brian
(Brian Gillespie)
June 1, 2018, 5:25pm
1
Rhino 6 SR6 Release Candidate 1 (6.6.18149) is now available.
To get it, subscribe to the Release Candidate update stream .
New in SR6 RC1:
Bugs Fixed:
Annotation: Text: Text does not show in RH6 (RH-46254 )
Area: Failure (RH-45887 )
BlockEdit: Reverses normals (RH-20775 )
Explode: Exploding a polysurface with per-face materials drops the material assignment (RH-42470 )
File IO: OBJ import pops up a dialog for every unknown type it encounters (RH-46255 )
Grasshopper: Custom Preview render mesh providers are skipped inside clusters. (RH-45439 )
Grasshopper: Components: Empties and nulls in Addition/Subtraction/Multiplication need to be handled better. (RH-45811 )
Print:
Autosave Every Page (RH-46213 )
Printing Technical modes to PDF doesn’t work. (RH-46267 )
Rendering: Materials: Need a way to get a simple color from an ON_Material for the layer panel (RH-46117 )
SubD:
Becomes invalid after deleting some faces (RH-46175 )
Fix WireFrame display (RH-46258 )
TextObject: Broken single stroke fonts for V6 (RH-43096 )
WeldVertices: Does not work in V6 with attached model. (RH-46170 )
Features:
Grasshopper: Bake: Cluster baking should omit/include internal geometry appropriately. (RH-43831 )
Rendering: Realtime SDK: Commands and API for accessing HUD functionality (RH-42000 )
brian
(Brian Gillespie)
June 5, 2018, 10:16pm
3
New in SR6 Release Candidate 2 (6.6.18152):
Meta Issue:
Grasshopper: document the .no6 extension for GHAs (RH-44953 )
Crashes fixed:
We just fixed a significant source of crashes all over Rhino. It affects Rhino not being able to save, crashing when working with annotation, and some crashes in Grasshopper.
No Subsystem: tl!SplitIntervalsMatch – Access Denied (RH-46416 )
Surface-surface intersection: tl!SSXnew::ComputeIntersectionCurves – Access Denied (RH-46419 )
Bug:
Annotation: DimLinear: Dimension collapses with history update (RH-46241 )
Annotation: Hatch: Purge causes a Hatch error (RH-45012 )
Display: GPU Tessellation - Thick curves have flat ends in print display (RH-43461 )
Help: What does GrasshopperDeveloperSettings do? (RH-46371 )
Panels: PanelType.System Panels get treated like public enum PanelType.PerDoc panels (RH-46396 )
Feature:
Grasshopper: Add GrasshopperLoadOneByOne command (RH-45335 )
brian
(Brian Gillespie)
June 12, 2018, 9:54pm
4
New in SR6 Release Candidate 3 (6.6.18163)
Bug:
Decals: Cylindrical decal shows upside down. (RH-46148 )
Detail: String changes in properties (RH-46556 )
PrintPreview: Print display line ends (RH-44688 )
SDK: RhinoCommon: MeshFaceList.DeleteFaces also deletes vertices (RH-45910 )
brian
(Brian Gillespie)
June 19, 2018, 10:20pm
5
New in SR6 Release Candidate 4 (6.6.18168):
Crash Fixed:
Bugs Fixed:
3DFace: Ngons and quads (RH-45859 )
Annotation: DimLinear: Add control of right or left text placement of text that won’t fit in linear dimensions (RH-46012 )
File IO:
PLY files are not importing properly in V6 (RH-46652 )
VRML import broke in recent builds of V6 (RH-46610 )
Help: Make Help file system available for off-line V6 users (RH-43313 )
Installer:
Make hyperlinks in Privacy Policy open default web browser (RH-46750 )
Update installer privacy policy (RH-46643 )
SDK: GHPython: ghpythonlib.components do not take **kwargs properly (RH-46672 )
SDK: RhinoCommon: ShowContextMenu not working as expected (RH-40761 )
Selection: Make SubD control polygon pickable (RH-46067 )
ViewCaptureToClipboard: View capture from Raytraced kicks off a rerender when it shouldn’t (RH-46313 )
Enhancements:
Annotation: DimOrdinate: Needs Update Option (RH-46154 )
