brian
(Brian Gillespie)
April 4, 2018, 12:19am
1
Rhino 6 SR4 Release Candidate 1 (6.4.18093) is now available.
To get it, subscribe to the Release Candidate update stream .
New in SR4:
Enhancement: *
Display: Highlight isocurves on selected object (V5 feature missing in V6) (RH-45031 )
Crash:
Lights: Right-clicking a column header in Lights panel crashes Rhino (RH-45186 )
Make2D: Crash or hang (RH-44987 )
SDK: RhinoCommon: Preview scene objects aren’t properly wrapped, causing “DocumentCollectedException: This object cannot be modified because it is controlled by a document.” (RH-45109 )
Bug:
Annotation:
Background Text mask doesn’t work anymore (RH-43960 )
Tolerance doesn’t display when natural length <> is replaced (RH-44973 )
Annotation: DimLinear: Dimension update with Project (RH-43676 )
BlendCrv: BlendCrv - Join when the input is edges (RH-44976 )
BlockEdit: Hatch in Block Displays at Incorrect Scale in InPlace Edit (RH-29465 )
ClippingPlane: Display does not update when remapping ClippingPlane (RH-28448 )
Core Architecture: :GetCachedTexture(const wchar_t* filename, bool bFromFile) (RH-39166 )
Display:
Blocks invisible if layer is locked (RH-44782 )
Curves should not affect ground plane elevation (RH-44307 )
Decal widget should not affect ground plane elevation (RH-43964 )
Drawing delays when first object is created (RH-44830 )
False color analysis not working in some display modes (RH-38223 )
SetObjectDisplayMode buglet (RH-42692 )
TextMask display not forward enough in display order (RH-43106 )
Use isocurve color does not work (RH-43202 )
Extrude: UVN mode on mesh boundary edges (RH-44874 )
File IO:
DGN import can’t select model spaces (RH-45115 )
Export Radial dimensions with edited text to dwg not right (RH-45003 )
OBJ roundtrip problem (RH-44974 )
Reading Acad files, Make standard 4 views and layouts from Acad (RH-44251 )
History: Prefix # fails inside script runner commands like Paste (RH-44516 )
Lights: Names and layers in Lights panel won’t update immediately (RH-45187 )
Localization: Strings in English (RH-44104 )
Match: Matching to surface edge and History (RH-45122 )
No Subsystem:
Context Menu Item “Select By Value” and “Select By Key Value” for user text issues (RH-44871 )
Serious bug in PT_MeanBBox() (RH-44774 )
Print:
PDF with hidden lines - too thick (RH-44757 )
Printing attached model as PDF creates erroneous output. (RH-44742 )
RDK:
Preview scene causes calls to CRM WillBuildCustomRenderMesh during display (RH-45085 )
Proxy Contents in the uuidData_RdkContentDisplayCollection DataSource (RH-45032 )
RHRDK_ASSERT should report to Raygun (RH-45113 )
WCS scaled materials (like the library materials) are totally broken (RH-44878 )
Rendering: Materials: Metal bump textures do not work in 6.4 (RH-44880 )
Rendering: Texture Mapping: Texture settings in materials have a possible mapping channel of “0” (RH-44748 )
SDK: RhinoCommon:
Add double precision mesh support to RhinoCommon (RH-30860 )
Make Point2f, Point3f, Vector2f, Vector3f ISerializable (RH-45075 )
coerce3dpoint does not use CultureInfo.InvariantCulture (RH-45112 )
SDK: RhinoScript: CurveAreaCentroid method always returning (0,0,0) (RH-44692 )
Select: Alt-double-click to force editing text and dots (RH-44495 )
Feature:
SDK: Python: Upgrade IronPython to 2.7.8.1 from 2.7.5 (RH-42987 )
Please report any problems in this forum. Thanks!
brian
(Brian Gillespie)
April 10, 2018, 11:33pm
3
Rhino 6 SR4 Release Candidate 2 (6.4.18100) is now available.
Bug Fixes:
Annotation: Don’t show preview text in DimCurveLength (RH-44449 )
BlendCrv: History and edit mode is broken (RH-44315 )
Display:
Add Clipping Plane settings in the Artistic, Pen and Technical display mode options (RH-15567 )
CRhinoDisplayPipeline::DrawBitmap not drawing dibs with alpha transparently (RH-44803 )
Hidden lines are displaying incorrectly (RH-44601 )
New display mode is missing from list (RH-26522 )
Object display with vertex colors (RH-45249 )
SubD object shades darker then it ought to (RH-40848 )
Text mask not masking (RH-37492 )
Drape: fails with vertical objects (RH-26400 )
EndBulge: Surface display color uses layer color (RH-12793 )
File IO:
Hookup 2018 SKP SDK on both platforms (RH-45089 )
SkectchUp import does not get the textures for this model. (RH-45124 )
Lights:
Context menu items applied to the previously selected light (RH-45222 )
Two settings in Lights panel are not functioning (RH-45188 )
Menu: Localization string in the menu (RH-13261 )
OSnap: Pressing Shift or Control when floating osnap toolbar has focus (RH-45151 )
Print:
Text in blocks printing as white (RH-43453 )
WYSIWYG capturing of Technical views has been broken … (RH-45200 )
Rendering: Materials: Scale problems in SR4 (RH-45414 )
SDK: Python: Bug in rs.ExplodeMeshes (RH-41744 )
SDK: RhinoCommon:
Calling DisplayPipeline.DrawMeshWires from GetPoint.OnDynamicDraw override doesn’t draw anything (RH-45281 )
No way to get user text on a group (RH-33092 )
Wrap RhinoChangeSeam for RhinoCommon (RH-45015 )
SDK: RhinoScript: Provide option in Rhino.Redraw to not refresh layer panel (RH-45312 )
UI Cleanup: Clean up Context Menu filtering on User Text panel (RH-44724 )
Zebra: Double the analysis (RH-14877 )
brian
(Brian Gillespie)
April 17, 2018, 10:36pm
4
Rhino 6 SR4 Release Candidate 3 (6.4.18107) is now available.
Crashes fixed:
ShowNotifications: Crash clicking on the notifications panel icon (RH-45350 )
Features added:
MatchProperties: Add mesh modifier properties (RH-22541 )
Bugs fixed:
Cycles: Image interpolation not optimal (RH-39827 )
Display: 2D text drawing busted (RH-45226 )
Installer: Can’t require Win 7 SP2 as it does not exist (RH-45452 )
Print: Printing attached model as PDF creates erroneous output. (RH-44742 )
SDK: RhinoCommon: Point3f, Vector3f deserialization broken (RH-45446 )
SubDFromMesh: _SubDFromMesh result not visualized in certain display modes but exists in the file (RH-41629 )
brian
(Brian Gillespie)
April 25, 2018, 9:36am
5
Rhino 6 SR4 Release Candidate 4 (6.4.18114) is now available.
Crashes Fixed:
OSnap: VCRUNTIME140 – Access Denied (MERGE) (RH-45360 )
Print: Crash on Print to pdf (RH-45437 )
RhinoStart: Rhino 6.4.18092.16031 crashes on startup (RH-45259 )
Bugs Fixed:
BlockEdit: Open Block Edit “If” File is Closed in Block Edit (RH-42749 )
COLLADA: Special character in name causes DAE export to fail. (RH-45421 )
Drag:
Transforming sub-objects at the command line (RH-45386 )
Use single worker thread for brep & extrusion subobject transforms (RH-45283 )
File IO: STEP import doesn’t import everything (RH-45596 )
Gumball: Offset value box and make right-click accept the input (RH-45192 )
Insert: Block name list in the Inert dialog uses case sensitive compare (RH-45522 )
NamedView: Restore from the command line does not animate (RH-45235 )
ShowEdges: Display not working in Rendered mode on mesh edges. (RH-43967 )
Text: Input area invisible (RH-45443 )
Update System: Post Plug-in updates data as utf-8 (RH-45574 )
