dan
(Dan)
1
Rhino 6 for Windows SR16 Release Candidate 1 (6.16.19169) is now available.
To get it, subscribe to the Release Candidate update stream.
Bugs Fixed:
- File IO:
- STEP import hangs in V6. Not V5 (RH-52594)
- SaveAs/Export misses dimensions (RH-53275)
- SDK: RhinoCommon: Boolean Split in RhinoCommon (RH-53221)
Regression:
- Display:
- Odd near plane cut-off when ground plane enabled (RH-53270)
- Thumbnail Quick Previews have strange white stripes (RH-53217)
- File IO:
- SLC export regression in Rhino 6 (RH-53163)
- When overwriting an existing file, a bak file is created (RH-50560)
Tasks Completed:
- File IO: Change *.3DMBAK in Options to *.*BAK (RH-53144)
dan
(Dan)
4
Rhino 6 for Windows SR16 Release Candidate 2 (6.16.19176) is now available.
To get it, subscribe to the Release Candidate update stream .
Bugs Fixed:
- Licensing: Cloud Zoo: Remove SR decimal designation from message (RH-49020)
- Pipe: Trims funny (RH-1220)
- SDK: RhinoScript: Rhino.AddAlignedDimension new bug (RH-53254)
Crashes Fixed:
- FilletEdge: RhinoCore!CVRBSrf::GetSectionIds – Access Denied (RH-52916)
Regression:
- Annotation: Text: Grouped text, double-click editing (RH-52950)
SDK Enhancement:
- SDK: Provide function to draw Zebra preview (RH-53350)
brian
(Brian Gillespie)
6
Rhino 6 for Windows SR16 Release Candidate 3 (6.16.19183) is now available.
Bugs Fixed:
- Cycles:
- Compute tangents for render meshes prior to pushing to Cycles (RH-52111)
- Glossiness and Polish has changed in Raytraced (RH-53403)
- SDK: Python: NurbsCurves with Weights does not match RhinoCommon (RH-47837)
- SDK: RhinoCommon: Provide function to draw Zebra preview (RH-53352)
Crashes Fixed:
- File IO: Import Command: import_STEP!ClosestPointBad – Access Denied (RH-53450)
SDK Enhancements:
- RDK: RenderTexture.IsHdrCapable can not be overridden (RH-52530)
- SDK: RhinoCommon: Support Undo and Redo (RH-53088)
