Rhino Service Release Candidates
Service Releases fix bugs, improve stability, and add SDK features for programmers. We will release Service Release Candidates frequently so you can give feedback. You must have a valid license for Rhino in order to get Service Release Candidate builds. BETA releases will not update to release candidates.
To subscribe to Service Release Candidates, follow the platform-specific instructions below.
Rhino for Windows
  1. Start Rhino
  2. From the Tools menu, click Options
  3. In the Options dialog box, click Updates and Statistics
  4. From the Update Frequency drop-down box, select Service Release Candidate
  5. Click OK
Rhino for Mac
  1. Launch Rhino for Mac.
  2. Navigate to Rhino > Settings > General
  3. In the Updates section, from the Update Frequency drop-down box, select Service Release Candidate
  4. Click Check Now
Please report any problems with Rhino in this forum.
Dots per inch, Printing
Issue exporting text from Rhino to AutoCAD
RhinoDotNetCrash
[v6] No colors for Point Clouds?
Group bug, added everything into one group
Modify Display Mode Surface Edge Thickness
Display Text object from Cluster
Move face to an inward point (with normal constrain) moves the face to the opposite direction
Rhino 7 Subdivision Surface Project
GHPython Editor Design Feedback
[RhinoCommon] CommitChanges will revert a custom mesh object to normal mesh object
Export textured mesh files to obj
Problem with RhinoCommon GetSubObjects
[RhinoCommon] CustomMeshObject - how to use RecordHistory?
Bug Report: Colored Dots Linetype curve prints black
FBX export failure (light)
Renaming Objects with Rhino3dmIO
Holomark 2 Released!
Isolate gets me dollars
Getting the viewport clicked in via mousecallback
ChangeSpace and blocks?
Bogue rhino script
Rhino 7 Service Release Candidate Available
Rhino 6 SR1 Available
Rhino 8 Service Release Candidate Available
Layer name sort order
V6 Options>Files Allow copy/paste to V4?
LayerTableEvent when deleting a layer
DrawSprite WorldLocation
Rhino 6 bug - focal blur
mesh.GetConnectedVertices problem
Rhino 6 Performances Issues
I've upgraded my license for Rhino 6 but keep running eval version
Rhino 6 SR5 Release Candidate 1 Available
Last used printer not remembered
rs.ComboListBox broken?
Subtraction component changes tree structure
Enhancement request for the recent files tiles
RhinoCommon: Sorting of curves in HiddenLineDrawing
RS OpenFileNames returns nothing, can not select multiple files
Rhino.UI.OpenFileDialog.ShowOpenDialog with MultiSelect=True not working
[RhinoCommon] SaveFileDialog does not handle Filter correctly
Complex number multiplication error in GH R6.4 SR4 and 7WIP
Minimum Leader Length
Why some materials don't preview on rendered mode in RH6?
Dialogs.ShowListBox does not consider the selected item
Permanently turn off annotation scaling & history warnings
GH Pull curve to surface is a PITA
Rhino_Script won't load
Graph Mapper grasshopper 6 conic
Rhino 6 bugs
Missing Text saving V6 back to V5
Bug Copy and Paste in Blocks
Display Optimizations in 6.17
PDF line weight became heavy after Rhino 6 update to SR17 (6.17.19189.16411, 8/07/2019)
Rhino 6 SR20 Release Candidate Now Available
Bug: PropertyListBox
Rhinocommon DisplayMode Change Event
_SeBox feature improvement
What rhino commands do you use on a regular basis and think others don't know about?
Rhino 6 Service Release 18 Release Candidate Available
Bug? of Rhino6 Mac beta(Reading STL file)
Can you help? Duplicated materials instead of shared
Match > Curve to Surface - Should it work more like BlendCrv?
I can't use FilePdf.DrawPolyline
MoveFace and MoveEdge Block
How to optimise GHPython OBJ export?
Scroll bar, accept, and cancel in V6's Block Edit dialog box
Bad STEP import V6 correct V5!
Can't run v6, retail or beta. Error message states "VCRUNTIME140.dll is missing"
Control points/polygon: how to see it through a surface?
How to see control-points/polygons properly when surface modelling?
SVG Icon Editor issues
Possible bug with BooleanDifference method
Redraw and Layers panel
Materials ID in Collada export
Rhino 6 SR4 Release Candidate Available
Bug in rs.ExplodeMeshes
Timer Component Bug: Exception "Scheduled solution must have a delay of at least 0ms"
Texture mesh display issues
Searching in the V6 Python editor help
UVW map exporting to FBX
Cycles - Edges bleeding
Rhino 6 Windows - problem importing some 3ds models
V6 Bug: Changing current Layer is too slow
V6 Text mask as background not working
Gumball not moving Ghosted Block object in one view and disappearing like ghosts
V6 Bug: coerce3dpoint
Rhino 6: _BlendCrv not joining edges anymore like in Rhino 5
Sort Annotation Styles
Rhino 6 / Dimension Problems
R6 Bug: extract mesh part
How to get the source of a referenced object?
Mesher bug - per object mesh doesn't respect values defined in template
Dimension history bug
Mesh UV export problem
Rhino 6 bug - ShowEdges command does not work in Rendered display mode
Placeholder Material
Spurious warning message when running a modified script
Rhino 6 SR3 Released
How edit materials of linked blocks in the assembly file?
rs.SurfaceEvaluate, when derivative=0 does not work
TextTag problem
Text command not working in V6
Rhino 6 several bugs
Text Command Bug
PDF Printing Troubles
Rhino 6 SR14 Release Candidate Available
RS: ViewDisplayModeProperty settings don't last
Leaderbuggy
STEP file imports but geometry is distorted
Layout Technical view sometimes includes stray curves from unselected objects
ReEdit: More issues- Draworder when PDF print
Rhino 6 Service Release 21 Release Candidate Available
Rhino 6.19 Release Candidate 1 Available
Vertical dimension orientation not consistent
Block Editing problem
Printing shaded views - surface edges color incorrect
Consistent Populate Geometry Crash
Document User Text "Date Modified" Broken?
V6 Text Command
SmartTrack in V6
Brep.ClosestPoint strange result
Text height doesn’t remember last input
Linear dimensions in Rhino 6
Unit conversion broke changed? Vb scripts no longer work
Latest update usertext doesn't work!
Cycles Shader Node UV is flipped
SKP import missing materials
Text modifying latest update
Rhino 6 and WIP load nothing from a 42Mb sldprt file
Importing Solidworks 2019 files :-(
SolidWorks import problem
Rhino Crashes every time I try to use a clipping plane
R6 crashes when editing anno style name
Technical display: Silhouettes fail in orthographic view
Double clicking on text over hatch
Rhino 6 Service Release 22 Release Candidate Available
Ground plane texture problem
Rhino 6 Service Release 31 Release Candidate Available
Problem with printing trimmed pictures
Unroller misbehaving unpredictably
Two easy view questions
Updating linked block resets Annotation Scaling
Bug - Automatic spell checker in Text properties freeze cpu
"Text" is extremely slow
Rhino6 dimensions strange behavior when stretched
Rhino.AddAlignedDimension doesn't use Anno Style
Surfaces in blocks print differently than on their own?
Export Pdf with controllable point object size
Rhino 6.14 still clipping plane ignores blocks?
Rhino 6: Solids in Blocks do not shade Fills
Layer name looses focus
Rebuild Curve causes Rhino 6 to crash in new SR
Help: Rhino.Geometry.Mesh.CreatePatch() questions
Rhino6 NurbsCurve Weights Bug?
Joining Meshes became super slow in recent V6 builds : (
EtoCollapsibleSection crashes Rhino
Problem adding new mesh to document
Rhino 6: 3DMBAK option off, but still 3DMBAK files
Rhino 6 for Windows SR 16 Release Candidate Available
Show Zebra Stripes During Dynamic Draw? (C++)
Paint Glossyness is not working in latest patch Rhino6
Rhino 6 - text defaults to Arial
I need help! I so much want to like Rhino 6
Bug Report: Layer States lost after V6 round trip
Rhino 6 Service Release 23 Release Candidate Available
ETO "ShowModal" fail after SR 13 canidate update
Latest update broke rs.BrowseForFolder
Rhino 6 Service Release 28 Release Candidate Available
Slow canvas UI (with multiple elements)
Rhino 6 Help Request
Display-Bug with Blocks after Update
Rhino 6 SR6 Release Candidate Available
Cylces performance degraded in this wip
Stop cycles by code
Raytraced mode slowness
Surface normals different while editing blocks
V6 - Weld Vertices not working
Linetypes in Paperspace Bug
Project tangent to surface does not result in correct surface boundary in Rhino 6
Rhino.UI.Dialogs.ShowContextMenu checked state bug
Unroller curves have no length
Printing Crashes Rhino (always)
This font was crashing rhino
Rhino web browser 'too old to work on this site'
Cast/Receive Shadows problem
Edges don't print on this block
Rhino 6 for Windows Service Release 17 Release Candidate Available
Snapshots/Animation
Pipe cap bug when preselecting both open and closed curves
Text Field Values - Export
Selecting in shaded view
Bug: Control Points vanish when selected
VRML 2.0 no longer importing reliably
V6 point (.txt) import and export changes from V5 which I think are bugs
Help files without internet access?
Linking views
Text height as no effect
Dimension value in properties
More info about Timer component?
Rhino 6 SR7 Release Candidate 2 Available
PDF print color still broken
Eto Window.Icon property raises "handle is invalid" exception in Rhino 6 SR26
Rhino 6 SR7 Release Candidate 3 Available
Set Icon broken in latest SR candidate?
Help: Saving toolbar on dropbox causes error message
IsPointInside of Rhino3dmIO seems to fail completely
Bug report: panel icons are partly hidden after customizing the icon bar
Array around crv.. wondering why this happens?
Graphics problem?
Curve Display Error
Possible bug? post effects in the rendered image screen process only for a few seconds
Unable to to toggle different "Feature Types" from the dropdown menu. (Grasshopper)
Reducing Python Script Editor Window blackens the Grasshopper Editor Window
Rhino 6 SR7 Release Candidate Available
Rhino3dmIO, wrong bounding boxes from annotation objects
Rhino crashing when editing annotation styles
Rhino 6 SR8 Release Candidate available
License expired in advance
Crashing: Ghpython component crashes Rhino when autocomplete kicks in on type hint Surface?
Remove small holes of many selected breps
Bug Annotations - Rhino 6.7 - Scaling
Rhino 6.7 cannot import WRL (Virtual Reality Modeling Language) files
Graphic bugs in rhino 6
(V6) Antialiasing change?
Rhino 6 Service Release 24 Release Candidate Available
STEP Importer Broken in Latest RC
Rhino 6 mac Beta
RhinoPDF and default setting with a new layout
-_SaveRenderWindowas not saving alpha channel
Button in edit dimension style box (partially) off-screen
Rhino 6 SR9 Release Candidate Available
Crash when using Dot display
Rhino 6.5 bug - crash on exit
"Document User Text" tab doesn't open
Rhino 6: menu "Panels/Macro Editor" seams not to work
Light from Sun and Rectangular LIghts Dim in Rhino Render
Usertext panel not rendering
Blank Floating Windows
Rhino crashing when editing text
digitize_Faro.rhp error
Yesterdays V6RC asks for license
Rhino updater changed my installation path
brep.MergeCoplanarFaces out of tolerance
Rhino 6 SR10 Release Candidate Available
Clipped Edge display: an issue wherever the section is drawn
Rhino 6 view capture not remembering settings
Rhino 6 Niggles..any ideas? Cycles and sizes and circles
ViewCaptureToFile of Raytrace still slow
Rendering Reflection Colour Cast - Corruption?
V6 - duplicate material? (from Layer Material panel) - Layer Materials Mess
Raytraced - when scaled - comes out white
Raytrace Display Render -- Capture To File Not Working?
Compiled .ghpy input tree access error
Question on RH6 usability, again
Rhino 6 BETA - not displayed objects in viewports
OpenInEditor() opens material child texture in Textures panel, not Materials panel (v6 & v7)
BoxEdit Bug
[Bug?] Joining this mesh create multiple clone objects
Is -SelLayer with wildcard broken on Rhino 6?
Rhino3dmIO Geometry.Leader Plain Text empty
"Mesh split plane" component fails
Stuttering rotations while moving cursor on viewport
Rhino 6 SR11 Release Candidate Available
[Rhino6] Add view: no anti-aliasing and performance hit
Make2D and linked Rhino files
UserDictionary.Set( string key, Plane val);
Make2D not working properly - Rhino 6 Windows
Troubles with text
RhinoScript crash on importing multiple ViewDisplayModes
Rhino 6 Service Release 25 Release Candidate Available
RhinoScript AddLeader returns NULL
ExtractPt on preselected CTRL+SHIFT points on PointCloud
Transparent background screencap - edges also transparent?
AngularDimension set DefPoint bug
Rhino 6 - Slow save to network location
Crash at Make2D command (problem with Rhino.DocObjects.Custom.UserData?)
Leader bug and system hardlock
V6 rendered mode - I really don't get it
Rhino6 Make2D Third/First Angle projection doesnt compute the perspective viewport as parallel
Rhino 6 SR 15 Release Candidate Available
Sweep 1 Rail - Simple Sweep option removed in RH6?
Rhino 6 SR12 Release Candidate Available
Disgusting line end bleeding
Chr(10) adds a space after new line
RhinoScript TextObjectJustification wrong for values of 4 an 7 in Rhino 6?
Text created by Rhino.AddText in Italics bug
Layout preview geometry bug with Grasshopper (Rhino 6 SR12 2018-12-17)
Bicycle frame - started with multipipe
Text command causes Rhino to crash each time
Rhino 6 SR13 Release Candidate Available
Rotation using Degree Minute Seconds
Rhino Sketchup export triangulating surfaces
Step import consistency issue
Rhino 6 Service Release 26 Release Candidate Available
Bug: exporting nested block doesn't add instance reference
Mesh point inclusion test reports unexpected result
Assign material to brepfaces
Set Greville Points(c++)
Small 3dm file won't open
Rhino 6 SR30 Release Candidate Available
Text Rotation Issue?
Rhino8, M2, slow command response i.e. delete, extend, fillet, split,
Display order linked to layer order
Rhino 8 not printing correctly
Request for clarification on Beta closing
Can't load Rhinoscript - again
Rhino 6 Service Release 32 Release Candidate Available
How to kill your project file? (Dangerous Bug!)
Content Cache Updated Guide
Raster printing with Rhino 8
Rhino7 newest service release requires enter/space bar to confirm the entered value?
Latest version - Service Release and Service Release Candidate
Rhino 7 saving problem
Why do I not see the latest Service Release Candidate?
Not able to access Yak packages SSL / TSL secure channel
Rhino not using GPU
Rhino 8 - Raster printing line width issues
Bug: Controlpoints and Line preview disappear in excluded clipping plane
GH Component was build against a newer minor version
BUG Shader Black Issue in Rendered Mode on Rhino 8 And 7
Printing in Color Only Prints Black & White in v8. v7 is Fine
Bug discovers
Rhino 8 UI - Can't See Display Tab Text
Layer editing bug
V8 BUG: ChangeLayer window doesn't display all layers until resized
Rhino V8 MAC
My toolbars and display layout in rhino beta 8 for mac
Toolbars not showing Rhino8
Snapdragon X Elite: Rhino doesn't run
Crash when use clippingplane in Rhino 8
Rhino 8 keeps crashing when I use the ClippingPlane Command
Importing STEP files to Rhino creates a new block
Issue in scriptable command for setting tolerance
Rhino 8 is slower than Rhino 7
Docked webview panels throw plugin id already in use on Yak update
Closing Plugin Panels
Editing a linked block wipes out everything
Problems using Visual Studio V15.5.6
Rhino 6 (licensed and latest version february 2017 ) Print to PDF Option Results in 1kb empty File
Rhino 6: Settings continuously reverted back to default
Big bug in Rhino panels, SR1
Opening large step files takes a very long time
20 posts were split to a new topic: Rhino 7 WIP Update Frequency Missing
