Rhino 6 SR11 Release Candidate 1 (6.11.18310) is now available.
To get it, subscribe to the Release Candidate update stream.
Crashes Fixed:
- :DrawSurface – Access Denied (RH-49173)
- Crash when opening a document (RH-49110)
- rdk!GetDefaultPreviewEnvironment – Access Denied (RH-48820)
- RoundHole: opennurbs!ON_Brep::Duplicate – Access Denied (RH-48771)
Bugs Fixed:
- Annotation:
- Annotation: Leader: History updates when detail activated (RH-49029)
- ApplyDisplacement: Transform mesh with displacement (RH-43929)
- ApplyShutLining:
- ContinueCurve: Continue a rational curve (RH-48989)
- Display:
- Grasshopper: Font picker broken (RH-49017)
- Grasshopper: Components: Line charge broken if x=0 (RH-49083)
- Loft: Loose option should use a better parameterization (RH-49231)
- Mesh: The mesher does not work right with surf… (RH-292)
- Mirror: Flips normals inward (RH-49075)
- No Subsystem:
- ControlGridLayout create a method to freeze layout while adding controls (RH-49192)
- ControlGridLayout tune up for center aligned controls (RH-49186)
- Make NumericSteppers in Rhino.Ui.Controls public (RH-48879)
- Multidoc support fixes in Lasso et al (RH-49016)
- Sizing error crash in WpfElementHostBase in RhinoWindows.dll when loading large document text collection (RH-48656)
- OpenNURBS: Make RTF names like “Klavika Medium” work on Windows (RH-49028)
- Properties: No content control context menu (RH-48172)
- Pull: Pullback should be in surface domain (RH-49147)
- RDK: Assert when closing Rhino - CRhRdkFrameBufferChannel::DeleteBuffers (RH-48611)
- Rendering: Materials: Per face material in wireframe temporarily breaks shaded modes (RH-47892)
- SDK: Add Euler angle support in ON_Xform (RH-49074)
- SDK: RhinoCommon:
- SelConnected: Wrap around closed curve & surface seams (RH-49156)
- SubD: Micro gaps in SubD meshes (RH-49094)
- TextObject: Elaborate about AllowSingleStroke option in the help (RH-48437)
Usability Problems Fixed:
- Join: Pre-selected edges are ignored by the Join command (RH-44162)
- Textures: Custom Curve control keeps resetting zoom (RH-49236)
Enhancements:
- Grasshopper: Curve Division must be smarter to take into account the end of the curve and rounding errors. (RH-49039)
