Hi! I recently installed a rhino update and am no longer able to use Rhino 7. I have a valid Rhino 6 Educational license, but now when I try to log into Rhino 7 WIP I get this error:
This product only supports Core hour billing on this device.
I get the same error logging in with a team NFR license.
I’m running this on my macbook pro laptop running bootcamp with windows 10 pro — not using any strange virtual machine or windows server configuration.
theoutside
(Kyle Houchens - McNeel and Assoc. )
#2
we had an odd install error yesterday that appears to have been fixed.
please try a new download and uninstall old / reinstall new from here-
It’s neither here nor there, but for what it’s worth, rhino runs great on my machine for my purposes. I’m not building GB+ models, I’m using grasshopper and writing plugins. (though I do frequently handle significant amounts of geometry without much trouble). My Rhino 6 wasn’t updated because I basically exclusively use the 7 WIP.
Repairing the install did not fix the issue. @brian?
theoutside
#7
Ok, good to know.
call Tech support and Let’s take a look at what is going on… something weird is afoot.
tech is open 8-12 and 1-5 (closed for lunch) m-f PST.
@andheum any chance I can get temporary remote access to your machine? This is a bug in the code that detects whether you’re running Windows Server or Windows Desktop. Tech support won’t be able to help you
I’ve got a meeting for the next couple hours; after that I can jump in and help. I’ll send you an email…
OK, after poking around a little bit, it turns out that @andheum had configured the CloudZooPlainText setting in advanced options in order to configure compute. Disabling that setting by editing the file "C:\Users\[your-username]\AppData\Roaming\McNeel\Rhinoceros\7.0\settings\settings-Scheme__Default.xml" to remove the key fixed it.
