Rhino 7 SR4 Release Candidate 2 for Windows and Mac (7.4.21047) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac
Bugs Fixed:
- Curve-surface intersection: Tangent circles were not trimmed properly (RH-49513)
- Display: Grasshopper geometry was not affected by Arctic mode (RH-54491)
- History:
- Libraries: External drive locations overlapped in Favorites (RH-44424)
- MatchProperties:
- MeshRepair: "Align Vertices" button ran an obsolete command (RH-62619)
- Picture: The scriptable command created a Custom, not a Picture, material (RH-48174)
- RDK: Scripting material name did not work properly (RH-53152)
- Rendering: Post Effect: The Denoiser effect was not applied to ViewCaptureToXXX results (RH-60785)
- Rendering: Texture Mapping: Custom mesh mapping fails on mesh objects (RH-62605)
- SDK: CRhinoObjRef::SelectionPoint returned incorrect location (RH-62633)
- SelBrush: Curve option returned cancel and made subsequent commands in a script fail (RH-62697)
- VolumeCentroid: Was incorrectly calculated (RH-39331)
Crashes Fixed:
- RDKCrash: Crash caused by accessing RenderMaterials table twice (RH-62647)
Enhancements:
- Rendering: Cycles: Raytraced mode / Rhino Render can use above 64 and all CPU cores available (RH-62665)
- Rendering: Textures: Rendering - Added AlwaysUnpackEmbeddedFilesToTemp advanced setting for moving *embedded_files folder from next to 3dm to TEMP folder (RH-58250)
Regressions Fixed:
- Grasshopper: Components: Mesh Curve Intersection did not find all intersections (RH-62386)
- Properties: The scriptable command (-Properties) did not support hatch properties (RH-62192)
SDK Enhancement:
- OpenNURBS: Added font management support for user specified missing font substitutions. (RH-62306)
- SDK: RhinoCommon:
UI Change:
- Menu: Added Analyze > Curve > ShowEnds (RH-62452)
Mac-Only Changes
Enhancements:
- File IO: Tuned up behavior of file duplicating (Shift+Command+S) (RH-62594)
- Properties: Added Displacement settings to curves with Curve Piping enabled (RH-62282)
Windows-Only Changes
Bugs Fixed:
- Menu: "Help > Technical support" goes to a 404 error (RH-62466)
- Rendering: Textures: Rhino hanged when running a command while searching for textures (RH-61634)
Regressions Fixed:
- ScriptCompiler: Compiled script plug-in does not print message when loading (RH-61920)
