Rhino 6 SR23 Release Candidate 1 for Windows and Mac (6.23.20028) is now available.
To get it, subscribe to the Release Candidate update stream on Windows or on Mac .
Bugs Fixed:
- Display: Far from Origin - Extrusion Objects - New display meshes after ClearAllMeshes are still yukky (RH-54463)
- ExtendSrf: Fixed extension preview of trimmed surfaces not using object's color (RH-55971)
- ExtractRenderMesh: ExtractRenderMesh does not land in the active file (RH-56549)
- File IO:
- Make2D: Text affects Make2d scale (RH-55212)
- PrintPreview: PrintDisplay and Default line weight (RH-56294)
- SDK: Unexpected issues with deleting Display Modes (RH-56488)
- SDK: RhinoCommon: Added BrepEdgeList.MergeEdge and BrepEdgeList.MergeAllEdges (RH-56496)
- SoftEditSrf: Preview incorrect for FixEdges=No (RH-55717)
- UserText: Retain key when value is removed (RH-56502)
Crashes Fixed:
- opennurbs!ON_String::operator= – Access Denied (MERGE) (RH-56197)
- Choose One Object: RhinoCore!RhinoChooseOneObjectHelper – Access Denied (RH-56676)
- Extend: opennurbs!ON_Geometry::GetBoundingBox – Access Denied (RH-56641)
- File IO: ntdll!RtlpFreeHeapInternal – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-54504)
Regressions Fixed:
- Annotation: Dot: Size change does not update in real-time (RH-55731)
- Annotation: Text: method TextObjectText removes property font_style=1 (bold) (RH-54742)
- SDK: RhinoCommon: V6 Display PointStyle not filled with white (RH-56225)
SDK Enhancement:
- SDK: RhinoCommon: Set Background Gradient Colors from Python Rhinocommon (RH-53234)
Usability Problems Fixed:
- Annotation: Styles: Styles - More accessible "Edit Style" (RH-56327)
Mac-Only Changes
Bugs Fixed:
- Rhino reminds me to update my MacOS (RH-56389)
- Annotation: DimLinear: Unit cannot be changed in properties (RH-55611)
- Color Picker: Color from HSB sliders is not sent to material color (RH-55867)
- DevLoft: SubCrv stops the command (RH-49515)
- Eto: Moving a dialog with the WindowStyle set to None not possible (RH-48963)
- ThicknessAnalysis: ThicknessAnalysys unusable on Mac (RH-55891)
Crashes Fixed:
- -[NSApplication _crashOnException:] (RH-50573)
- -[UnitsPrefController setModelUnitIndex:] (RH-53416)
- -[MRDocument revertToContentsOfURL:ofType:error:] (RH-55195)
- RDK: Under OSX Eto form can crash Rhino (RH-56323)
- Rendering: NullReferenceException: Object reference not set to an instance of an object (RH-55794)
Regressions Fixed:
Windows-Only Changes
Bugs Fixed:
- Annotation: Text: Edit Text dialog box has OK and Close buttons functioning the same (RH-55374)
- BlockEdit: Click leaves extra copies (RH-56469)
- Print: Dialog niggle (RH-49684)
Regressions Fixed:
- Annotation: Text: Made scrolling through fonts and preview possible again (RH-34845)
