Hi @Asterisk and all,
Here is an update.
RH-52539 Print color variation between blocks and exploded blocks
This is fixed as of Version 6 WIP (6.16.19154.08024, 2019-06-03) or later.
You will need to set your Options -> Updates to Release Candidate to get access to it.
In review:
- Objects (either blocked or individual) preview and print correctly with Vector and Print color settings.
- Important to note the Print Color is only for 2D objects like, curves, annotations, hatch.
- A surface in shaded mode will be shade in the Display Color, not the Print Color.
- But the surface edge curves and isocurves will print in the Print color and Print Width set by object or by layer
Also RH-50656 Control for the Dimension Line When Arrows Are Placed on Outside is also fixed for Rhino 7. Rhino 7 WIP has this new dimension line feature to control the line between the arrows as explained here. Any user that has Rhino 6, can download and use the Serengetti (work in progress) release.
Let me know if I mixed anything up here.
We can work though it again.
Sincerely,
Mary Ann Fugier
