Rhino 6 SR7 Release Candidate 3 Available
Rhino 6 SR7 Release Candidate 3 (6.7.18190) is now available.
To get it, subscribe to the Release Candidate update stream.
New in SR7 RC3:
Bug:
  • Annotation: Linetype: Create ETO Linetype Modal Dialog (RH-46484)
  • Display:
    • Block instance display color unstable (RH-45093)
    • Detail print color display ignored in blocks (RH-47035)
  • File IO:
    • IGES Export Color Option Default (RH-46878)
    • STEP import missing surfaces (RH-35624)
    • Step import - Ugly surface that other products can repair (RH-36106)
    • Surfaces trimmed incorrectly reading DWG file (RH-46761)
  • Guides: Should not be copied with objects to another model (RH-46776)
  • InfinitePLane: Show the plane right away (RH-46959)
  • Print: Clean up paper sizes (RH-46464)
  • Rendering: Materials: Disappear (RH-46825)
  • SDK: GHPython: prevent the external scope from evaluating at every repetition (RH-47124)
  • SelChain: SelChain, SelColor and script runner commands (RH-46995)
  • Toolbar: Error message when loading disabled plug-in RUI file (RH-47126)
  • Tutorials: Confusing links in Help (RH-46980)
Crash:
  • Cycles: IndexOutOfRangeException: Der Index war außerhalb des Arraybereichs. (RH-47041)
  • SDK: RhinoCommon: tl!TL_SortPlanarCurves – Access Denied (RH-47199)
A post was merged into an existing topic: Rhino 6 SR7 Release Candidate 1 Available
