Rhino 7 Service Release Candidate Available
Rhino 7 SR4 Release Candidate 3 for Windows and Mac (7.4.21054) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac
Bugs Fixed:
  • Display: Block instances became invisible in Rendered mode with reflective material on ground plane (RH-62541)
  • Explode: Did not warn on dense meshes (RH-62722)
  • PackageManager:
    • Listed incompatible version as available update (RH-62299)
    • Packages for Rhino 7.4 could be installed in 7.3 (RH-62590)
  • Rendering: Materials: SetEnvironmentTexture does not work in Rhino 7 (RH-62874)
Enhancements:
  • File IO: SKP Import - Displays warning when SketchUp file is newer than supported (RH-62765)
  • PackageManager: Local package repository supports keyword search (RH-62476)
  • Reparameterize: Works individually on polycurve segments instead of the whole polycurve (RH-62712)
Regressions Fixed:
  • Grasshopper: Components: Mesh Curve Intersection did not find all intersections (RH-62386)
  • MoveEdge: Distorted surface without internal trims (RH-62818)
SDK Enhancement:
  • SDK: RhinoCommon:
    • Added Mesh.MatchEdges() which calls RhinoMatchMeshEdge (RH-30345)
    • GetNextDiscontinuity tolerance parameters were missing (RH-62573)
Windows-Only Changes
Bugs Fixed:
  • Installer: Rhino fails to install with RMA_SERIALNUMBER is a required property (RH-61465)
Enhancements:
  • Rendering: Cycles: OpenCL render device usage has been improved to avoid crash (RH-62353)
