Rhino 6 SR19 RC1 for Windows and Mac (6.19.19267) is now available
To get it, subscribe to the Release Candidate update stream on Windows or Mac.
Bugs Fixed:
- Annotation: DimLinear: With no Draw forward correction, Dimension text may orient wrong (RH-54734)
- File IO:
- Join: Join - Preselected surface edge cannot be joined to other surface edges (RH-54533)
- Print: Surface edge color incorrect when printing selected objects in shaded mode (RH-38049)
- PrintPreview: Linetypes are not displayed at correct scale (RH-54532)
- SDK: Make a RhinoCommon function for RhinoGetPointInsideSolidBrep (RH-54687)
Cosmetics:
- PointDeviation: PointDeviation dialog - labels don't align with lines (RH-54483)
Crashes Fixed:
- : opennurbs!ON_HistoryRecord::`RTTI Complete Object Locator' – Access Denied (MERGE) (RH-54599)
- Display: RhinoCore!CTextureFileNotifier::AddFile – MERGE (RH-54376)
SDK Enhancement:
- SDK:
Usability Problems Fixed:
- Drag: Can't drag a whole polyline when it is already selected (RH-54726)
Mac-Only Changes
Bugs Fixed:
- ApplyDisplacement: Render mesh disappear (RH-54466)
- AutoSave: Rhino freeze (RH-54268)
- BlendCrv: BlendCrv Edit option is broken (RH-54419)
- Developer Tools: Update CI and bootstrap versions (RH-54689)
- DragMode: DragMode broken on V6 for MAC (RH-54650)
- EditPythonScript: Needs to support Dark Mode (RH-54446)
- Grasshopper:
- Length:
- Offset: Length, Radius and Distance don't work on Mac (RH-40859)
- Preferences: Fails to import custom tool sets (RH-54733)
- Radius: Nested Radius command does not work properly (RH-54743)
- Rebuild: Make the numbers work out (RH-47425)
- Rendering: Realtime SDK: Raytraced Mode HUD and its icons too small (RH-53497)
- RotateView: UI for new viewport rotation option needed (RH-39598)
- Selection: SelID fails nested on Mac (RH-49457)
- SelectionFilter: Command-line filter "Edge" is unknown (RH-45951)
- Split: Command line cannot accept Sel commands (RH-38056)
- Subobject Selection: Subcurves can't be extruded with Gumball (RH-42036)
Crashes Fixed:
- AutoSave: Rhino freezes during Autosave when embedding Mono 6.0.0 (RH-54290)
- RDK: Crash when attempting to use ToMeshArray() on a RenderPrimitiveList (RH-44411)
Features Added:
- LayoutWorkspace: No way to display Osnap toolbar in Layout editor (RH-52543)
- SelectionFilter: Can't type nested commands on Mac (RH-45950)
Incomplete Port:
- CursorTooltip: Cursor tool tips offset (RH-51573)
- Grasshopper: GH Window disappears when Rhino isn't the active application (RH-50695)
- Preferences: Missing control point styles on Mac (RH-53848)
- SDK: GHPython: Code completion / auto indent in GhPython on macOS (RH-54435)
- UndoSelected: Not yet implemented (RH-52440)
Regressions Fixed:
- ShowSelected: SelColor in hidden objects requires new selection - not so in RH5 (RH-46716)
- Gumball: Pressing Space in value entry does not function as Enter (RH-36510)
Windows-Only Changes
Crashes Fixed:
- Grasshopper: Components: Populate Geometry crash (RH-53872)
Tasks Completed:
- Options: Move Control Point Style above Visibility (RH-54813)
