Rhino 6 SR14 Release Candidate Available
Rhino 6 SR14 Release Candidate 1 (6.14.19064) is now available.
To get it, subscribe to the Release Candidate update stream .
Bugs Fixed:
  • Annotation: DimLinear: History broken on Extrusion objects (RH-50905)
  • Annotation: Leader: Break history on leader text modification (RH-51081)
  • BlendSrf: No Zebra on chained edges (RH-50790)
  • Display:
    • Decals don’t have mipmapping enabled (RH-50908)
    • Technical shows lines from off-in-detail layers (RH-50008)
    • Text quits displaying after lots of view changes (RH-50854)
  • File IO:
  • Help: F1 does not open Circle help (RH-51106)
  • MacroEditor: Opens Help web page (RH-51169)
  • NamedView: Dragging a Named View Widget does not cause a OnEvent call (RH-50995)
  • No Subsystem: In-place material editor displays texture after pasting (RH-50878)
  • Print: Draw Order not consistent with print output (RH-50792)
  • SDK: RhinoCommon:
    • RhinoDoc.WriteFile should pay attention for file extension (RH-51091)
    • SweepOneRail.PerformSweep failure (RH-50636)
  • Selection: Pre-selected object gets semi-unselected during Trim (RH-50851)
  • Toolbar: Icons are wrong or wrong size (RH-50996)
  • UDT:
Crashes Fixed:
  • No Subsystem: mfc140u!mfc140u – Access Denied (RH-50932)
  • Project: opennurbs!ON_Curve::EvPoint – Access Denied (RH-50929)
  • RDK: Rhino crashes on exit after pasting a deleted material (RH-50759)
  • SDK: mfc140u!mfc140u – Access Denied (RH-51067)
  • SDK: Python: Crash on MatchAtrributes (RH-50362)
Enhancements:
  • RDK: Render Content Name Conflict dialog annoyance (RH-50817)
Regressions Fixed:
  • NamedView: Cannot transform control points of Named View Widget (RH-50696)
  • No Subsystem: :Impl – Access Denied (RH-49602)
Rhino 6 SR14 Release Candidate 2 (6.14.19070) is now available.
Bugs Fixed:
  • Gumball: Does not accepts scaling in units, if scale node has been adjusted (RH-51170)
  • SDK: DisplayMode properties changed by scripts revert back on Gumball toggle and other actions (RH-51112)
  • UserText: Fragile link between Attribute User Text - Text Field - Object Name and Object Name (RH-51172)
Crashes Fixed:
  • Cycles: Crash with linear lights in Raytraced (RH-50809)
Rhino 6 SR14 Release Candidate 3 (6.14.19078) is now available
Bugs Fixed:
  • Cycles: Texture images are read in flipped through Cycles XML (RH-51358)
  • Localization: Unlocalized command in German Rhino (RH-50786)
  • OpenNURBS: Rhino3dmIO build failing (RH-51375)
  • Properties: Dimension icon becomes blank (RH-51272)
  • SetUserText: Attribute user text from Properties (RH-51298)
Rhino 6 SR14 Release Candidate 4 (6.14.19085) is now available
Bugs Fixed:
  • File IO: SketchUp materials come in incorrectly in nested components (RH-51558)
  • Licensing: Cloud Zoo: Cloud Zoo hang-up (RH-51259)
  • Rendering: Materials: The BUMP texture does not open (RH-50706)
Regressions Fixed:
  • Annotation: Text: Cannot change font size in text editor (RH-51527)
Rhino 6 SR14 Release Candidate 5 (6.14.19092) is now available
Bugs Fixed:
  • File IO: Some materials that have names in Sketchup get set to nothing in Rhino (RH-51571)
  • Grasshopper: Parallel computing with Point in Brep Component crashing Rhino (RH-51201)
Rhino 6 SR14 Release Candidate 6 (6.14.19106) is now available
Regressions Fixed:
  • Make2D: Clipping plane cutting into box in Top view produces no result from Make2D (RH-51626)
Tasks Completed:
  • OpenNURBS: Release new public opennurbs from 6.14 (RH-51765)
Rhino 6 SR14 Release Candidate (6.14.19113) is now available
Crashes Fixed:
  • SDK: RhinoCommon:
    • Crash in Brep Curve Intersection component (RH-51517)
    • Rhino crashes when loading Octane. (RH-52114)
