChangeQueue & Raytraced broken for objects with sub-object materials
After last WIP update, grasshopper crashes when offseting closed curves
RibbonOffset's "Side to offset" pick point's affect on result
V7 Text field is missing
Bug in executing Stitch command/subd/mesh
GH2 stuck loading
How to 'UnJoin' a polysurface edge?
Custom UV texture misalignment
Wireframe of SubD always visible with transparent material
V7 change in behavior for RenderWindow.Channel.SetValues with RGB channel
Offset Star Curves problem
Shadows and Display Speed test/need for tune-up
How can I input the coordinates as same as Autocad?
Fin command problem
R8 layer panel drag&drop
Toolbar Separator move crashes Rhino
Using Metal, hatches show through in all display modes
Hatch. Control Points. Control Polygon doesn't highlight. (Bug?)
Rhino BETA Feature: Global Edge Continuity
Rhino BETA Feature: Create Hatch patterns with Grasshopper
Rhino BETA Feature: New Default Hatch Patterns
Rhino BETA Feature: Physically based material displacement
Faces selection bug?
Cluster runtime very slow
Rhino BETA Feature: Transparency Color and Refraction
Surface filleting across Tangent faces bugs
Drag 'n drop .pat hatch patterns...?
Bug : MMB can't manipulate the view on macOS
Rhino BETA Features
Rhino BETA Feature: Shapes in linetypes
Torus as Fillet
UserData is broken for geometries. It wasn't 1 month ago
Subd faces extrusion
UI / Interaction questions
Multiple Mapping channels for UV Editor in Rhino 5/6
Can you make a script to pick only unwelded edges as seams?
[UVEditor TIP] UV mapping: Replace your UV Grid Texture
ArrowHead bug report
Add option to show N last characters in long layer names
Rhino BETA Feature: Patch re-implemented
Rhino 8 - Clipping drawing misplaced background
Sub-d To NURBS observation: No Iso-Curves
OrientOnSrf needs a better UI
Wirecut bug
Rhino 8 Feature: Selective Clipping
Dodge History Prefix Request
V8:Gumball bug
Gumball on Mac
Printing PDF on OS X Ventura In Rhino MAC 7 is slooooooow
Query Model Objects lag
Tried WIP since months
Feature Request: SelHatchPattern
Selected object blocks selection of other objects
Will Rhino 8 Have a Proper Dark Theme?
Where's Rhino PDF printer driver?
Selection problem: Cursor is in different position than selection square
Delete Key does not work after selecting objects by layer
Bug ? Split with Point with .z
Copied layer location
Mesh Extrusion Bug?
Why release Rhino 8 if so many features have been dropped from WIP
Display glitches pen/artistic/technical display modes
Spotlight not working Rhino 8 WIP
Bug - Ctrl + F* not working
Spotlight in R8 Beta does not light the surface
Feature Request: Section Box
Clipping box in 3D view
Missing: Clipping box trick
Section box tool in Rhino?
Why is there a fly-out from the Filter panel?
Reading plugin data when importing from a 3dm file
WISH : Avoid unsollicited arc splits
Yak not populating details from manifest
Bugs: Bump not showing, Geometry dissapears in Rendered
DarkMode+LightMode Bastard behaviour in Rhino 8 Beta SR0 (Oct. 10 2023)
Procedural textures + UVW Mapping in Raytracing display mode broken?
Viewport Border Went Missing
Glitch: blue target boxes stick around
Rhino.Geometry.PointCloud RhinoCommon feature request
Displacement texture distance unexpected behaviour
[Rh7 WIP UV editr BUG] UV Editor UV mapping does not show up on this particular mesh
Detail WIndow Misbehaviour
Gumball vanishes from Decal widgets
Gumball relocate issue
Mesh.IsPointInside() persistent bug
_Select command and _SelPrev history
Mesh effects feedback
Rhino WIP Repeating Crashes with Isolate objects
New UI - Floatable resizable windows can be permanently hidden
Aug 30 WIP 8 update mac
GH conversion from Vector to Geometry fails
Q: How to push edges, and corner to zero?
Clipping plane does not clip curves
🐛bug - Layers drag to sort
Can't get the meshes (render & display quality) displayed smoothly
Bug - meshsphere not symmetric
Print to RhinoPDF includes external area
Trim Bug in WIP
Import DGN file with references
Rhino BETA Feature: FilletSrf improvements
Sketchup to Rhino
Convert Brep to extrusion (RhinoCommon)
Smart track, smart just not too bright
Rhino 9 WIP: PointClouds not displayed correctly
WIP Sectioning Attribute Requests
Numpy for Rhino 64 bit
Slow display performance when using clipping planes
Select Mesh Naked Edge - (feeling lost between commands)
Clipping plane - Snapping to the clipping plane edge
Rhino BETA Feature: Direct3D Display
Scale issue with .svg
Inaccuracy in exporting of adobe illustrator files
Rhino Beta - Crosshairs, StretchCrv, Black/White OBSOLETE
Inset command Rhino8
Sweep 2 ... why doesn't work?
Removing CPs makes surface rational
Material.FromJSON() Unhandled exception
Bug: Inability to move an object to the CPlane zero
Wish Hatch to behave as curve on more areas
WIP has broken a couple of items in my plugin
Looking for volunteers to try out new UI for FillSrf
Request: Smooth Control points preview
Bug blockmanager: "ERROR no geometry found" at copy/paste existing block
Layer state associated to detail view in layouts gets dis-associated
Bug: Looks like _Hatch stops the recording of commands to _Undo
Double tapping Ctrl to delete SmartTrack points not working
Blend two curves with G3 continuity in Grasshopper
Automated Way to Achieve _BlendCrv with G4 Continuity?
Sublayer visibility issue in Raytraced mode
Same hatch in two layouts with different colors
Zlib version
Offset SubD - deviation
OffsetSubD requires interactive preview of updated values
Large file won't open, rhino not responding
FBX files >100MB not importing into Rhino 8
Simplify Failed on Simple Object
Issues with display modes in Rhino BETA
Display mode to show only border of polysrf
Rhino BETA Feature: Concept Display Mode
Dynamic help error for RestoreLayerState
BlockEdit consumes objects
Rhino BETA - TextObject - Remember Last Input Wish
Strange geometry/bug showing in technical/artistic/pen views
Bug Report: Clipping Drawing "Visible Background"
Is there a way to select the diameter of a circle/cylinder?
Rhino BETA Feature: A new algorithm in the Rebuild command for Curves
Patch (New) Untrimmed does not support internal points/curves
Rhino BETA Feature: Gumball Control Polygon Alignment
Detail Section Styles Pattern Color
Rhino BETA Feature: Command Line UI unification
Rhino 9 WIP - Bug latest update - Mac Platform
How to get/print PNGs with transparent background?
Rhinoceros 8 - Popup toolbar resized
Make2D - "background" curves in separate layer
When did that happen?
Import toolbar into Rhino 9
Rhino WIP changing toolbar properties image
V9 ClippingDrawing. Hidden objects and output duplicating issues
Rhino BETA Feature: Updated Toolbars
Rhino beta - camera movement very slow when objects are selected
Restriction of ObjectType in RhinoCommon
Rhino BETA feature : FilletSrf with spherical corners
SelName popup issue
UV symbol colours
Rhino 9 Beta Grasshopper 1 Slider Lag
Shrinkwrap component expired - weird crash
Text Dots in Blocks print different size in Technical display mode
Reporting Bugs... (or rather: Please help with advanced settings)
Pixelated textures in Rendered display on Rhino 9
Prototype: Clone/Copy Clipping-Drawings In Source Layers
[wish] ImportLayout - ClearAll button
Rhino BETA Feature: ArrayCrv
Dxf export settings not holding
Matching A3 Layout view with A3 on model view
Some instant aliases fail to execute
Distance from dimension line to text/numbers adjustable?
Visual bug after extruding/moving edge with Gumball
Text mask in R6
Text and dimension masks
Dimensioning: annotation style, text frame thickness
Is it possible to add the BothSides option to OffsetMultiple
Rhino 8 bug: Hatch 1D scaling
Bug report: pipe connection failure
"Self intersecting loop was found. No hatches made."
Hatch Worked in Previous Version of Rhino But Not Now
Displaying selected elements takes too long
Rhino 8 lags when selecting object
Faded Grid
Rhino BETA Feature: Layout Groups
rs.AddBlock always uses the Origin as base_point
Deleting objects on reference layers
Add precision parameter to ON_BoundingBox::IsDisjoint method
Dimensions display wrong unit values when using "limit" tolerance style
SoftEditSrf - don't try it on dense (high point count) surfaces
Markup issue in iRhino 3D
The Squisher’s Problem!
BlockManager columns
Section style won’t show when using create a drawing command
(small Bug) revolve - Start-Angle and Full Circle
Soft Transform - Selection Issue
Global Edge Continuity – Issue
_CurvatureAnalysis decimal separator
Strange results of Merge All Faces
Lights which are not part of blocks are still accesible while block editing
Small UI issues
_Line options (Perpendicular)
Section styles controls
Wondering what's in the Rhino 9 WIP (Work in Progress)?
Mesh.IsManifold returns true for non-manifold meshes
Question About RebuildEdges and Tiny Surface Gaps
Naming difference in GH Components compiled in Script Editor
SoftTransform - Stays enabled after closing panel
Editing toolbar icons crashes the WIP
Worksession - "Copy Objects to Layer" for objects in attached files
Paste + nudge gives me a windows error sound and no nudging
SUBD edge loop gumball improvement
SUBD face select gumball improvement
Rhino BETA Feature: Markup
Strange issue with Copy Paste causing linked block to import again
Toggle window asking for selection from multiple overlapping objects?
Rhino BETA Feature: new Split Point Cloud command
Regression: Verbose Error Messaging
🐛 Script Editor - Always In Foreground Over Rhino 8.19
Layer dropdown selection bug: only text area is clickable
New filename for WIP?
Ellipse through points...no command
Spacebar in Grasshopper crashes Rhino WIP
Bug: Script Editor resets code when re-entering a Cluster (Rhino 9)
BUG: Rhino 9 WIP shrinks the floating toolbars
Rhino BETA Feature: SoftTransform Enhanced
VSR end of Life-
Toolbars not showing Rhino8
CGAL on Rhino8 ScriptEditor
Surface modeling problem
Feature request. Edit group like edit block
BlockResetScale not working. Bug?
Can i disable grid fade?
Materials and sub-objects - probably a bug
Leader text cut short
Ray tracing with edges
Import only selected named views please
Bug: popup panel gets hidden as soon as wheel is not pressed anymore
Rhino BETA Feature: Linetypes With Shapes
Seperate Grid (Snap) values for XYZ
Rhino BETA Feature: Template Layers for Clipping Drawings
Using V9 With 3dconnexion Space Mouse
BUG: Hatches displayed in front of other objects
UDT FlowAlongSrf - refit vs. refine/addKnot
Text to support "tab" please
Baking textures of multiple objects into one file
Direct3D Monochrome misses outline
Rhino BETA Feature: Boolean Improvements
Rhino 8 | Section Drawings | List of bugs
Wirecut ongoing issue with crease splitting
Using the Guides Tool
Rhino WIP: Text Entity Line-space Scaling Doesn't Work for Values < 1.0
Rhino 8 ScriptEditor file tabs window feature missings
Request: Script Editor - More options for toolbar
Gumball smooth/snappy toggle
V8 ScriptEditor search and replace... NO UNDO?
SECTION TOOL improvements
WISH! Parallel guide lines in Rhino6
Gumball User Experience Suggestion
Rhino 8 ScriptEditor feature requests
GD&T are you using it in Rhino or your work?
Patch: preserve edges of input surface
Show a surface's UV direction
UV Indicators
Text proportions goes brrr outside standard letters
Feature request: Appearance adjustments for U and V selected control point indicators
Unwanted surface splitting
BUG: Leaders in Detail View relocating
Import Dim Styles - Deselect All?
Drag Strength UI Proposals
UnrollSrfUV Linear direction
Exporting Multiple Block Definitions
Hyphenated command doesn't prompt options (_-SaveSmall)
Squish crashes Rhino Beta
(Wish/Ideas) English-Interface for non-native speakers
BUG: The layers panel will hide while naming a new layer
Zoom Target stopped working
Can I set different languages for Rhino's UI and Help panel?
Scale dropdown for pages layout, please!
Mesh boolean union problem
WISH to have SOLID from Srf tools (when possible)
Wrong shading in Concept mode
Control+Command+F doesn't work
RhinoCode.exe - Failed getting nuget packages
Custom user text in title block
BUG in Clipping Drawings - doubled output
[BUG] Materisl thumbnail in Layers Panel does not update
Hide in detail shows in other detail
Shift+Tab direction lock not working in Rhino 9 WIP
ExtendDynamic only let you shorten curves
V9 Beta. ClippingDrawing feedback and questions
BUG: Broken zoom with the 3d mouse [Commandline gets blocked]
Rhino 8 - Make2d Ignores Clipping of Blocks
Custom Preview (WIP) - Transform input?
Bug Make2D Nested Blocks Text with Text Field Formula
Dir -> show arrows only on one side of the surfaces?
BlendCrv with G4 continuity produces a curve that is only G3
IsolateToViewports is counterintuitive
Set Difference, Intersection, and Union Have the Same Output Name
Units change issue/bug?
R9 difficult editing text
Vertex crease Broken?
Space no longer works in gumball transforms
SelBox/SelSphere selecting objects on Layout
Wish History to recognize when mirrored objects are moved together
Copy and pasting a TEXT element from paper to model space, it vanishes
Gumball value entering with Space not working
Analysis Tools' Switch – unequal behaviour
After today's update got this:
Saving a Gradient Hatch for future use / share all using Rhino
ArrayLinear - preview setting doesn't allow adjustments :-(
Wish: Improvements of the "Select by object name" command
How to heal hole in trimmed mesh?
Please remember position and size of the Toolbar dialog box
V9 Beta Dot - no primary text entry box on initial try
Clippingplane - Array - incremental naming not working
Scale UVN in Serengeti issues when selecting all points
Rhino BETA Feature: Text Formatting
Audit3dmFile - Need Text Output, Same As Previous
Rail / Leitkurve / Geländer wording
Rhino BETA Feature: StretchCrv
Rhino BETA Feature: Black / White Switching
Tabs in Notes
(papercut/wish) InsertPoint (SubD)
WISH: Justified Text
How can I justify my text in Rhino? MAC
Grasshopper Step export fails
Rhino BETA Feature: Knife
Can’t handle linework like AutoCAD
Justify text
Why are fillets so bad?
EdgeSrf with 3 closed curves now broken V9 WIP
Rhino BETA Feature: Parallel Lines
Gumball Plane Handle Not Maintaining Planar Movement
Problem with Self-Snapping behind constrained ClippingPlane
Toolbars and Macros menu items
Rhino V5 onto WinXP 32bit...how is it done?
(Paper-Cut / Inconsistency) Layer of new Objects
Wrong location snapshot when importing terrain from SketchUp
Sweep2 - incorrect seam direction, surface flipped
New Splash Screen - Can’t set default Template file
Quad OSnap on details in Layout space (and other CPlane wishes)
New command line
Bug: Picture objects not displayed in Shaded mode (visible in Rhino 8)
Clipping drawings - include text/annotations
ProjectToCPlane Bug - Extrusions
Rhino9 wip question about annotations
Rhino 7, 8 and 9 - Angle dimension bug
Microphone access from Rhino Mac app?
How to save a toolbar in V9 Beta
Bug Annotion in Clipping drawing
Hatch inside another block turns black during BlockEdit
Sweep 1 Rail not completing along full path
Lower case letter 'k' not working with Explode function
A plea to keep MeshMeshFast (or suggest alternatives)
Snapshots Animation Not Working
Bug: DraftAngleAnalysis pull direction sometimes flips during EndBulge
MatchCrv preview different from result
Rhino WIP - Sweep 2
_ReduceMesh preview issues
Skin DLL not loading when /nosplash parameter is passed to rhino.exe
Blend Material appears either/or
Blend texture and multiple mapping channels?
Nested Block Editing
BlockEdit workflow: editing nested blocks by double-click
Blocks ---- issues
Editing a block within a block is maddening
Other CAD software, SketchUp compared to Rhino
Block Edit Inside Block Edit (SUGGESTION)
(Rhino 9 Beta, Mac) _textObject, initial panel size
Accessibility Bug: Aliases Smushed Together
Rhino 9 ArrayCrv
Create Sublayer, tab, rename, tab, rename doesn't work the same anymore
Sweep2, Output SubD - Same Options, Diff Output
Rhino 9 BETA: Display Optimizations
Reference Layers and Joining Objects
GRRRRRRR Multiple Grasshopper sessions file overwrite no warning
Rhino -> AutoCAD Export: Not Recognizing "Alternate units below" Flag
Mirror Hatch to keep orientation
Roundhole should ignore the Cplane
Rhino BETA Feature: Surface Direction Indicators
I get license problem when try open RhinoWip Mac
Sub-d flat mode pick - Bug
Rhino BETA Feature: FilletEdge and BlendEdge corners
Skylight shadow resolution
Materials panel thumbnails missing
PlanarSrf produces surfaces with inconsistent isocurves
WIP bug_Popup menu command crashes
Folder not holding
Trim Command, Amend Cutting Object Selection
Rhino BETA Feature: Non-Rectangular Details
Crash WIP9 TestSquish
Terminate the processing command
Rhino BETA Feature: Zebra Improvements
RebuildUV - add Retrim option
Failed to Register RPC client
BooleanIntersection bug?
Bug: Raytraced (Cycles) continues through a reduce mesh
Step file with incorrect geometry
File opening issue
Possible to remove the 0 from fractional imperial dimension reading?
Color indicators in layer panel
Can't cap perfectly trimmed polysurface
MacOS Settings : Hatch are difficult to work with
Gumball relocation issue/inconsistency (feature request)
Copy/paste geometry between instances of Rhino and Autocad?
Phantom object and display problems
Missing lines when script sent to print
Question about MultiPause in macro?
Macros With Multiple Pauses?
Selecting layers by name has stopped working
Record History for a Boolean stops working when object is inside a block
Rhino 8 WIP Feature: New Layer Visibility Control (Obsolete)
Rhino 6 WIP/BETA?
Rhino viewport navigation request
New UI: I would describe it as "fragile"
Operation Workspace screen like illustrator and VectorWorks
InvokeOnMainUiThread
Copying text in dark mode, inverting result in black on black
Little BUG: importing hatches
FillSrf - Wishes / Features
Rhino 6 WIP/BETA?
User text and Named Positions
Solved - Text Control Points
Realtime preview of new/unique layer materials?
Unwrap - non uniform scaling
How to modify a surface by designating the heights of any arbitary points on the surface?
BUG: wallpaper with transparency loads/looks incorrectly in V9
Question/Wish: Move vertices to circle?
Help us improve direct modeling: record yourself modeling this camera!
Request: Reduce Layers Panel Color Icon Stroke (and fuzziness)
Can text editor by bigger?
Rhino BETA Feature: Cursor Crosshairs
Full Dark mode GH
Serengeti Access Enterprise
Add Control Point Distribute Feature
Can't access Serengeti link from email invitation
Rhino 5 SR14: Bogus VRAM detection and low-res textures on NVIDIA GPUs
WIP8 Mac to v7 Layer State issue
Cannot download Rhino 6 WIP? - (fixed)
Need help for component that calculates Brep Volumes
How about more than 64 cores support of rhino?
Apply different materials within a polysurface
Woops, I've forgotten where the V6 download is, can you help?
WIP Selective Object Clipping feedback
API to EditPythonScript at a given location
New UI: How to move the panel tabs to the other side
Bug: Disappearing Gumball after extrude
New UI: First impressions (Huh?)
Rhino V6 WIP unable to download
Super frustrated. Rhino 7 freezes when I capture to file on Mac Studio M1
BUG: Dot text rides behind section cut
Clipping plane view slow
Clipping Planes- Used to be able to
Clipping planes still too painful. Will it get better before V6 launch?
Clipping Plane Fills! Please
Suggestion for V7- Clipping plane fill inherit the object colour
Box Corner Output Tooltips
Rhino WIP Download link?
WIP download link is redirecting to /download
Soft Transform - Topology Distance
I cannot update RH6 WIP
Limitations of New Picture Command
To Break History or NOT to Break History
Do not show this dialog again bug
R6 UI colors aren't compatible/transferable to R7 BETA?
Loft with history jumps to wrong edge glitch
Gumball on Subd-Edges not always centered?
RH8 Beta Raytraced display mode shifty BUG
Location reset every time i close rhino 7
Multiple Layers Panels - lock icon inconsistency
Icons get better
PDF Import Painful
ON_PolylineCurve parameter vector (m_t[]) initialisation
Marine Design & Engineering Meeting Barcelona - May 8, 2019
Dots linetype bug
How does one show the dots linetype? - Other linetypes do work
Changing one Layer's transparency is affecting another layer
Blocked Objects and Clipping Planes
Text object uneditable?
Disappearing wireframes
New UI: Text along with tab icons?
Joining creates bad object
RebuildEdges post-selection bug
Bad graphics with wireframe
WIP 8 Antialiasing issue
Display mode, render - copy, change color and Material (bug ?)
Issue with OffsetCrvOnSrf on sphere
New UI: Lock docked windows doesn't work
!_Cage wrong by curve
LayerState questions
Crash of v8 during detail view rotation
AddLoft Tangency in script
Import 3dm issue
Rhinoceros 7 WIP - QuadRemesh crease edges
Texture files not connecting
Problem with dimension lines after latest update
License expiring in Rhino 8 WIP
Resizing pop-up toolbar
Split Ellipsoid
Object faces won't print by layer
SubD ununified directions on one object
Running _TextObject causes crash and strange display
Hatch transparency missing for print color
Text Entitiy CreatePolySurfaces returns Null Value
Denoiser issue
Hatch gradient new point issue
Worksession.ModelCount causes exception in RhinoCommon Mac
Render Output Control?
Blocks are loosing hidden Objects
Rhino 7 Feature: Display Performance Discussion
Linetype inside blocks don't work
Give control back to command prompt after attribute user text edition
SubD to Nurbs buggy
A way to locate the corresponding layer?
Is it possible to add a SubD object to a File3dmObjectTable?
GlobalEdgeContinuity - Flat parameter effect unpredictable
WIP - Hatch - hmmm...?
MatchMeshEdge through scripting or Grasshopper 3D components
GlobalEdgeContinuity Feedback and Issues
Rhino 9 WIP | Bug | Purge command clean sections
MergeEdge problem
My Feedback regarding gradient hatch
OpenGL material bug
Issue with Markup causing failure on Import Model Block Definition
Bug? ExtractRenderMesh from Linked Blocks
Get gumball custom location
Render Animation very different from Viewport?
Weld Modifier in Blender 2.8X and Rhino7?
Some lines were deleted in PDF import to Rhino in *(PANCAKE (byillusionwing)) and #Bug in Rhino 7 SR0 2020-4-21 (7.0.2011,)AND Rhino 6 SR26 2020-4-20 (Rhino 6, 6.26.20)
Push pull command
File Search Paths and RunPythonScript
No SubD type hint in Grasshopper GhPython
Rendering Challenge1!
ViewCaptureToClipboard-Monochrome Error
Choose curve at apparent intersection?
Hatch object including outline and solid background
Display order linked to layer order
Multiple mapping channels confusion
WIP Flair, cool but slow when textures and wish not show textures
BlendSrf problem Rhino 6 SR15
Custom mesh setting link broken
Hatch Print Color
NamedView causing delay in Rhino 6
Edit Blend Surface
Changing curve width in Rhino can leave GH curve width stuck
Rhino 7 ExtendSrf causes other problems
Feature request! Layout
Layouts manager - print more layouts
Why haven't you upgraded to v7?
Stack Layout/View Tabs FEATURE REQUEST
Clipping planes wish: visually and distinctively show collision
Flat python list errors with latest Rhino WIP version
Nudge only works once
Rhino 8 - Print Dialog - Layout Selection in large Layout Sets
Not a question but a development suggestion/request
💡 Feature Request: Layout Grouping or Folder Structure in Rhino
Feature Requests: Double Click into Group to Edit & Folders in Layouts
Rhino 7 Layout Panel
Add more print widths/advance settings
Read inserted block scale
Most effective method to extrude complex 2D pattern to 3D
Sub-d loosing with clipping plane/clipping plane gumball
Short Description fails to register with CustomObjects (RhinoCommon)
Macro for ReplaceBlock
Moving Layers up and down the list / Loosing Dialog Position
Bug: R8 Layer Move
Help! Can't log in to Rhino 7 WIP
Textfield display Block insertion point
How to define custom Annotation
How to? Embed Z coordinate usertext in a block
User Text Point Coordinate inside the Block
Dynamic Text Field inside a Block
"live" Z coordinate of block as text
Text displaying the z coordinate
Decimal zeros missing (PointCoordinate function)
Reference and bake Rhino groups
GlobalEdgeContinuity enhancements, replace EdgeContinuity
Variable %AppData% explorer name
Lens Length always becomes 50mm when I set the projection of the perspective view as parallel
Decals not showing in cycles (Raytraced) - Help
Refit trim - accuracy issues
Let DWG/DXF import plugin load UCS as new Cplanes
Wish - Non proportional viewport scaling
Gumball reposition only remembers single move with selection
Bug in "reflect" command
Trouble with picking surfaces
DevLoft failure
Dimension wording in dialog
rs.WindowPick is incredibly slow vs Rhino.WindowPick = instant
Incomplete information in Help topics
Clipping Section Drawings + Maintain Source Layers
NestedClippingDrawing doesn't quite follow Spacing & Width
Bug: Stop torturing us with FilletSrf Radius
My last 3 wishes. ...of this week. (make that 6 actually)
Decal Widget not visible (Rhino 8 WIP)
Refit trim - doesn't handle 2 trimmed edges
ChangeQueue.ApplyMaterialChanges is not called for some assignments
Changing object layers in WIP
Wish: extractPt to include textDots
Adjusted rail segments:in SubDSweep2 doesn't work for same value
Mesh selection causes Rhino.Runtime.DocumentCollectedException:
Volume for a subd
File Opening: V8 WIP
Please fix rs.JoinSurfaces for V8
History for self-intersecting curve offset bug
Rhino 8 WIP for MAC Crashes on Zoom Window Command
8 Bit grayscale images not loaded properly (Rhino 8 WIP)
How to un-stitch (un-weld) edges or vertices in SubD model?
Bright lines in printout of rendered view
Cycles blown out
Strange PBR behavior
Rhino 7 WIP - Export Settings - STL
Boolean unify what can be and ignore problems
Text has wrong/no kerning applied
Rhino.FileIO.File3dm: Looking for a possibility to read/write to/from a stream
Some Wishes
Edit polyline with curves in it
Rhino V7 still has this silly degree/control point behavior on polycurves
Selection Without ShiftKey
Denoiser issue
SubD extrude face FAILS with reflection plane
Boolean input selection bug (false duplicates)
Intersection Bug
Bug: Cycles light multiplies some times
WIP Material Display Issues
Split Isocurve sometimes removes face color
V7 missing "No environment" item in 360° Environment dropdowns
Failed to create manifest.yml with 'spec' command
Setting curve's print width bug
Hatch pattern display error
Renaming Named Positions and pressing delete
Exception iterating RhinoApp.ToolbarFiles in latest WIP
Layer color in Object Props dropdown
Adjusting Fractional Dimension Horizontal Number Spacing?
Preselection with -_SelLayer _Pick
No Relative coords in status bar Info pane
OrientonCrv
Selecting object shows isocurves of OTHER objects
BUG - Block edit window
Superscript in dimensions
GlobalEdgeContinuity: doesn't find matching edge
Near snap on surface edge?
Point editor alert / EdgeContinuity
Gumball memory
Splitted edge bug
InterpcrvOnSrf history on by default? This command is buggy
Turntable request
Potential Rhino 9 WIP Feature: Flair
Rhino BUG** Lasso command selects objects beyond the clipping plane limits
FilletEdge - DeleteInput broken
Layer states in Worksession
Surfacing... just a nightmare
Cadesign base - 3D Days Online
Can you create different details in Z direction
Draft Angle Analysis Component
Technical surfacing
V6 Zebra Wish
Are Worksession Layout Detail issue resolved in Rhino7?
ComboBox flicker in EMap Options
Worksession Questions
The lack of Tables/Schedules in Rhino 6+7+8 (WIP)
How to transfer Rhino 7 licence to Rhino 6?
Bug: Worksession does not save layer model/perViewport visibility
Rhino 9 WIP Toolbars duplicated
Explode block instances while keeping their original layers
Which format is compatible with Rhino?
How to import to layers instead of blocks?
Wishlist or do they exist?
Rhino 8 - SubD shape fitting with degree curve (continuous curvature)
Rearrange layers by dragging
Texture maps not being assigned from sub folders V6
BUG: ToSubD is losing mesh UV coordinates
Collapsing layers make Rhino 8 WIP Crash
In Plane Option for 3DFace
AutoCad Export DWG and DXF crashing all the time
V7 WIP Append - from edge crashing
UI stuff still moving
OSnaps do not stay put
New UI: Fuzzy icons
"Rhino WIP Missing Fonts" message shown when sending Open file command through COM
Rhino 8 User Interface Freeze Approaches
"BIG" BUG toolbars
V8 ScriptEditor python testing and bugs
Object Snap Culling Issue
Tools > Toolbar Layout dialog size
Toolbar Layout panel glitches
Weld subd cage?
Confused about some very basic SubD functions missing
DupEdge and DupFaceborder in SubD Flat Mode, other subD issues
Prioritization of McNeel work to have a good rendering workflow in a team. Using material libraries of realtime PBR shaders + render-engine specific shaders
Work-wrecking bug with mapped image paths being changed by Rhino
'Guid' parameter support of preselection
SubD output option in _Loft - a lot of testing, comments, suggestions
Referenced Block remains Selectable on locked layer
Breps Intersection Bug (WIP)
Using Linq in C# scripting component
Leader text mirrored bug
Far from origin
Problem with ExtractSubCrv
SubD Symmetry?
Some visualisation issues with SubD + some suggestions
Cutplane fails to traverse the object completely
Bridge command SubD
One More SubD Symmetry Request - Use case
ProjectToCPlane refusal
Brep.Split complete failure if one curve not on brep
Wish: Reflect with multi SubD selection
WISH: Prevent sublayers list from unfolding
Create file for 3d printing
SyncronizeRenderColors account for opacity in layer?
BUG Persistent Material Population After Undoing Block Instance Insertion
Tooltip Error Cascade Arrow Rhino 8 WIP
Line Scaling/Printing in Layout space issue
SpaceMouse not working in WIP
Impossible to use arrow keys in 'Segments' in 'Linetypes' dialog
MatchProperties Dialog buglet
Exports and imports using Rhino Compute
Gradient Hatch technical testing
Is Rhino Breaking My Geometry? Offset Lines Fail Parallel
Adjustable Curve Blend
Critical Rhino Bug: Chamfer/Connect + Join Corrupt Line Orientation
BUG: type conversion curve->surface corner type sharp
BUG WIP 8: Adjustable Curve Blend
BlendCrv: Numeric adjustment
Control Point Weight Color?
STEP import - missing lines
A few wishes for the pile (1- Control Points) [Ah, should these all be in Serengeti?]
Why does BlendCrv not always blend between picked positions?
Animating camera with parallel / isometric views
Gumball not reorienting itself to center of object after Boolean Union
3d view rotation flicker
UI: option for wider layer display
Feature Requests: Curves
Blend Curve 'Sliders' Request
Changing mesh wireframe color kills edge analysis dialog
Png in layout prints black when output is set to vector
Display BUG: CPlane Axes draw grid outline
ShowDir Bugs
DimAligned Shifting
It crashes when I do undo.Redo
Rhino 9 SR0 WIP: All Objects Disappear
Most recent WIP deleting all objects in an existing project
Point clouds and clipping planes
Script logic for setting up for UE4
What happened to the beautiful Command search box?
Inverted transparency in color picker
Import just one layout
User strings not retained in SumSurfaces after JoinBreps
Subd selection tools and vertex merge that I'd like to see implemented
Annotation style issue again?
Command options dialog and command window
I am trying to understand why i cannot join the final surfaces
RhinoCommon Replace Edge
Rhino Wip - Clipping plane and Make 2D problems
When Will Floating Command Prompt return to the Mac WIP...?
Failed to Save File - read only
Command Options Dialog Command Box Still Appearing
ExportAll crashes Rhino instantly when specific layout is selected
Mac - Interface still behind Windows
Creating meshes... Press Esc to cancel Creating meshes... Press Esc to cancel Creating meshes... Press Esc to cancel Creating meshes... Press Esc to cancel
Gumball extrude
Rhinoceros replacing AutoCAD
Hatch improvements
Bug: Non planar planar curve
Reordering layers
Layer woes
Weld command for subD and meshes based on a float distance
Some SubD WIP bugs/UX issues
Bug in contextual select objects
Wish: delete image linked directly from Missing Image Files dialog box
Text field date language
Entire model disappeared after editing block
WISH: Undo sorting of layers
Gumball with aligned directions + normal
Hatch select
Adding an optional panel for the colour picker
Copy/Paste of a Block Instance also caries Document User Text?
Document Usertex pasted with objects and imports
New Object Color On Layout Window
Rhino/PDF Symbols Mismatch
Create Grasshopper Component from AutoCAD LISP Routine
WIP won't start after first run on VM
Are there any G2 continuity limitations at special points?
Bug analysis?
Feature Request: SelVolumePipe`
Incorrect top view shadows
Rhino 8 Feature: GH1 Is Now More Than Just Geometry!
Mesh subselect when clippingplane ignores clippingplane
Can this be combined into a closed BREP?
SubD Toggle, one is enough (TAB)
Rhino crashing when trying to render
Surface Thickness Settings
UI flickers when clicking Osnaps
3Dconnexion mouse controls are reversed in WIP (compared to Rhino 6)
More preset print sizes for rhino pdf printer?
Rhino 8 Grasshopper Script Editor - Design Feedback
Print state
PlaneSurface constructor, unexpected behavior
V6 Object won't highlight allowing drag and drop materials from library
Trying to reproduce Rhino's native Sweep1 behavior with RhinoCommon
Wish list: Set bitmap texture from memory stream
PlugIn.CreatePreview called (apparently) unnecessarily
Named Selection & Worksessions
PNG alpha channel transparency not working
Wish: Add "ClearAnalysisMeshes" command
WISH (BUG): Hide control points when locking layer!
Odd object - mouse click subobject selection of a curve segment not working
Creating 2d surface from Rows x Cols controlpoints
Update dialog
MergeAllFaces crashes Rhino on simple object (file inside)
Something weird with keyboard input
Some thoughts and suggestions
Subd Challenge 2 - helmet
Ray Intersection - Getting the hit geometry
Make2D macro
Bug: Gumball not working with camera icon
SelBoundary to be independent of zoom
Selection priority of ghosted mode
RhinoCommon method broadcasting command line messages?
Bug: SelBoundary not working on some hatches
Custom object mesh triggers remesh even when no changes have been made
[FEEDBACK] Rhino 7: Right mouse button over Polar arrey repeat last polar array action
Rhino settings reset+Dims disappearing
Changing viewport render style wipes out seams during Unwrap
Surface transparent - bug
Some Wishes
Cap (no crease ) on Subd doesn't work for this object
Isolate causes Filter dialog to open
Wonky gizmo scaling
Problems with sub object selection, doesn't work in v7 but does in V6?
Rihno pdf problem
#Suggestion add all (Arc Option command) to Polyline
Refreshing Textures got slower & annoying
Lots of layout questions! how to align objects in separate details? how to insert breaks?
Grasshopper 2-Alpha available for testing
Offset Error
Feature: Add Sorting for Key and Value columns in UserTextAttributes window
Testing new QuadRemesher
Remove crease cannot work for this object
Bug Rhino7 Intersection.MeshMeshFast()
Mesh split for sneeze cfd not working
Wish: mid snap for meshes
Rhino BETA Feature: Document Section Styles
Arrgg! Blocks non-uniform scale. How do I revert to uniform?
Missing option from materials panel
Rhino Script Compiler for Rhino5, second Beta
SUBD merge faces annoyance
V6 Goal: True PDF Export
When Rhino unpacks textures to a new folder it OVERWRITES textures with same filenames
GetTextureFromUsage fails in V7 when built against V6 RhinoCommon
Blocks edit
Block edit and non-uniform scale
Rhino 7 Feature Text Formula Enhancement
Wish: _FilledEdge with double click selecting tangent edges
Rhino BETA Feature: Navisworks Export
Rhino BETA Feature: Improved Creation and Editing of Hatch Boundaries
Rhino BETA Feature: GH1 New Component : Value Picker
Annoying BUG with "Line normal to surface"
Where is Workspace Editor (toolbars/macro)
Edit Button Icon - background shows wrong color
Matching: Control Points visible in Preview
MatchSrf / MatchCrv, Show Points
When I enter the matchsrf command the control points disappear
Planar UV point layout on BlendSrf
Testing V8: unselect & save selection not working & crash w/shrinkwrap
Rhino BETA Feature: USD File I/O Improvements
Rhino BETA Feature: Create New HatchPattern Command
Rhino BETA Feature: New Hatch Management Panels
Blendsrf issue V6 vs V5
Select Name
Rhino BETA Feature: New GH1 Components for Texture Mapping
Cannot set mesh parameters in order to get only triangles faces
Suppress "Tolerance had to be doubled..."
Rhino BETA Feature: New GH1 Components for Textures
Rhino BETA Feature: New GH1 Components for Rendering Materials
Rhino 8 not exporting USD files
FilletSrf extra coarse display OpenGL vs. Direct3D
Wish: Multiple Hatch File Import Option
ExtrudeSubD faces vs edges
(Bug) FilletSrf - Selection point on extrusions
UI - Properties panel - Changing object layer seems really off
Bridge bug - face pre-selection
Exit command not working
Create pipe with wall thickness
V8 SectionTools Integrated
Wish: Smarter "Connect surfaces" tool
Wish: Displaymode shadow density, not only color
rs.WindowPick() randomly isn't "grabbing" some objects that completely fall into selection box and picks some that are completely out of it
PBR Material tutorial for Rhino 7 WIP
Keyboard shortcuts to command options
_Distance wish
SelName popup window cannot be resized
Bug: Command History not Scrolling to End
Multi-face extrude with different normals
ExtrudeSubD does not support DragMode View
Offest SubD Face based on Face's Normal
Wish: ExtrudeSubD please option along normal
Selection often ignoring z-depth checks
Gumball extrusion button with lofted surface
Joining curves makes a bad object
ObjectCaptureFromPhotos for RhinoWIP (Mac-only)
Status bar layer pane expansion
Block Name Conflicts with "-Insert"
Push Pull pre-selection
Scale to 0 using gumball handle not working
Rotate3D lacks self-awareness
More with SubD Tools
Make clusters in current document discoverable in 'Create..'
Scriptable Rotate around CPlane Z-Axis
Joining SubD vertices?
Stuttering rotations while moving cursor on viewport
Creating an empty box with Box(plane, BoundingBox.Empty)
Clipping Sections Bug offsetting background, and layer issues
Clipping Section no fills on blocks
Panel position and toolbar (color) bugs
Rhino WIP Toolbars
Toolbar Resizing - BUG?
Command Editor for Rhino for Mac not working
Rhino Panel File Explorer default view
AutoAlignCPlane Toggle for Alias?
Is there any reason why Block Manager can't be cycled by typing a letter as 'Insert' menu?
Selection Filters Buttons Bug
How to load geometry from linked block files?
ComputeVertexColors fails on this mesh
Rhino Render Crashing (Mac)
Layout User Text - Empty Value Deletes Key
Rhino 8 - What happend to the custom commands?
Bug: "Match Properties" destroys the object History
WIP (8) feedback
Feature request: Curvature graph on SUBD objects
Rotate View Around ObjectAtMouseCursor not stored
Rhino 8 feature: Surface Fillets
Even deeper dive into subd-
Interesting gumball feature?
Rhino 8 - Viewport Capture to File Issues List
Tiling bug using ViewCaptureToFile with parallel lines shading
WIP (8) feedback
New Gumball on control points
Bug report: ArcBlend may fail to close curves
Failed to save Rhino 6 file
Rhino 8 WIP issue with gradient hatch
Bug ? Sub-vertices selection on polysurface
Rhino 8 Drafting: Hatching and Vector Pen Display Mode
Display Mode Technical with lines dashed
Raft on Sea
Plane.IsValid bug?
How to draw curves adhered to complex curved surface?
V8 vs. V7 - Display Mode inconsistencies!
Marker isn't there
Offset render mesh files
"BIG" BUG toolbars
Is Rhinoscript Method file installed with WIP 8?
Selection bug? offset to the left and up
Rhino camera view problem
File Size!
Using the Isolate command bring up the Selection Filter
Mesh CreateFromCurveExtrusion bug
Baking extrusion objects?
All preferences wiped out -- 8.0.23220.12306, 2023-08-08
Layout bug in Rhino 7.30
Can Grasshopper for Rhino 6 works on SubD and Extrusion?
Single Color Texture bug/wish
Isolate command invokes the Selection Filters window
Delete hatch from the settings panel
Text Object window in Rhino 6
PointDeviation - Points from lines/polylines needed
FBX material issues
Rhino BETA Feature: Instant Aliases (hot keys)
Text preview too large compared to the rest of UI
Document Properties dialog box does not include document file name and location
Offline help file for Rhino 8 WIP
Disable enter repeat command on right mouse button
Edit text and restore CPlane request
Bug report: ArcBlend is not able to create lines
Rhino 8 WIP Transforming geometry is 10X slower than Rhino 7
Feature Request - Mac - Panels: Named CPlanes enhancement
TAB key disable missing in V8
Rhino 8 WIP Constraints not working
V8 Mac - Spotlight not working in render
Testing new v8 stuff
Wish: Clipping Box
Is there a Section Box to rhino?
Support for clipping boxes / shapes
Clipping Box Macro
Loading worksession files is slow
Draw3dtext line breaks bug
ExtrudeCrvTapered method on roof creation
Filter toolbar shows chevron
Osnap chevron
Bump textures not rendering at all
Selection filter - I don't want the popup
Blocks + Groups
Selection filters not working
[Bug or Mistake?] Is FlowAlongSrf supposed to be exact for cylinders?
Spellcheck request - Rhino 9
Spell check....?
Show Named View Widget
Regression: Toolbar/Panel Border Thickness
When I use mirror to copy some faces, the inside becomes the outside
Dot print preview Quantum leaps
How to use vb.net to control the display checkbox?
Moving files between Mac and PC Rhino users
Rhino showing "Please Wait… Updating toolbars” splash at start
Setting up a linked .rui... :exploding_head:
RUI files and UI setup issues
Button/tab bars WERE intuitive, as in past-tense
Feature Request: IntersectTwoSets
Problem with UVmapping
Packed Faces options in Rhinocommon and/or for regular polysurfaces
Is it possible to access the custom render mesh through the command line?
Rhino 9 WIP | Bug | Clipping drawing creation
Parsing content of a 3dm file - identify large chunks
Mesh IsPointInside bug
Rhino WIP: Down Arrow Fails When Moving Second-to-Last Layer to Bottom
Draw Order: Hatch Boundary broken?
Wish: Hatch boundary color/style
Blocks + Groups
Hatch Boundary Color
Taper spoiling mesh
BUG (?): Surface back face display colour
Can't edit subd vertices using python
subD control Points in Grasshopper
Big Feature Request - Substitute Reference Objects for Reference Locations
Raytrace-like mirror plane tool in Rhino 7?
BUG🐛: Gumball temp graphics persist after rotation
Feature Request–Transfer current measurement at Cursor into command
Layers match properties does not match section style
Grouping, Sorting, and Filtering
Problem with new C# script new editor - copy/pasted code doesn't work
Ghosted - closed and open polysurface look different
Render colors on Mac
Query Model Objects - Brep problems and Surface not recognized as surface
Bug - FilletCorners transforms lines in degree 2 curves
New Rhino update will not open files
Rhino WIP Command Bar Title and background color issue
How can I change Rhino command line window font size and color?
Rhino 9 WIP freezes after imported pdf file (just 4 pages)
BUG: Wrong volume fx
Rhino BETA Feature: Drag, Rotate, Create: Interactive Viewport Widgets
Audit3dmFile with Browse option crashes/closes V9 WIP 2025-12-09
Rhino 8 Feature: ScriptEditor (CPython, CSharp)
Rhino WIP Crashing? Do you get the crash report dialog?
WIP Check Now not working
Very unstable
Can't filletedge
What is the chance of Rhino getting a White/Black (Model/Paper) layer color like AutoCad?
Bug - Gumball scale handle remains visible after scale is set to 0
Make2D error using view created from ClippingSections
Rhino 9 wip update server down?
WIP download - multi-step, not entirely obvious process
Unable to update WIP
Tuning colors
Wish: Make2d to simplify the curves
(Paper-cut) Multiple Object Snaps
CUT, COPY, PASTE, Please!
Rhino BETA Feature: PushPull Multiface Support
Struggling with UVs and UDIMs in Rhino 8/Rhino 9
OpenGL vs DirectX performance with point clouds
Idea/Request: Match UV maps scale across multiple objects
State of Rhino on Apple Silicon really that poor?
Status Bar - Display Object Type
Rebuild command (select master curve ) the absence of (maximum deviation)
Wish: Clipping plane - cap clipped objects
make2D ignores construction plane
WISH: Trim Curves by Brush (like an Eraser)
Custom mapped object. UVs lost when moving squished piece
Couple of worksession bugs - Make2D and text
One day sun animation - technical viewport
The horror the horror of exporting to pdf and illustrator
Can you make the “Volume” function display like a dimension?
Retrieve Values from Text Fields
Ghost forms behind my drawing in Rhino WIP mac
CurvatureAnalysis - Colors reversed in key scale
GhPython/RhinoCommon Decal Placement
[Feedback] SubD Osnap
Rhino 8 - Exclude Layer from Clipping Plane
Opening Grasshopper File Resets Rhino to Factory Settings?
Rhino for Mac (WIP): Goodbye Mono, Hello .NET 6
Latest WIP crashes on windows 10
Continue curve command - unexpected behavior
Make2d splitting lines.....?
Make2D via a python script keeps crashing Rhino
WIP: connections command
Contour - Does not execute properly
Show name of current CPlane?
RH8 - Popup - size setting
Offset srf not working well
Clipping Drawings - Unable to show hatches and curves
Help with drafting
Should I get an email when someone replies to a topic I'm watching
Bug - BlockEdit Linked block renames nested blocks - Rhino 7
Insert creates UUID behind blockname
Removing Arrow Decoration embedded in BREP
Set Rotate Axis to line
Move UVN Smooth bug
Secondary Osnaps not selectable / working
Rhino BETA Feature: Direct Editing of Clipping Drawings
R9(WIP) - Annotation Leader (bugs)
ChamferSrf request link distance option
Latest V9 Crash With Document user text panel
Clipping section drawings - Section Style - Boundary / Print Color Bug
Rhino urgently needs these tools!
Extend surface by negative value not working on simple surface R7(SR13)
Wirecut difference
Request: Fin, Ribbon, RibbonOffset Both sides option
Rhino 8 UI issues: panel background styling
Please Add FillSrf to Rhino Common C# Api
BUG: ‘-Insert’ is missing command line options
Clipping views are force-updating themselves into parallel projection
Glass looks dark in rendered mode
WISH/BUG: Replace missing linked block file
Tools - Options - Aliases: impossible to expand the last column width
Gear and Sidebar Icons Tweaks
Direct3D BUG Clipping Plane Display Fades Out
New Layer panel wish
Problem Files
Rhino displacement tool
Wish - Improved Layer filter UI
Macroing Draft Angle Analysis
Wish: Command History feedback for Delete
Hide Tangent Edges
Layouts button at bottom bar undocks Layouts panel from container
SketchUp Import Issue - Textures and File Size
Importing SketchUp - any progress with texture mapping issues?
Select edges to untrim --> untrim
Feature Request: Snaps
Mac vs Windows UI inconsistencies
SetTurntableAnimation doesn't remember viewport
MRU toolbar in the WIP (some observations)
CalcRPN ... Roll or Swap Memory Stack (question/request)
Increase diameter of multiple spheres simultaneously
SplitRefitSurface Bug - Can't cancel the command
Nudge Is Broken
Blocks + Groups
Rebuild (New) - Control Point Display - Need to turn off
Global Edge Continuity: hairs scale changes unexpectedly
Block name conflicts in command line not working for nested blocks
Rhino 8 - Linked Blocks not showing up?
Rhino 7 Subdivision Surface Project
Delete with BACKSPACE in WIP9
Photo Textures Directly in .3dm Files Reliably?
Squish: Requests for enhancement and bugs in existing Squish command
Bug Squish back WIP9
Red SubD reflect line is puzzling me
Rhino 6 transparent background print
Improvement suggestion about printing
Print a png with a transparent background (Rhino 8)
V8 Popup toolbar doesn't keep its size
RhinoWIP for V9 minimum macOS Version
Polyline artefacts in Direct3D
WIP 9 - Icon mouse over description is behind the dialogue
Rhino BETA feature: Emap dialog changes
Rebuild WIP: Point Count can be set too low for degree in Tolerance mode
Button Editor always crashes rhino
Rhino BETA Feature: MatchSubD
Patch: UV indicator
[Bug] Offset creates additional curve segments?
BUG'o'saurus - curve offset shifts the order of the segments
Point-On-BRep selection
Rename "RunPythonScript" in Undo
Toolbars... from bad to worse. Will it ever get right?
BUG: "Align to control polygon" mode is not reliable
Direct3D background changes
Osnap and Filter checkboxes : state buttons instead of checkboxes
Rhino WIP Feature: Grasshopper 2 Script Components
Can we have an explode block component?
Wish: Smart object selection
Mesh command doesn't obey selected layer
Panton Chair - SubD Model Attempt
SubD Challenge 9! Robot Fish! (wait, what?! )
Save on exit / semi-bug
SubD Edits of planar-face-object
SubD Friendly Curve
New Patch requires edge constraints? Regression?
[bug] Rhino.UI.Dialogs.ShowMessage shows two dialogs for one call
Layer Panel redesign?
Invert sub-object selection or SelBoundary with Sub-objects
Wish: remember the last Block Name Conflict choice
Removing tangent edges using ClippingDrawings command in Rhino 8
Proposal: dynamic gumball + curvature graph (and set value)
WIP - import a point cloud - it's invisible!
Photo come out black
Cannot 'Distance' Imperial units when Model is in Metric
Rhino Meme Chat Gallery
Show Distance Channel crash
Rhino WIP import settings?
Curve.RebuildElmo(.....); Api c# return null!
Print to PDF does not match the viewport's appearance at all?
Scripting, Type Hint, Rhino 8
Offset polysurface went wrong?
C#/Python Editor Type Hints on Mac
Global Edge Continuity - Release Candidate now on packagemanager
Block editing visual glitches in Shaded mode
Rhino 8.2: Bug in Push Pull?
PushPull breaks all history
Wish: Alpha for Text Mask
Rhino 8 - Offset closed curve - Loose=Yes issue
How to offset curve with Loose Yes but with trim the intersect on Rhino6
Bug with curve offset
RhinoEtoApp.MainWindow.SizeChanged has no effect!
Help with creating a window following Rhino window
RhinoEtoApp.MainWindow.Screen fails on Mac
Events for Rhino Window resize/move
Rhino 8 UI layer panel issues
Command prompt buttons not consistent
Latest Rhino Beta has screwed my mouse control
Rgt Click stopped working (Beta Mac)
Layer Panel: Feature or Flaw?
R9 beta crash with python script
Totally weird toolbar phenomenon
Wish: _boss stop
テキストの寸法データが分解できない
Make 2D and Text
Popup toolbar mouse button release execution broken (again)
Rhino BETA Feature: UV Editing Improvements
EvaluatePt with label wish
Rhino 8, Object properties panel, field size
Properties window - advanced controls
How to wrap text?
Fit Ellipse Through Points
How to disable .dxfbak files
ChangeLayer crashes WIP
Lazy viewport dragging lines
Patch Surface from Mesh
Rhino 8 Text Object Group Bug
Rhino STEP export converts straight lines to curves
Rhino BETA Feature: Group missing assets
Is there a repeat last move command?
Is cplane turned on after software start?
CrvDeviation accuracy
Weird geometry problem - causing a hard time
Worksession - Object Display Mode Changed - Bug
Can't zoom when object is selected, bug
Issue following the fix for commit RH-95187
New FlattenLayout command (work in progress). Feedback requested
Bug: Script Editor Search Whole Word Filter
Keyboard Shortcuts for Display Modes Not working in latest WIP
Accessing Lowest Level (Child) of Nested Blocks-STEP File Import
Rhino 8 loading incompatible Azure.Core assembly version for plugin
Rhino BETA Feature: Gumball Improvements
Grasshopper Texture Mapping Issues
(Wish) Gumball Location, _GumballRelocate with different Options
Simple UV mapping bug
Worksession - Copy Objects To Layer
Dimension without any line
Worksession Bug - Opening RWS file can close Rhino
Nudging with history problem
Section: Doesn't Recognize Circle and/or Arc for Rad and Dia Dimensioning
ZoomSelected acts differently on Blocks
Merge layers from import file autocad to rhino
[python] how to properly reconstruct layer hierarchy after re-importing from DWG?
Wish: recreate sublayers by DWG importer
V8 improvement / bug - PushPull and Inset on multisrfs
This new update installs a Tsjech (?) version instead of English
Worksession Bug: Opening a .rws file saved without a main .3dm file
ZebraOff crashes Rhino
Why am I allowed to rotate the Top view?
Python3 in Beta8 - CPython 3.9 near end-of-life
Toolbar button editor - warning message when no changes made
Rhino 8: Texture Mapping with the UV Editor (Unwrap)
Leaders - Add / Delete Control Points
My toolbars and display layout in rhino beta 8 for mac
Mapping Material Behaving strangely
Physically Based Displacement hard to use
Surface Filleting across Tangent Faces
Rhino Python 3.10 - Please support it!
Rhino BETA Feature: SectionTools Enhancements
Suggestion: Suspend Groups
Bug: blank properties dialog box
Close a file without saving with scripting
Support for AutoCAD Complex Linetypes (Batting, GAS_LINE) in Rhino
Rhino 9 Wish List
Layer states restoration failure
Direct3D glitches on rendered mode
(Wish/Question) PointDeviation Update/History
Curious Rh8 in-Block interactions with hidden geometry
[Rhino 9 Beta] MMB pop-up triggers on button release
Rhino Beta PopUp Menu on MacBookPro has a bug
Bug - "Delete Object" on exiting block edit
V-Ray 7.20 plugin fails to load in Rhino 9 WIP (9.0.25308)
Bug: Layout detail scale locked to mm - auto scale label wrong
Rhino BETA Feature: Export Block Attributes
Rhino curve/surface anatomy
Rhino Eating my Hard Drive Space
"solid point" nudging issue
What aspects of USD are or will be supported?
Why can’t Rhino windows open *.usd…?
PDF import catastrophy
Rhino V8 - Text editing bug?
Section Styles - Section Styles Dialog
Gumball inconsistency using shift to invert value
Rhino9 WIP e problem with the team Command: -_SelLayer
V9 WIP bug - Clipping plane issue selecting points with double click
X-Line for Rhino
Loopy line types
RhinoPageView on a headless document
Rebuild/ ELMO - Missing input
AddGuide Visibility?
Bugs WIP 02.03
Bug - Text settings returns incorrect text height
Text aligning to a curve
Linetypes with symbols in it
Linetype with Multiple Lines?
SUGGESTION: Better linetypes + Hatches
Infinite Lines - Guide Lines Beta v6
Guides don't display after they are created
Rhino 8 Feature: Linetype Enhancements
Text Entity outputs Null Text Settings
Text on curve
Line types - Break lines?
V6 wish - 2D Linetypes i.e. batting
Custom Linetype with Text
Linestyle help
Request for Expanded Line Type Options in Rhino
Symbol (Block) Linetypes
Blocks + Groups
Break lines for 2d drafting
UV editor - object too tiny
Texture mapping unwrapping
Invisible text slider color in dark mode
SubD UVN points movement issue
Rotating diameter dimension in RH7 vs RH6
Latest V9 BETA. Draft angle analysis issue
[BUG R9] UVs not working in custom display mode
RhinoCommon Mesh Face/NGon enumeration and count
RH Beta - Hatch points cannot be deleted
Clipping Sections
Bug: Fit Text Alignment in Dimension
Bug: Arrow Direction
RC Attach files in Worksession
OSnaps buttons are clipped in 9.0.26181
Layer states bug
"Preparing material for first time use"
Intersect with meshes and general mesh rant (Rhino 8)
Rhino 8 Leader not adjusting in Layouts
Edit radial dimension points
R9 BUG - Procedural textures issues
Curve Vanishes After Editing Control Points
Sub-D loft not working (but works on same model in 8)
LoftSubD / Sweeps not working
UnrollSrfUV Questions
Mouse‑over effects in properties irregular
RhinoCommon API access for WireCut
Feature request: add mesh export "quality" for '.glb' (not just .obj)
Make 2d > third angle projection
SaveSelection takes too long
XYZ handles on lights
New Osnap/Filter panel
Tabulator and Shift keys don't behave like in RH8
Hatch-Rectangle selection
Feature request: Snap to meshes toggle
Bug: Fillet edge changes the display mode
Problem displaying long macros in ”mouse -> screen edges”
ListBox images not showing in v9 beta
Rhino 8 - Fuzzy Autocomplete not working
Rhino 6 documentation bugs
Rhino WIP (9) Can't import containers (RHC) from rhino 8
How do I migrate a Rhino8 container to Rhino9?
Rhino WIP - Trim
Rhino Title Block Tutorial and FAQ
BUG: Nudge step change via command/macro fails
Command line glitches
(Wish) Distribute - more Love please
Rhino V9 Issue. Can't switch Display mode during Fillet Surface operation
Block Manager - How To Get Viewport "Thumbnail" For Use In UI Elsewhere?
Command autocompletion is confusing
RhinoCommon: Loft with Tangency
Bug report : Nudge works only one time
Command prompt buttons cut off
Bug: random Boole
E57 Point Cloud Import Without Normals
VisualAnalysisMode Draw-Methods vs UpdateVertexColors
Tooltips on Mac OS need to be checked
Surface Curvature Analysis
Bug ArrayCrv
Wish: multiple selection for _untrim
Request: "SelectAllAndIMeanAll"
Grasshopper component search click not working
Patch with point only input: Untrimmed and MultiBlend
Rhino 9 Beta: MeshBooleanSplit regression with coincident faces
OBJ export options dialog has VERY big buttons
Options Update Wish: Check now always active
WIP Bug: Gumball smooth setting
Double click on UndoMultiple and RedoMultiple
ToolTips in Rhino 9 BETA (15-09-2026) for Orbit
Blocked Out
[Rhino 9 Beta] First selected curve in Blend isn't yellow
MeshSplit problem
Unable to copy text from layout to model space
Rotate Copy=Yes > Relative angle
Add Highlighting to BlendCrv PickPoint
Missing toolbars in latest BETA (9.0.26223.12303, 2026-08-11)
[Bug] Curve offset fails
Wish: -SelLayer Current
What command select all objects on layer the selected object is on?
[R8 issues] Scaling issues with Dimension Annotation inside Scaled Blocks
ScriptEditor call stack: what is the repeating doc(self)?
Snapshots Crashing The File
Brep.JoinBreps Mutates its input
Rhino Beta - Layouts: hidden object are visible in copy of detail
Rhino Questions (PrintDisplay, MatchProperties)
"Selected object count" does not work sometimes
Rhino8 and Picture sees image size not as entered
Grasshopper gumbal not working in WIP9
UV Editor: Save to Bitmap Request
Synchronize Render Colors
REQUEST. Faster Thumbnails for Named Views (or no thumbnails option)
Boundary Surface fails to create the surface within the closed curve?
ArrayLinear - Fill option request
ArrayLinear — Can Second Point be the End of the Array?
Select All Objects in Layer of Selected Object?
Can Rhino handle mesh without being very slow?
Rhino beta Not Responding when adding to group
Rhino 9 Beta Direct3D feedback
Small Dims Extension
Feature Request: Zoom Selected
Dimension Text Placement when outside Dimension Line
Wish: VerticalFaces=1 for Cylinder, Cone, and TruncatedCone
Command fires when releasing the mouse on a button mid-drag
SUGGESTION: Curvature Graph UX
Snapping highlight is too thick
Curvature graph wishes
Problem with Offset command
Rhino 8 OffsetSrf Failing
Command prompt history doesn't show messages anymore during startup?
3MF file opens with missing components in BETA
Is there a command to drop objects bases down to C plane en masse?
Rhino BETA Feature: Inset Group Mode
More Fillet Issues V8 & V9 WIP
Get minimum radius curvature from a surface using rhino python script
R9 BUG - Text field copy/paste changes font
Problems with matching hatches, rhino8
-SelLayer with Current option - confusing result
Technical view drops lines in output
Rhino BETA - OptionsImport Problem
Bug or not? Latest BETA's Zebra analysis has noticeably more aliasing
Feature Request: Rotate from Center Without Gumball
Rhino BETA Feature: Content Viewer in Grasshopper 1
Script Editor cast to No Type Hint
Bug: Orient needs 2nd confirmation
ScriptComponent Autocomplete not working after Run
OpenGL and Direct3D in latest BETA are drastically different than before
C# /Script auto gen doesn't handle comments
Bug: 'NoEcho' does not work in rhino9 on aliases on some commands
Curve not updating in grasshopper
R8 GH Script component - safety enhancement request
Feature Suggestions: select SubD faces by surface packing color
Rhino 9 Plugin load failing Mesh.FileHole
Meshtrim, MeshSplit, MeshBooleanUnion etc. not working correctly; bug
One-view bug
Object snaps - on-screen point indication missing before pick
MAC: Bad viewport performance after editing
Bug Paste ImageFile
ArrayPolar Z distance problem
BUG: Massive lag when I try to open the Gumball options
Some UI colors no longer restore to their defaults
Distribute improvement: Can we have it working for 2 objects as well?
Issue with Rhino.Geometry.Mesh.IsPointInside()
Rhino 9 WIP hatch pattern width does not change
Rhino BETA Feature: Points and Tangents for Clipping Drawings
Blend layer colors
Rhino 8 Popup Windows Size Resetting
SVG import bug
Units problem with cameras
What is Eto?
[BUG] - Double-clicking the 'Layer' column head broken?
Clipping Sections - Layer Control with Linked Blocks
Nudge direction
Why does Rhino have SubD-friendly curves instead of SubD Curves?
Saving protocol in Rhino Beta on Mac is screwy
.NETCore plugin loader inconsistencies
ShadeSelected is NOT supported by the new Concept DisplayMode
Bug: Clicking a dialog's close button can trigger a panel button
Bug: Loss of keyboard input after double-click in Layer panel
Boolean Difference fails in grasshopper but works in rhino
URL in properties panel cause extreme slow-down!
BETA - EditPythonScript
Request for Cameras again
Request for Bug Fix in Continuous Patch Component
Line and curve objects in Technical dispaly mode
BUG: section drawing generate extra lines
Issue forcing custom OpenCV version in Python3
Rhino BETA Feature: Patch re-implemented
Rhino 9 - Linetype pattern extremely slow + array bug
Mesh Booleans Issues
Blurry icons
Bug: CurveLength annotation function
(display bug) BlendCrv Panel frontmost on entire system
FlatShade Command Not Working in Rhino 9 Beta
Monochrome DisplayMode show visible tint/color on glass objects
Force cage to use XYZ instead of UV?
[[XX]] Attribute text fraction error
BUG - stacking fractions misaligned
Template files - Annotation styles - too many decimals in text height
Rh8/WIP bug - Ordinate dimension does not change style
Squish and SquishBack failure
Rhino V9 WIP (April 1st 2024)
Why does raytraced take so much longer on Mac?
Linetype Scale in CustomGetPoint DynamicDraw() Event
Intersect / trim Problem (bug ?)
SetObjectDisplayMode not working in Rhino WIP
V8 package manager issue
Grasshopper in Rhino 8 WIP - Extrude Component Doesn't Work
Lag when selecting multiple objects Rhino 8 WIP
Consistent performance degradation - must be restarted frequently
Rhinos uses 100 % cpu constantly
Python 2.7.8 library
Current RhinoWIP Very Slow
Isocurve density and toggle switch
How to show/hide isocurves?
RH8: Mesh color display issue with Metal
Marker symbol
Clipping plane does not clip intersection lines in Technical display mode
Objects made transparent in Rhino 8 Mac
BUG. Bounding box takes into account imaginary block insertion point
BUG - changespace does not respect text orientation
Icons get better
Rhino 8 WIP Features
InterpCrvOnSrf closed curve editing
Icons get better
Icons get better
Command line maths (again)
RhinoScript user interface method wishes & bugs
Unwrapping AsRigidAsPossible and Symmetry
Physically based normal displacement UI request
Rhino8 Rhinocode can't use pandas
Matplotlib cannot generate figures
Matplotlib in Rhino8
Script Editor Python 3.9.10 initialization fails
New drafting symbols, Title block sheet count
Local PyPi packages
Rhino 8 WIP Feature: Constraints
RemovePerFaceColors right mouse button command
Custom UV texture misalignment
Template for custom size pdf?
Display glitch with TestMetal
New UI: Add missing panels to the panels menu (Osnaps, Selection filters)
