brian
(Brian Gillespie)
1
Rhino 6 SR12 Release Candidate 1 (6.12.18345) is now available.
To get it, subscribe to the Release Candidate update stream .
Crashes Fixed:
- File IO: System.NullReferenceException: System.Windows.Forms.TreeView.CustomDraw (Message& m) (RH-49784)
Bugs Fixed:
- Camera: Camera rotation centering (RH-49770)
- DevLoft: RhDevelopableSurface::UntwistSurface() returns false when input rulings are already perfect (RH-49730)
- Display:
- Eto: System.NotImplementedException using Eto.Forms.SelectFolderDialog (RH-48720)
- File IO: FBX doesn’t export vertex colors properly (RH-48914)
- GetObject: CRhinoGetObject::SetGeometryFilter does not filter out top level SubD objects (RH-49365)
- GetPoint: Crash with really long string input (RH-49719)
- Properties: Objects names in Chair, Curve, Glass and Arrow options models (RH-49587)
- SDK: Python: rs.TextOut error (RH-49664)
- SDK: RhinoCommon: ModifyTextureMapping (RH-49440)
- Select: A request for a command to select Details (RH-46607)
- Selection: Locked definition layer does not allow selection (RH-49752)
- ShowEdges: Some SubD edges appear to be not highlighted (because some faces don’t get displayed) (RH-49419)
- SubD: SubD - Copies cannot be selected until moved (RH-49701)
- UserText: Undoing match Attribute user text deleting new Keys/Values but doesn’t recreate initial Keys/Values. (RH-49640)
Regressions Fixed:
- Sweep1: On polycurve messier than in V5 (RH-49771)
brian
(Brian Gillespie)
2
Rhino 6 SR12 Release Candidate 2 (6.12.18351) is now available.
Bugs Fixed:
- Annotation: Text:
- Font field does not remember font names in Japanese (RH-49670)
- Font field does not remember font names in Korean. (RH-49468)
- Font field does not remember font names in Traditional Chinese. (RH-49661)
- CommandPrompt: Keep degree entry for angles (RH-49749)
- Crash Processing System: Log current Grasshopper component when solving definition (RH-49463)
- Display: Edge offset (RH-49776)
- Make2D: Parallel views (RH-49527)
- SDK: RhinoCurveBoolean C++ SDK function request (RH-47891)
- SDK: RhinoCommon:
- Brep.CreateTrimmedPlane appears to be broken (RH-49888)
- RhinoDoc Open and Save events report invalid file name on Mac (RH-49887)
- SelectionFilter: Incorrectly selects SubD sometimes (RH-49849)
- SystemInfo: Should show hybrid video information (RH-49754)
Features Added:
- RDK: Color DragItems for the Mac (RH-49743)
brian
(Brian Gillespie)
3
Rhino 6 SR12 Release Candidate 3 (6.12.19008) is now available
Bugs Fixed:
- Cycles: Matte materials raytrace all black using cubin files compiled with CUDA 10 (RH-49636)
- Delete: Deleting lots of history objects and parents is slow (RH-49741)
- Display: GH text tag does not show in layout (RH-50142)
- EdgeSrf: Leaks memory (RH-49971)
- File IO: Error message on cancel (RH-49871)
- Localization: Typo in en-usEtoRdkUI.xml (RH-49954)
- Make2D:
- Mesh: UnweldVertex: Should work with SubD vertices? (RH-49762)
- No Subsystem: Floating previews are white while resizing (RH-49955)
- Print: Picture not Printing with Detail Clipping to Rhino PDF (RH-49079)
- Purge: Hatch in block changes pattern on purge, save and reopen (RH-49808)
- RDK:
- CRhRdkTexturedContentField is essentially useless (RH-43752)
- DragDrop datasource for Content Library Dialog (RH-49734)
- Rendering:
- Adjusting saturation for an HDR in a Renv affects lighting intensity too much (RH-38732)
- Custom render meshes are not rendered by third party renderers (RH-50072)
- SDK: RhinoCommon: Wish - Add linked or linked/embedded instance definition to File3dm (RH-49968)
- SelectionFilter: Sub-objects checkbox visibility (or general case) sizing bug (RH-49817)
- ShowEdges: Zoom action improvement (RH-49928)
- SubD Editing: Missing SubD faces when extruding an Ngon with creased edges (RH-49815)
- SubDFromMesh:
- Change the name of SubDfromMesh to ToSubD (RH-49840)
- ToSubD - remove shaded in all views option. (RH-49991)
- Subobject Selection: Select one menu has wrong texts (RH-49986)
Crashes Fixed:
- Cycles: :CUDADevice::reserve_local_memory – Access Denied (RH-48541)
- No Subsystem: Commands.ViewModels.MeshRepairWizardViewModel.UpdateCheckStatesAndLog () (RH-49882)
- Rendering: rdk!ShrinkDataInt – Access Denied (RH-49175)
Enhancements:
- Explode: Exploding linked block makes all layers visible (RH-49038)
- Snapshot:
- MatchSnapshot command added to copy snapshot object properties (RH-50000)
- Simple drag and drop added to snapshot panel (RH-50001)
Features Added:
- SDK: RhinoCommon: Have a way to tell an ObjectPropertiesPage (or other panel hosts) when they are closed/disposed (RH-49990)
brian
(Brian Gillespie)
7
Rhino 6 SR12 Release Candidate 4 (6.12.19016) is now available
Bugs Fixed:
- Localization: Export > X3D dialog > Title is not localized (RH-50326)
- RDK: Raytraced backface materials broken (RH-43896)
- RectangularLight: Pre-pick manipulation of rectangular light doesn’t allow snapping to corners (RH-49551)
- SDK: Python: Update samples to use != (RH-49811)
Crashes Fixed:
- Cycles: Sporadic crash with during creation of content field. (RH-50232)
