brian
(Brian Gillespie)
1
Rhino 6 for Windows SR17 Release Candidate 1 (6.17.19189) is now available.
To get it, subscribe to the Release Candidate update stream .
Bugs Fixed:
- Annotation: Text: CRhinoDoc_AddText ignores bold (RH-53086)
- Choose One Object: “All” option in selection menu and subobjects (RH-53290)
- Display:
- File IO:
- Export evaluated ‘fX’ text as plain text (RH-53495)
- Non working characters in xaml files (RH-53406)
- FilletEdge: FilletEdge fails, OK in V5 (RH-52388)
- Offset: Offset breaks up (RH-53398)
- Pipe: Preselecting open and closed curves and using a Cap option results in extra surfaces (RH-53455)
- Print: Print is incorrectly clipped (RH-53113)
- RDK:
- Assert fires when displaying Decal panel (Uninitialized content) (RH-53433)
- Can’t use Bitmap Texture with Picture Material (RH-53302)
- Rendering: Realtime SDK: Moving clipping plane incorrectly triggers ApplyMeshChanges (RH-53225)
- SDK: Cannot subobject pick extrusions from an instance object using GetObject (RH-53460)
- SelBrush: SelBrush does not work as transparent selection command from Move (RH-52604)
- Selection: Backface color transparency affects selection (RH-53491)
- SelectionFilter: Filter and widgets (RH-53483)
- ShowEdges: ShowEdges dialog problem (RH-53151)
- Snapshot: Object Material Assignment client causes the Unsaved Model State dialog to pop up (RH-53271)
- Sweep1: Untrimmed miter gets wider at kinks (RH-53323)
- WebBrowser: Too old to work on a website (RH-53549)
Crashes Fixed:
- Annotation: Text: Crash with this font (RH-49785)
- Drag: RhinoCore!CRhinoObject::IsHidden – Access Denied (RH-53292)
- Eto:
- System.NullReferenceException: Eto.Forms.Window.Close () (RH-48544)
- System.NullReferenceException: Eto.Wpf.Forms.Controls.GridColumnHandler.CellEdited (ICellHandler cell, FrameworkElement element) (RH-53037)
- No Subsystem:
- 0x00000057
1c8fc780!0x000000571c8fc780 – (NTSTATUS) 0xe0434352 - (RH-50800)
- 0x1!0x1 – (NTSTATUS) 0xe0434352 - (RH-53031)
- Toolbar: NullReferenceException: UnsafeNativeMethods.CRhinoUiToolBarManager_OnToolBarButtonClicked (RH-53598)
Meta Issue:
- SDK: Python: Add a note to the RhinoScriptSyntax README to help contributors understand our branching scheme (RH-53346)
Regressions Fixed:
- Display:
- Can’t get mesh naked edges to show in Technical mode (RH-48509)
- Clipping Plane - Cannot change option “Shade selected plane > Color” (RH-53021)
- Sweep1: Untrimmed miter error (RH-52961)
SDK Enhancements:
- SDK: RhinoCommon: Provide support for enforcing Raster output in ViewCaptureSettings (RH-52318)
dan
(Dan)
3
Rhino 6 for Windows SR17 Release Candidate 2 (6.17.19196) is now available.
To get it, subscribe to the Release Candidate update stream.
Bugs Fixed:
- Display: The “Flat shading” setting in ANY display mode doesn’t seem to stick when changed (RH-50741)
- Documentation: Document ability to override settings by sys admins (RH-53059)
- Shear: Macro with Shear command fails when drag-selecting (RH-53192)
Crashes Fixed:
- No Subsystem: Could not find HatchPattern with ID ec0fc635-4c6a-40b6-9679-8fcbf56528a6 (RH-53580)
- Options: Searching Options > Advanced crashes Rhino (RH-53306)
dan
(Dan)
4
Rhino 6 for Windows SR17 Release Candidate 3 (6.17.19204) is now available.
Performance Problems:
- Display: RH-53792 Technical Display Performance improvements
brian
(Brian Gillespie)
5
Rhino 6 for Windows SR17 Release Candidate 4 (6.17.19212) is now available.
Bugs Fixed:
- BoxEdit: Incorrect size info (RH-53923)
- Build Process: Rhino3dm (iOS): Consider adding a reference to System.Drawing.Common (RH-54050)
- Display: Draw ground plane intersections with shader (RH-53855)
Crashes Fixed:
- Eto: System.ObjectDisposedException: Eto.Widget.get_Handler () (RH-52467)
- No Subsystem: Method not found: ‘Void Rhino.Render.CustomRenderContentAttribute…ctor(System.String, Boolean, System.String, Boolean, Boolean, Boolean)’. (RH-53844)
Performance Improvements:
- Display:
- Large blocks slow when clipped (RH-52341)
- Technical Display Performance improvements (RH-53792)
Regressions Fixed:
- No Subsystem: Correct typefaces not always found for certain languages (RH-53897)
brian
(Brian Gillespie)
6
Rhino 6 for Windows SR17 Release Candidate 5 (6.17.19218) is now available
Crashes Fixed:
- WeldVertices: opennurbs!ON_DotProduct – Access Denied (RH-54055)
- Display: Skip curve visibility testing (RH-53992)
brian
(Brian Gillespie)
7
Rhino 6 for Windows SR17 Release Candidate 6 (6.17.19232) is now available
Bugs Fixed:
- Display: Edges cannot be turned off (RH-54193)
- PackageManager: PackageManager has access to Internet when DisableInternetAccess=1 (RH-54087)
- Print: Some lines print extra heavy (RH-54266)
Crashes Fixed:
Enhancements:
- Display: Technical Display Performance Improvements (RH-54123)
