Rhino 7 Service Release Candidate Available
Rhino 7 SR10 Release Candidate 1 for Windows and Mac (7.10.21223) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
  • BoxEdit: Input was added to the existing size (RH-64916)
  • Display: Casting receiving shadows was ignored in linked blocks (RH-64860)
  • File IO:
    • Read-only warning popped up when scripting a file opening (RH-64932)
    • OBJ Import - Commas as decimal separators failed (RH-65090)
    • PDF Export - Scale values did not update properly (RH-65098)
    • DWG Export - Text object was saved with incorrect annotation style (RH-65115)
    • DWG Export - Text size was incorrect (RH-65155)
    • PDF import page 2 error (RH-65250)
  • FilletCorners: Kept the wrong side (RH-21609)
  • Grasshopper: Components: "Component ID conflict" dialog showed instead of "File Conflict" on multiple conflicts (RH-65096)
  • Gumball:
    • Missing scale handles when aligning to text object (RH-64901)
    • Activating the scale handle was harder in V7 (RH-64915)
  • History:
    • Link to dimensions was broken without a warning when editing converted an extrusion to a polysurface (RH-32233)
    • Locking children too agressive with annotation (RH-49644)
    • “All” option of HistoryUpdate command did not update history child that was locked, hidden, or on a locked layer (RH-65232)
  • Layer: Layers not turned off in layouts (RH-65079)
  • MergeAllCoplanarFaces:
  • NamedSelections: Drag and drop to reorder was broken (RH-64987)
  • Options: Options causes remeshing (RH-65017)
  • PointDeviation:
    • Hair left on screen when “Display hair” was turned off (RH-65167)
    • PointDeviation - numbers do not match colors (RH-65182)
  • Print: Preview drew text with wrong colors (RH-63128)
  • QuadRemesh: Display conduit stuck when remeshing multiple objects (RH-65023)
  • RDK: Child content was not instanced with instanced parent content (RH-65040)
  • Rendering: Single color texture using object color did not render (RH-64914)
  • Rendering: Materials:
    • Plastic was exported as PBR (RH-64756)
    • Hidden materials caused confusion in object properties (RH-65041)
  • Rendering: Textures: Rendered display: mesh objects use low res simulation of procedurals (RH-64754)
  • SDK:
    • Grasshopper template in v7 did not generate a new GUID (RH-64988)
    • RhinoBrepTrim failure (RH-65209)
  • SDK: RhinoCommon:
    • Project template did not ask about WinForms/WPF (RH-64575)
    • Bug in Rhino.Geometry.Transform.GetHashCode (RH-65150)
    • Crash in VolumeMasProperties (RH-65162)
  • ScriptCompiler: Compiled GH Script using cached values (RH-65097)
  • SetPt: Pressing x, y, z keys did not toggle the checkboxes (RH-65123)
  • SubD: SubDExpandEdges - Rhino 7.x test command. (RH-65157)
Crashes Fixed:
  • tl!TL_MeshBrepFace – Access Denied (RH-64946)
Enhancements:
  • File IO: CSV Export - Saves attribute user text of top level blocks (RH-65035)
  • NamedSelections: SubD faces and edges in selection set can be post input for commands (RH-64986)
  • RDK: Material type conversion is improved (RH-64750)
  • SDK: RhinoCommon:
    • BrepFaceList.ShrinkFaces() method was broken for certain multiface breps (RH-64138)
    • Added overload to volume massprop calc to include tolerance (RH-64317)
  • SubD Symmetry: Reflect command allows existing Reflect object as input (RH-60738)
SDK Enhancement:
  • SDK: RhinoCommon:
Usability Problems Fixed:
  • Rendering: Materials: Tree mode list kept collapsing (RH-65070)
  • Rendering: Texture Mapping: UVW mapping box text windows are too small- (RH-64980)
Mac-Only Changes
Bugs Fixed:
  • File IO: PDF Export - Vector output failed on Mac if custom size * dpi was too large (RH-65116)
  • SDK: Python: A script failed on Mac (RH-65056)
  • ToolPalettes: Preferences > Tool Palettes > Hide tool palettes when starting commands: should exclude some commands (RH-65131)
Features Added:
  • Preferences: Added advanced setting to suppress tool palettes reappearing after command completes (RH-57945)
Windows-Only Changes
Bugs Fixed:
  • SelFontUse: finds hidden text (RH-65077)
Enhancements:
  • Keyboard Shortcuts: Added Ctrl+Q to quit Rhino (Exit command) (RH-64974)
  • LoadScript: Supports Windows environment variables in file paths (RH-65034)
  • Options:
    • Updates and Statistics page now shows the current version (RH-50906)
    • Double-clicking on the name of an advanced setting copies it to clipboard (RH-65122)
SDK Enhancement:
  • SDK: RhinoScript: Enhancements about alpha value of colors (RH-65170)
