brian
(Brian Gillespie)
1
Rhino 6 SR10 Release Candidate 1 (6.10.18275) is now available.
To get it, subscribe to the Release Candidate update stream.
Bugs Fixed:
- Annotation:
- Dim ObjProps - Clicking User arrow with no blocks in the file removes arrows. (RH-48700)
- Dimension text display wrong with 2 dims of different distances (RH-48701)
- Annotation: Leader: Text changed to “” too easily (RH-48702)
- BoxEdit: The preview jumps all around when you are transforming objects individually. (RH-48648)
- ClippingPlane: Clipping intersection is not updated in Wireframe mode (RH-37609)
- Display:
- Baked object shows wrong texture mapping while being dynamically transformed (RH-48738)
- Closing options dialog makes display think AdvancedTexturePreview state has changed (RH-48251)
- Eto: TextChangingEventArgs.NewText and OldText crashes (RH-48678)
- File IO: Import raster pdf (RH-47521)
- Properties:
- Create a flow layout panel style control to use with the new Object Properties Panel (RH-48601)
- Create flow panel layout for icons on the eto object properties dialog (RH-48621)
- Macro for render color (RH-48462)
- RDK: Assert triggered in RDK when about to add bitmap texture (RH-48736)
- Rendering: Materials: Layer material issues (RH-48421)
- SubDFromMesh:
brian
(Brian Gillespie)
3
Rhino 6 SR10 Release Candidate 2 (6.10.18279) is now available.
Bugs Fixed:
- Annotation: Resize the dimension editor (RH-44975)
- Annotation: DimLinear: Can’t change Linear Dimension’s arrowhead (RH-48636)
- Cycles:
- Larger then viewport captures with Raytraced are blank (RH-44181)
- Sometimes result in blank or black image (RH-45147)
- Display:
- GH drawing in block previews (RH-48603)
- Technical modes with shadows on produce a rectangle artifact (RH-42875)
- Localization: German macro editor won’t open (Needs testing in SR10) (RH-48705)
- NamedView: Restoring multiple named views only shrinks the viewport (RH-46089)
- Layer Material dialog takes too long to appear (RH-48717)
- Linked block materials do not update after edit (RH-44908)
- SDK: Brep.MergeCoplanarFaces out of tolerance (RH-46914)
- SDK: Python: rs.ObjectsByType doesn’t use ‘state’ parameter properly (RH-44476)
- Sketch: Make it ignore ortho and gridsnap (RH-48709)
- SubD: SubD to NURBS - Gaps at dart vertices (RH-31322)
- Templates:
- Problem with Default Annotation Style Length Unit Setting In Some Templates (RH-45791)
- Problem with Inch Fractional Annotation Style Length Unit Setting In Some Templates (RH-45792)
Usability Problems Fixed:
- Templates: Default justification for Text and TextObject incorrect (RH-44045)
brian
(Brian Gillespie)
4
Rhino 6 SR10 Release Candidate 3 (6.10.18288) is now available.
Bugs Fixed:
- Display:
- Curve display incorrect on microscopic curve (RH-44360)
- Incomplete clipping plane intersection In the Display (RH-46205)
- Geometry Core: Add Rhino TestCorruption command that testing .NET managed breps and meshes for corruption that causes crashes in Rhino. (RH-48729)
- Make2D:
- NamedView: Create view from widget ignores ortho (RH-42090)
- OpenNURBS: Make it easier to use the C++ opennurbs pubic library in Visual Studio (RH-48727)
- Rendering: Materials: Rendered mode materials not showing after OBJ import (RH-48761)
- SDK: RhinoCommon:
- Get Broken History Warning state? (RH-48311)
- GroupTableEventArgs doesn’t provide access to the effected group (RH-48233)
- SDK RhinoCommon FileSettings.AutoSaveFile setter no longer working? (RH-48721)
- Scale: Default scale factor as distance units (RH-48698)
- ViewCaptureToFile: Remember resolution setting in scripted version (RH-48689)
