Rhino 6 SR20 Release Candidate 1 for Windows and Mac (6.20.19295) is now available.
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
- Annotation: Moved fixes for arrow, text placement and forcing dimline from v7 to v6 (RH-55119)
- Annotation: Styles: Move FitText Down on Annotation Style (RH-55171)
- Display: FolderWatcher erroneously deletes texture map (RH-54934)
- File IO:
- Grasshopper:
- Patch: ClosestPoint gets wrong answer on Patch surface before adding it to the doc (RH-55152)
- Picture: Turns into black when changing color mask threshold (RH-54790)
- Properties: Move Arrow/Line controls to the Arrow Section (RH-55172)
- Purge: Purge messes up annotation text (RH-54887)
- SDK: Python:
- SDK: RhinoCommon: Comments that point to SweepTwoRail need to be adjusted (RH-55228)
- Settings: LoadProfile* doesn't set default if setting doesn't exist (RH-54905)
- ShrinkTrimmedSrf: Over splitting (RH-54987)
Crashes Fixed:
- RDK: rdk!CRhRdkContent::CImpl::IsOwnedByDocument – Access Denied (RH-55000)
- ShowNotifications: Double-click at blank area crashes Rhino (RH-54061)
Regressions Fixed:
- File IO: Dimensions lose style properties (RH-54936)
SDK Enhancement:
- SDK: RhinoCommon:
Tasks Completed:
- Tutorials: Update v6 user's guide model xml files (RH-53449)
Mac-Only Changes
Bugs Fixed:
- Dark Mode: Popup toolbar background color is incorrect (RH-54898)
- EditPythonScript: EditPythonScript not implemented on Mac (RH-44751)
- Eto: No SelectedItemsChanged event on TreeGridView when click/drag item (RH-50396)
- File IO: Obj export on Mac doesn't save the texture name within the Mtl (RH-54986)
- Grasshopper:
- NetworkSrf: NetworkSrf and History - fails on Mac (RH-55058)
- Rendering: Materials: Lock repeat icon padding has increased in texture settings (RH-55112)
- SDK: RhinoCommon: Offset component orientation inconsistent between GH for Windows and GH for Mac (RH-36841)
Crashes Fixed:
- __pthread_kill (RH-51383)
- -[MRDocumentModelWindow sendEvent:] (RH-54522)* Close: libsystem_kernel.dylib:__pthread_kill (RH-54252)
- Grasshopper: System.NullReferenceException: Object reference not set to an instance of an object (RH-55121)
Incomplete Port:
- UndoMultiple: Implement on Mac (RH-51590)
Tasks Completed:
- Build Process: Notarize the application with Apple (RH-49086)
Windows-Only Changes
Bugs Fixed:
- Properties: Properties jitters (RH-54869)
