brian
(Brian Gillespie)
1
Rhino 6 SR8 Release Candidate 1 (6.8.18205) is now available.
To get it, subscribe to the Release Candidate update stream.
Crashes Fixed:
- No Subsystem:
- RhinoCore!CCommandZoom::DynamicOption – Access Denied (RH-47328)
- RhinoCore!CRhinoDisplayEngine_OGL::GetDepthBuffer – Access Denied (RH-47292)
Bugs Fixed:
- Cycles: OpenGL 3.3 does not have Cycles use software drawing correctly (RH-47222)
- Display: White space missing from text (RH-47173)
- Export: IGES tolerance input is locale sensitive (RH-47046)
- File IO: Materials skipped (RH-47290)
- Rendering: Realtime SDK: Toggling layer visibility doesn’t send proper events for lights (RH-47221)
- SDK: Python:
- AddAlignedDimension Bug (RH-33507)
- Rhinoscriptsyntax rs.AddSphere plane input bug (RH-30726)
- rs.BoundingBox not quite right when one of the objects isn’t a geometry object (RH-44277)
- SDK: RhinoCommon: File3dmObjectTable needs AddInstanceReference method (RH-45450)
- SquishInfo: Result is a mesh in v6 but a surface in v5 (RH-42734)
- Surface-surface intersection: Intersector leaves a gap at the pole. (RH-46900)
- ToNURBS: ToNURBS - patches missing at corners (RH-47006)
- UVEditor: Texture not working in VRay (RH-35735)
brian
(Brian Gillespie)
3
Rhino 6 SR8 Release Candidate 2 (6.8.18211) is now available.
Crashes fixed:
- SDK: RhinoCommon: RevSurface.Curve getter crashes Rhino (RH-47447)
- Safe Frame: RhinoCore!CRhinoDisplayPipeline::Draw2dLine – Access Denied (RH-47410)
Bugs fixed:
- Annotation: Rhino 5 Dimension Loose user text modifications (RH-47471)
- Annotation: DimLinear: Dimension lines draw past extension lines (RH-47357)
- Annotation: DimOrdinate: Detail scale not applied to Ordinate dimensions read from V5 files (RH-47476)
- Annotation: Leader: Leader arrows go missing (RH-47266)
- Block:
- Mesh Sphere in Block Shows Wireframe in Shaded or Rendered Modes (RH-44695)
- Meshes in Block Object Does Not Render (RH-44778)
- Display:
- Dots text is clipped (RH-45913)
- Rhino 6 Slow Display with 15,000 meshes (RH-47430)
- Rotation view in Rendered display mode of Rhino 6 is very slowly (RH-41149)
- Vertex size ignored in V6 display modes (RH-46816)
- Eto: Can Panel.MinimumSize take into account DPIScale like Size or ClientSize does? (RH-40307)
- File IO:
- Critical Point tag locking up import (Import GHS) (RH-42212)
- VRML import broke in recent builds of V6 (RH-47341)
- Print:
- Color Source Support in ViewCaptureSettings (RH-45512)
- Multiple Pictures on Layout - Print Issue (RH-47322)
- RDK: Content order in ContentDisplayCollection DS (RH-46994)
- Rendering: Texture Mapping: Yellow tip on Texture Mapping dialog sometimes has the wrong position (RH-47219)
- SDK: RhinoCommon: Mesh.Append slow (RH-47320)
- Safe Frame: Does not draw correctly in a detail view (RH-47440)
- TextField: Show the function result (RH-46107)
brian
(Brian Gillespie)
4
Rhino 6 SR8 Release Candidate 3 (6.8.18219) is now available.
Bugs Fixed:
- Annotation: Resize the dimension editing dialog (RH-47289)
- ClippingPlane: Dots on active clipping planes go black (RH-47524)
- Display: Some blocks display as wireframe (RH-47467)
- Print: There is a display mode that will not shade in Layouts (RH-46899)
- PrintPreview: LayoutLinetypes is broken (RH-46526)
- SDK: RhinoCommon’s MaterialTable.Find does not work (RH-47366)
- SDK: RhinoCommon:
- Expose RhinoBrepRemoveInnerLoops in RhinoCommon (RH-47288)
- Smoothing Specific Mesh Vertices (Rhinocommon) (RH-47443)
- TextEntity.GetBoundingBox() returns incorrect BoundingBox (RH-44507)
Cosmetic Bugs Fixed:
- Display: Aliased lines have inconsistent width (RH-46636)
brian
(Brian Gillespie)
5
Rhino 6 SR8 Release Candidate 4 (6.8.18226) is now available.
Bugs Fixed:
- Display: Line and Arrows turn white (RH-47474)
- Eto: Profiler showing slowness at Bitmap.Width (RH-46860)
- ExtendSrf: Incorrect error message (RH-47351)
- File IO: Garbled characters in layer names (RH-47193)
- Make2D: HiddenLineDrawing does not calculate point geometry (it did in V5) (RH-46391)
- Print: Image incorrect at higher resolution (RH-20130)
- Properties: ObjectPropertiesPageEventArgs is throwing Exceptions (RH-47567)
brian
(Brian Gillespie)
6
Rhino 6 SR8 Release Candidate 5 (6.8.18230) is now available.
Bugs Fixed:
- Display: Clayoo objects don’t update their render meshes in Rendered mode. (RH-44353)
