Rhino 6 SR9 Release Candidate Available
Rhino 6 SR9 Release Candidate 1 (6.9.18240) is now available.
To get it, subscribe to the Release Candidate update stream.
Crashes Fixed:
  • File IO: import_STEP!cmp_pd_entity_id – Access Denied (RH-47407)
  • No Subsystem: nvwgf2umx – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-47773)
  • Selection: InvalidOperationException: (MERGE) (RH-47888)
Bugs Fixed:
  • Annotation: Provide extensions in Rhino.UI to convert ON_Font to Eto.Font (RH-47597)
  • Annotation: DimLinear: Rhino 5 Dimension Text Shifts to Outside (RH-47473)
  • Annotation: Styles: AnnotationStyle dialog - Controls obscured by scroll bars (RH-47974)
  • ApplyShutLining: Doubled up curves (RH-45600)
  • BoxEdit: Save control values to command settings to be used and for new docs (RH-47995)
  • COLLADA: DAE export fails due to special characters in names (RH-47862)
  • Crash Processing System:
    • Make sending 3dm file more likely (RH-47925)
    • Stack Overflow (C++) exceptions are not handled (RH-47441)
  • Cycles: Status progress for Raytraced in HUD (RH-47851)
  • DPI Aware: Update Available notice looks wrong (RH-46664)
  • Display:
    • New solid hatch doesn’t draw after making hatch with lines (RH-47992)
    • transparency oddities (RH-27254)
  • EditPythonScript: Crash in python debug (RH-46611)
  • Eto: RichTextArea.SelectedText inconsistencies between platforms (RH-47813)
  • ExtractSrf: Much slower in V6 than V5 (RH-48012)
  • File IO: Remember scale between exports to PDF (RH-47954)
  • Fullscreen: Some items left showing (RH-35033)
  • Grasshopper: Delete, Escape, Enter, RMB go dead (RH-47833)
  • Make2D: Gray out “Register with previous” when “View” or “CPlane” is not selected (RH-45527)
  • Menu: Panels menu missing items (RH-47512)
  • NamedView: Redesign NamedThing dialog base class to support an Eto front end. (RH-38591)
  • Options: Deleting / Editing dimstyle crash (RH-47989)
  • Panels:
    • No scrolling (RH-46909)
    • Pages available for object types that don’t seem to make sense (RH-46742)
  • Print:
    • No filename, notes (RH-47921)
    • Printing a layout should default to the layout’s paper size (RH-47941)
    • Radio Buttons Broken on Print Dialog (RH-47969)
  • RDK:
    • Can’t change current renderer in document properties (RH-47957)
    • Custom sections don’t draw in object properties material panel (RH-47025)
    • No proper enviroment selected in UI (RH-43183)
    • Plug-in author wants to increase ‘Max Preview Seconds’ (RH-45890)
  • Rendering:
    • Dash version omits alpha (RH-47252)
    • ETO BreadCrumb ctrl (Content Editor) (RH-34198)
    • Environment selector control drop down doesn’t scroll with the section it’s on (RH-47984)
    • Ground plane auto height doesn’t work for GH meshes in OpenGL (RH-48025)
  • Rendering: Materials: Glitch when typing M for Move after cut and paste (RH-47555)
  • Rotate: Preview missing far from origin (RH-47723)
  • SDK: RhinoCommon: Grasshopper custom render meshes are not available from C# (RH-47696)
  • Tutorials: Update placeholder icons for Tutorial panel to something appropriate. (RH-47377)
  • What: Ellipses details (RH-47887)
Regressions Fixed:
  • Display: Dimension Text Not Readable Until Extremely Close Zoom (RH-47828)
SR9 RC2 (6.9.18247) is now available.
Crashes fixed:
  • Annotation: Hatch: opennurbs!ON_Curve::PointAtStart(MERGE) (RH-48087)
Bugs fixed:
  • Annotation:
    • AddLinearDimension always uses ‘Default’ dimstyle instead of ‘Current’ (RH-46097)
    • Crash in debugger - AnnocationViewModel.cs (RH-47633)
  • Annotation: DimAngular: Rhino 4 Angular Dimensions Opens in Rhino 6 Incorrectly (RH-48021)
  • Annotation: DimLinear: Dimension Length factor (RH-47566)
  • Annotation: Text:
    • Glyph meshing (RH-48057)
    • Text and Text Object commnds - fonts like Arial Narrow and Arial Black worked in V5. They do not appear in V6 UI (RH-45920)
    • Underlineing text that is ‘Arial Black Oblique’ reverts it to Arial (RH-47522)
  • ArcTTR: Tangent Radius Tangent in v6 (RH-48076)
  • BlendSrf: History error (RH-48042)
  • Block: No selection color on multiple blocks (RH-46074)
  • Build Process: Submodule not being updated by localization process (RH-48104)
  • Dir: Direction analysis watcher never deleted (RH-48053)
  • RDK: Material Library Downloader cannot handle write protected download folders. (RH-47881)
  • Rebuild: Pops up several identical warnings (RH-47721)
  • Rendering: Materials: Select material by typing first letter (RH-36142)
  • Rendering: Texture Mapping:
    • Bump Textures Not Rendering (RH-45653)
    • Cannot apply Texture Mapping (with preview) to object of type: extrusion, must explode first. (RH-47507)
    • Edit boxes and widgets don’t work properly (RH-47279)
  • SDK: RhinoCommon: File3dm.GetPreviewImage only works in Rhino (RH-45096)
  • WireCut: Typos and tune ups (RH-42266)
SR9 RC3 (6.9.18253) is now available.
Crashes Fixed:
  • No Subsystem: Sequence contains more than one matching element (RH-48137)
  • Rendering: Realtime SDK: Crash while exiting Rhino with a SampleRealtimeRenderer.rhp loaded (RH-46405)
Bugs Fixed:
    • Fails to update on Detail manipulation (RH-47896)
    • On Layout gets corrupted on Detail manipulation (RH-47897)
    • RhinoDotNetCrash.txt is missing inner exception type (RH-48182)
    • Upload file being read when file import crashes (RH-28358)
  • Cycles: Texture rotation off (RH-45995)
  • File IO: Trimming issue on reading STEP file (RH-48029)
  • Localization: “User Text” in “Rhino Options” dialog should be localized. (RH-47843)
  • Make2D:
    • 4-view does not clip (RH-46342)
    • Single view “CPlane” does not clip (RH-46346)
  • RDK: Scaling an object doesn’t update its custom render mesh (Edge softening) (RH-43371)
  • Rendering: Materials: Loses reference after adding to document. (RH-48140)
Regressions Fixed:
  • Properties: Radial and Diameter Dimension Show Invalid Overrides (RH-47540)
SR9 RC4 (6.9.18261) is now available.
Crashes fixed:
  • Annotation: Rhino.Geometry.TextEntity (RH-48116)
  • CrashDump: .NET crash during Rhino exit on Windows 10, 1803, build 17134.81 (RH-46531)
  • Display: :GetDepthBuffer – Access Denied (MERGE) (RH-48359)
  • Grasshopper: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. (RH-48322)
  • Grasshopper: Components: GH - dot display Crash (RH-46250)
  • Layer: RhinoCore!CLayerManagerListCtrl::OnPopupWorksessionSetActiveModel – Access Denied (RH-46054)
  • SDK: RhinoCommon:
    • InvalidOperationException: Invoke or BeginInvoke cannot be called on a control until the window handle has been created. (RH-48360)
    • Object reference not set… ETO. (MERGE) (RH-48366)
    • System.InvalidOperationException: Nelze volat funkci Invoke nebo BeginInvoke pro ovládací prvek, dokud není vytvořen popisovač okna. (RH-48327)
    • UNKNOWN!Commands.UI.AnnotationStyles.StyleViewModel.UpdateStyleTable – Access Denied (RH-48364)
Bugs fixed:
  • Display: SetObjectDisplayMode - Technical & Artistic (RH-47167)
  • File IO: STEP no longer works with external documents (RH-48275)
  • Localization: Detail property strings in English (RH-47847)
  • PluginManager: Rhino says Faro Digitizer plugin needs to be updated, but provides little information on what to do. (RH-48160)
  • Properties: UserText properties page goes blank when using Gumball (RH-48578)
  • Rendering: Materials: Selecting a textured library material without an internet connection should prompt the user (RH-44297)
  • Rendering: Texture Mapping: Custom mapping for CRMs wrong without ATP (RH-48199)
  • RhinoStart: rhps do not load (RH-48377)
  • Update System: Missing toolbars after update (RH-48389)
SR9 RC5 (6.9.18268) is now available.
We had hoped to release SR9 today, but made some last minute changes that should fix quite a few crashes. We also improved the installer to not delete license files when installing over old builds.
Crash:
Bug:
  • Installer:
    • 6.9 and 6.10 launches without toolbars, without using the saved rui and forces a reload of all plugins with some failing (RH-48433)
    • After installing 6.9 upgrade from 6.8, the language installer does not run (RH-48652)
    • The Rhino installer for 6.8 does not push install the Zoo server name correctly. (RH-48179)
  • Localization: Clipping in Print Panel (Italian) (RH-47241)
  • Templates:
    • Default annotation style in some templates uses one arrow and one tick (RH-46836)
    • Set templates to Smooth and Slower (RH-48507)
SR9 RC6 (6.9.18269) is now available.
Fixes in this build:
Crashes Fixed:
  • Cycles: Crash when switching away from Raytraced (RH-48355)
  • No Subsystem: Access Denied (RH-48604)
  • Properties: System.Reflection.TargetInvocationException: Rhino.Runtime.CommonObject.ConstPointer () (RH-48552)
Bugs Fixed:
  • Annotation: Selecting text with the object properties page visible causes the text mask to get set to background (RH-48655)
  • Faro: digitize_Faro.rhp “Preparing for first use” every time Rhino for Windows 6.x WIP starts. (RH-47815)
  • Grasshopper: Components: Error about Integer component (RH-47829)
  • Installer:
    • Script install of 6.6 using Zoo, update to 6.7, forgets Zoo (RH-47603)
    • Scripted Installer update from 6.8 to 6.9 loses license configuration (RH-48673)
    • Scripted update loses Zoo config (RH-48667)
    • Rhino 6.9.18268 changed my installation path (RH-48714)
    • 6.9 RC5 prompts “Enter your license key” (RH-48716)
  • Localization: German macro editor won’t open (RH-48285)
