Rhino 6 SR21 Release Candidate 1 for Windows and Mac (6.21.19324) is now available.
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
- Annotation: DimLinear: Distance Between Baseline Dimension in Layout Too Large (RH-55319)
- Decals: No event when dragging widget (RH-55354)
- Display:
- ExtractIsocurve: Extra isos from Extrusions (RH-55338)
- Help: No help from File Options dialog (RH-55394)
- Panels: Eto Named Items UI scroll bar is broken (RH-55477)
- SDK: Retrim surface bug (RH-55373)
- ShowSelected: "ShowSelected" or "UnlockSelected" Not Working in Detail (RH-55673)
- SmartTrack: SmarTrack implied "between" not working in certain cases in V6 and WIP (it did in V5) (RH-55493)
- UserText: text function sanitizer is matching functions on functions that contain words in other functions. (RH-55514)
- ViewCaptureToFile: Removing ScaledDrawing command line option from ViewCaptureToFile breaks Bongos animation rendering (RH-54395)
Crashes Fixed:
- File IO: RhinoCore!CRhDocSdkExtension::IsFileReadOnly – Access Denied (RH-55622)
- Toolbar: System.InvalidOperationException: System.Windows.Forms.Control.Dispose (Boolean disposing) (RH-50244)
Enhancements:
- SDK: RhinoCommon: GetModelScale / SetModelScale need wrapped for ViewCaptureSettings (RH-55372)
Regressions Fixed:
SDK Enhancement:
- SDK: Add functions for querying whether a certain OpenGL version can be used (RH-37168)
Tasks Completed:
- OpenNURBS: Sync changes from open source sbaer/rhino3dm branch back into opennurbs (RH-55467)
Mac-Only Changes
Bugs Fixed:
- Change 3DConnexion build method (RH-53092)
- Dark Mode: Color denoting modified in Text dialog hard to read (RH-55220)
- Display: Rendered mode lighting is wrong when Sidecar is being used (RH-55663)
- Display: OpenGL 3.3: Distorted drawing with AMD Radeon HD 6750M (RH-51148)
- Eto: Eto Named Items UI hangs with lots of items (RH-52254)
- Export:
- NamedView: Named Views list, name get cut off (RH-55647)
- Preferences: Mouse preferences not sticking (RH-55461)
- Print: Poor resolution on print to PDF (RH-55355)
- RDK: IOR setting squishes the transparency slider (RH-54654)
- Rendering: Wallpaper not rendering (RH-55670)
- Rendering: Materials:
- UI Cleanup:
Cosmetics:
- Preferences: Tooltip offset X and Y offset value entry boxes should be slightly wider (RH-55340)
Crashes Fixed:
- Contour:
Features Added:
- NamedView: Ability to drag to reorder the items (RH-55376)
Incomplete Port:
- EditPythonScript: Debugger for EditPythonScript on macOS (RH-54430)
Windows-Only Changes
Bugs Fixed:
- File IO: Cancelling Save overwrites MRU File (RH-55408)
- Help: Help page updates needed for these icons which save toolbar collections (RH-55597)
- RDK: Mysterious Black Box (RH-55294)
Crashes Fixed:
