brian
(Brian Gillespie)
October 31, 2023, 10:50pm
1
Rhino 8 SR1 Release Candidate 1 for Windows and Mac (8.1.23304) is now available
Requires Rhino 8
To get it, subscribe to the Release Candidate update stream on Windows or on Mac
Bugs Fixed:
Code Editor Control: copy and pasting code from old to new script component doesn't work (RH-75936 )
Containers:
Display style doesn’t change properly (RH-77536 )
When the toolbars are in Docked Side > Vertical, only “image only” works (RH-77629 )
Display:
Section edge shows through all objects (RH-77944 )
Clipping boundaries have inconsistent width (RH-77310 )
DupEdge: SubD DupEdge with history: extracted curve will switch to flat or smooth mode after SubD update (RH-77419 )
ExtractClippingSections:
Color of Custom “Section Style on Object” Not Being Applied to Clipping Drawing (RH-76692 )
Section Picking inconsistency (RH-77089 )
File IO:
UV island layout is not maintained in FBX export (RH-73503 )
Texture repeat values are not saved to FBX (RH-67020 )
WCS mapping doesn’t export to FBX (RH-67021 )
Custom UV map doesn’t save in Obj unless multiple mapping channels are used (RH-73999 )
glTF import supports reading layers (RH-72441 )
Fillet: Filleting curve result is dependent on clicked point (RH-77716 )
Gumball:
Cut operation makes extrusion disappear (RH-77673 )
Wrong preview when duplicating a face with the Gumball (RH-75397 )
Icons: Sidebar icons look blurry (RH-77950 )
LayerStateManager: Model On state is not restored (RH-77719 )
Layout: Layouts panel slows down zooming in and out with the mouse wheel (RH-77331 )
Localization: Mix of decimal separator usage (RH-77457 )
Make2D: Mesh sections are not occluding (RH-77414 )
MergeAllCoplanarFaces: Merging mesh faces leaves vertices (RH-77042 )
MeshTrim: Bad result when vertices overlapped (RH-31115 )
Options: Set CPlane view rotation via macro (RH-61235 )
Print: Preview showing lines of hidden geometry (RH-77340 )
ProjectToCPlane: Polycurves consisting of arcs project to self (RH-77924 )
Rendering: Render Window menu doesn't remember check states (RH-77329 )
Rendering: Content Panels: Copy Paste problems with Render Contents (RH-77534 )
Rendering: Cycles: Environment intensity issue (too dark) (RH-55126 )
Rendering: Presets: Allows customizing preset render sizes with render_sizes.txt (RH-77313 )
Rendering: Texture Mapping: OBJ export doesn't save WCS mapping settings (RH-54697 )
Rendering: Textures:
Don’t get embedded when copying and pasting geometry between documents (RH-77726 )
OBJ export issue having to do with texture coordinates (RH-50379 )
Section Tools:
NestedClippingDrawing command won’t change hatches in current model session (RH-77573 )
ClippingDrawings: Section hatch background color not displaying (RH-77431 )
ClippingDrawings command stacks labels (RH-77377 )
SelectionFilter: Lost on view manipulation (RH-77002 )
Subobject Selection: Ctrl+Shift+Double click edge selection does not work 100% of the time (RH-77897 )
Enhancements:
File IO:
Export DWG: identify skipped objects (RH-77693 )
Make layer order for reading and writing acad files predictable (RH-48103 )
Added an advanced setting for removing the extra dot in locking file extension [.3dm.rhl] (RH-77475 )
Supports exporting lines, polylines, and curve piping meshes to glTF (RH-73227 )
DWG/DXF import and export support groups (RH-77296 )
DWG/DXF Export supports saving AutoCAD 2010, 2013, & 2018 files (RH-77297 )
DWG/DXF Import supports reading groups (RH-15122 )
glTF export supports sub-object materials (RH-76510 )
Gumball: Cut handle now works with meshes (RH-76483 )
Layer: Layer color picker preview color in viewport (RH-77460 )
Rendering: Content Panels: Add material and environment duplication next to the source (RH-71587 )
SelVolumeObject: Added Window/Crossing/InvertWindow/InvertCrossing options (RH-1759 )
Features Added:
OSnap:End: OSnap: End: Snap to clipped curve (RH-76997 )
Regressions Fixed:
Block: Nest and Embedded Block Duplicates When All Blocks are Reloaded (RH-77602 )
ExtendSrf: Numeric input does not give the correct result (RH-65347 )
Make2D: No output from clipped mesh (RH-76378 )
Rendering: Texture Mapping: v8 loses mapping info and defaults to surface when exporting fbx and obj (RH-77115 )
SDK Enhancement:
SDK: RhinoCommon: Exposed CRhinoAppViewSettings::SetViewSettings (RH-77515 )
Usability Problems Fixed:
BlockManager: Performance issue sample (RH-77982 )
Mac-Only Changes
Bugs Fixed:
UI Appearance: Mac inactive tabs are too difficult to read (RH-77171 )
Enhancements:
Paste: SVG file can be copied from Finder and pasted into Rhino viewport (RH-77813 )
UI Change:
StatusBar: Removed "Available physical memory" and "CPU Use" from Info pane on Mac (RH-77200 )
Windows-Only Changes
Features Added:
SelChain: Allows view manipulation when selection menu appears (RH-75789 )
brian
(Brian Gillespie)
November 8, 2023, 12:05am
3
Rhino 8 SR1 Release Candidate 2 for Windows and Mac (8.1.23311) is now available
Requires Rhino 8
Bugs Fixed:
Retain print settings for file after rhino restart (RH-77614 )
Display Metal: Rendered viewport shows colorful artifacts on Mac Rhino 8 (RH-77271 )
Gumball: Cut action always creates bad results from meshes (RH-77841 )
Print:
Image size and dpi (RH-76437 )
Vector output of solid hatches fail in details (RH-78015 )
SDK: RhinoCommon: Rhinocommon Leader class has typo in DuplicateShallowHelper which returns a LinearDimension instead of Leader (RH-78041 )
ScriptEditor:
Problems panel icon stays red after closing a code with problems (RH-78130 )
Ensure C# scripts can reference binaries that do not have .dll extension (RH-78079 )
Missing Bitmap and Parallel in IronPython (RH-78129 )
Enhancements:
File IO: Export DWG: identify skipped objects (RH-77693 )
PushPull: Added Loose option (RH-76269 )
Features Added:
Grasshopper: Components: Set Model Linetype and Hatch Scale in Grasshopper (RH-77367 )
Regressions Fixed:
Display: Sub-object editing a SubD doesn't shade the preview anymore (RH-78065 )
Mac-Only Changes
Bugs Fixed:
Annotation: Hatch: Unable to use custom hatch patterns (RH-77747 )
Core Architecture: Idle Handler Affects Trackpad Performance (RH-78073 )
brian
(Brian Gillespie)
November 15, 2023, 12:07am
4
Rhino 8 SR1 Release Candidate 3 for Windows and Mac (8.1.23318) is now available
Requires Rhino 8
Bugs Fixed:
Delete: Fails to delete mesh edges (RH-56326 )
Layer: Layers panel not ending undo record (RH-78325 )
Localization: FitCurveToSurface shows comma in result (RH-78237 )
Print:
Raster output with extended view shows a blank print (RH-60027 )
Does not remember destination (RH-19435 )
Subobject Selection: SubD face selection is harder (RH-78173 )
TextObject: Text editing field not visible (RH-78227 )
Toolbar: Cannot close Rhino's default toolbar collection (RH-76105 )
Crashes Fixed:
Rendering: Textures: Crash bug when reusing blend texture (RH-78144 )
Enhancements:
Grasshopper: Create Get Plane Context Component (RH-76599 )
Print: Rhino PDF remembers DPI setting (RH-57008 )
Mac-Only Changes
Bugs Fixed:
Rendering: Materials: Sliders misbehave (RH-78222 )
brian
(Brian Gillespie)
November 22, 2023, 12:38am
5
Rhino 8 SR2 Release Candidate 1 for Windows and Mac (8.2.23325) is now available
Requires Rhino 8
Bugs Fixed:
Annotation: Linetype: (Sometimes) double width on windows (RH-78031 )
Bridge: Options dialog does not display Dark mode (RH-78377 )
CPlane: AutoAlign: Ngon failure sample (RH-78462 )
CurvePiping: Material tab (RH-78405 )
GCon: Incorrectly reports G2, instead of G1, between surface edges (RH-78419 )
Grasshopper: Bounding box is not flat until curve is flipped (RH-78284 )
Lights: Light panel falloff doesn't change on first time (RH-78311 )
LoadPlugin:
Pufferfish doesn’t run in GH in Rhino 8 (RH-78382 )
Add support for multi-targeting plugins to have specific assemblies for .NET Core vs. .NET Framework (RH-76604 )
OSnap: "Snap to occluded object" does not work properly in Rendered display mode (RH-78334 )
Rendering: Cycles: Physical Sky Texture not rendering in Raytraced / Rhino Render (RH-78269 )
Rendering: Materials: gLTF format doesn't save texture repeat values (RH-75896 )
SDK: CRhinoAppSettings::ShowOsnapDialog no longer works (RH-78331 )
ScriptEditor: Script fails to determine language from lang id specifier line (RH-78488 )
Toolbar:
ClosestPoint icon is missing (RH-78459 )
PopupToolbar glitch with Layers (RH-78366 )
UI Cleanup: Automatic UI sections show all sections even the empty ones (RH-78049 )
Crashes Fixed:
Eto: System.Exception: Could not initialize an instance of the type 'Foundation.NSUrl': the native 'initFileURLWithPath:isDirectory:' method returned nil. (RH-77593 )
FilletSrfToRail: FilletSurfaceToRail grashopper Crash (RH-74236 )
Enhancements:
Gumball: Cut operation shrinks the faces made from cutters surfaces (RH-78274 )
SelLayer: Tuned up pre-selection procedure of the scriptable command (RH-78335 )
SDK Enhancement:
SDK: RhinoCommon: Allows toggling visibility of Selection Filter panel (RH-78332 )
Mac-Only Changes
Bugs Fixed:
Display Metal:
Section hatches in Monochrome (RH-77797 )
Ghosted clipped part of geometry in shaded technical (RH-78208 )
Layer: Column header tooltips (RH-76570 )
UI Appearance: Mac command feedback is too slow and distracting (RH-77197 )
Bugs Fixed:
Rendering: Rendering through Frame buffer increases memory usage (RH-77045 )
brian
(Brian Gillespie)
November 29, 2023, 8:35pm
6
Rhino 8 SR2 Release Candidate 2 for Windows and Mac (8.2.23333) is now available
Requires Rhino 8
Bugs Fixed:
Dark Mode: Set dark mode by code (RH-78558 )
Display: Block: Text In Block Not Displayed Horizontal to View (RH-75332 )
FilletSrfToRail: FilletSrfToRail Fails (RH-77869 )
Grasshopper: Bug with referencing materials with textures and then baking (RH-77986 )
Grasshopper: Components: Data Output (GH DATA) component error in Rhino 8 (RH-78397 )
Gumball: gumball scale handles not displayed when it's set to object for decals (RH-78538 )
Regressions Fixed:
Offset: In Grasshopper 1 / V8, setting corner style to 0 (no extension) fails on polycurves (RH-78581 )
Subobject Selection: SubD face selection is still harder for non-planar ngons (RH-78578 )
Mac-Only Changes
Features Added:
LoadPlugin: Plugins: Create version-specific MacPlugIns folder and load plugins from there (RH-78149 )
brian
(Brian Gillespie)
December 5, 2023, 11:40pm
7
Rhino 8 SR2 Release Candidate 3 for Windows and Mac (8.2.23339) is now available
Requires Rhino 8
Bugs Fixed:
CPlane: AutoAlign: AutoAlignCPlane should be disabled by default (RH-78691 )
File IO: Export svg: keep the join (RH-78778 )
Grasshopper:
Content Cache causes Page Layout to lag. (RH-78823 )
Extrude curve failure (RH-76758 )
IntersectTwoSets: IntersectTwoSets and worksesisions (RH-78724 )
Selection: Selection - dots and layouts (RH-78771 )
Toolbar: Removing a new Toolbar button does not work (RH-78350 )
UI Appearance: Rhino needs a restart to be able to see a deleted button (RH-77523 )
Regressions Fixed:
Grasshopper: Components: data conversion failed from extrusion to surface (RH-78595 )
Rendering: Realtime SDK: Bella outputs error messages and fails to render objects (RH-78709 )
Mac-Only Changes
Bugs Fixed:
Splash and About: Copy-Paste from the About dialog (RH-69006 )
brian
(Brian Gillespie)
December 13, 2023, 12:39am
8
brian
(Brian Gillespie)
December 20, 2023, 6:44pm
9
Rhino 8 SR3 Release Candidate 2 for Windows and Mac (8.3.23354) is now available
Requires Rhino 8
Bugs Fixed:
Annotation: Text: Text Panel does not show any option (RH-79011 )
Containers: PopUp a container blanks the buttons on the floated version (RH-78476 )
Print: to pdf: closed polyline does not render well (RH-79094 )
ScriptEditor: References assemblies in #r do not work in python (RH-79116 )
Toolbar:
Duplicating a button needs the Macros command to properly change the tooltip (RH-79138 )
missing icons in select dimensions toolbar (RH-78748 )
Missing icon in visibility toolbar (RH-78756 )
WindowLayout: Duplicate sidebars on Mac (RH-70348 )
UI Appearance: RhinoArtisan: Space on top of command prompt in Rhino for Windows (RH-78557 )
Features Added:
Toolbar: allow flyouts as menus (RH-67717 )
Regressions Fixed:
ScriptEditor:
CPython Point3d non-iterable problem (RH-79162 )
“Out” parameter on new Script component is not removable from ZUI interface (RH-78322 )
Grasshopper component does not show previews on output parameter (RH-79120 )
ScriptEditor:
Grasshopper window drags really slowly when there are many script components placed on the canvas (RH-79189 )
Add import math
to python template scripts in editor and Grashopper (RH-79154 )
Modify python error diag to say use .NONE instead of .None (RH-79152 )
Mac-Only Changes
Bugs Fixed:
Print: can no longer export to a vector PDF in Pen mode, or even shaded. (RH-79092 )
Features Added:
Rendering: Post Effect: Intel denoiser is now integrated into Rhino 8.3 and works on Apple Silicon (RH-71149 )
Bugs Fixed:
ScriptEditor: ScriptEditor Crash with SaveAs same file name (RH-79103 )
brian
(Brian Gillespie)
December 26, 2023, 10:53pm
10
Rhino 8 SR3 Release Candidate 3 for Windows and Mac (8.3.23360) is now available
Requires Rhino 8
Bugs Fixed:
Options: Toolbar Options Page: Eliminate weird macOS UI (RH-78781 )
Toolbar: Difficult to close "Default Toolbars" when importing from Rhino 7 RUI (RH-78858 )
Regressions Fixed:
Grasshopper: Extruding surface issue (RH-79261 )
ScriptEditor: GH Python3 output polyline is different from IronPython (RH-79323 )
Bugs Fixed:
No subsystem: Add Toolbars page that Links to new Location (RH-78184 )
brian
(Brian Gillespie)
January 2, 2024, 11:39pm
13
Rhino 8 SR3 Release Candidate 4 for Windows and Mac (8.3.24002) is now available
Requires Rhino 8
Bugs Fixed:
Linetype Width Set to Pixels Not Displaying or Printing (RH-79349 )
Linetype Width and Pattern Scale Incorrect on Layout (RH-78703 )
Breps Linetype Width Not Previewing or Printing with Vector (RH-79352 )
Print:
Closed polyline missing a segment (RH-79094 )
Vector PDF output from technical creates white hatch (RH-79221 )
Raster printing makes lines thicker and thicker (RH-79212 )
Rhino Installer Engine: Installed plugin appears twice in the Menu (RH-78113 )
ScriptEditor:
Use Object does not load when base component updates legacy parameters to new ones (RH-79338 )
Non-single file assemblies fail to load in Pythonnet (RH-78289 )
Toolbar:
Difficult to close “Default Toolbars” when importing from Rhino 7 RUI (RH-78858 )
Replace gear with menu (RH-79395 )
Delete Toolbar when no buttons exist (RH-79369 )
Regressions Fixed:
Print: Control points on "single selected" Objects Print (RH-79362 )
brian
(Brian Gillespie)
January 10, 2024, 1:35am
14
brian
(Brian Gillespie)
January 17, 2024, 6:30pm
15
Rhino 8 SR4 Release Candidate 2 for Windows and Mac (8.4.24016) is now available
Requires Rhino 8
Bugs Fixed:
Options dialog glitch (RH-79684 )
IRhinoUiHolder doesn’t work for VRay (RH-79667 )
Layer:
Rhino 8 - Duplicate Layers (RH-79755 )
Layers panel visible slows down OSnap checkboxes (RH-79587 )
Offset: result is open (RH-78620 )
Print:
Some objects in layouts are not printing in technical vector output (RH-79070 )
Vector PDF draws unexpected intersection (RH-79539 )
Fake2d Not Invoked When Printing Layouts (RH-79629 )
Details in Technical draw heavier silhouettes (RH-79527 )
ScriptEditor:
Python error line is wrong in GH when importing gmsh (RH-79662 )
Unset outputs will use the persistent value from previous runs (RH-79615 )
Toolbar: Layout macros missing (RH-79591 )
VariableFilletSrf: : Ugly preview (RH-79549 )
Crashes Fixed:
ExportOptions: Rhino closes suddenly Rhino 8.4 RC4 (RH-79616 )
Toolbar: Crash in new toolbar (RH-79717 )
Regressions Fixed:
Print:
Hidden edges not drawn in vector PDF (RH-79735 )
Visible edges not drawn in vector PDF (RH-79734 )
Bugs Fixed:
DocumentProperties: Left column top alignment (RH-79518 )
brian
(Brian Gillespie)
January 24, 2024, 1:19am
16
Rhino 8 SR4 Release Candidate 3 for Windows and Mac (8.4.24023) is now available
Requires Rhino 8
Bugs Fixed:
OSnap one shots disabled if persistent Osnaps are disabled. (RH-79867 )
Layout: Snapping fails in layout (RH-79912 )
Print:
Preview size issue (RH-79897 )
Vector PDF output from technical - issue sample file - II (RH-79808 )
Print misses single pixel hatch (RH-79860 )
ScriptEditor: Error in Python 3 exception parser (RH-79830 )
Crashes Fixed:
ScriptEditor: Script Editor crashes Rhino8 when C# script is changed from VisualStudio (RH-79763 )
Regressions Fixed:
Print: Fitting Print to Paper Not Expected (RH-79932 )
ScriptEditor:
Legacy Python component has multiline standard output (RH-79618 )
Add Rhino appdata scripts paths to sys.path (RH-79864 )
Mac-Only Changes
Bugs Fixed:
OSnap panel doesn't sync during GetPoint operations on MacOS (RH-79825 )
Regressions Fixed:
Print: MAC: Trimmed Picture Causing Incomplete Vector Print On Layout (RH-79865 )
brian
(Brian Gillespie)
January 31, 2024, 7:23pm
17
Rhino 8 SR4 Release Candidate 4 for Windows and Mac (8.4.24030) is now available
Requires Rhino 8
Bugs Fixed:
Print:
Destination Image : Image Scale too large (RH-80036 )
In Model scale and On Paper scale controls unresponsive (RH-80003 )
ScriptEditor: PIP sometimes gets stuck when installing package (RH-80090 )
Trim: Unexpected behavior (RH-80000 )
UVEditor: Unwrap of a Rhino 7 custom unwrapped mesh is bad (RH-79784 )
Crashes Fixed:
Menu: Adding menu item crashes Rhino (RH-79874 )
ScriptEditor: importing ghpythonlib module crashes Rhino (RH-79982 )
brian
(Brian Gillespie)
February 7, 2024, 12:31am
18
Rhino 8 SR4 Release Candidate 5 for Windows and Mac (8.4.24037) is now available
Requires Rhino 8
Bugs Fixed:
Display: Print width is not turned off (RH-79770 )
Print: Technical view intersection lines do not honor layer print color (RH-28051 )
ScriptEditor: ghdoc is not set for external scripts (RH-80140 )
Crashes Fixed:
ScriptEditor: Python 3 marshaller crashes on self referencing objects (RH-80142 )
Regressions Fixed:
Edit Dimension: Inch Fractional Dimensions missing a space (RH-80143 )
ScriptEditor:
Command history is not clear with Script: Run or :Edit commands (RH-80272 )
Script Editor does not clear prompt after running script (RH-80271 )
brian
(Brian Gillespie)
February 14, 2024, 5:13am
19
brian
(Brian Gillespie)
February 15, 2024, 6:00pm
20
Rhino 8 SR5 Release Candidate 2 for Windows and Mac (8.5.24046) is now available
Requires Rhino 8
Bugs Fixed:
Display: Technical draws random intersections (RH-79288 )
Print: Far from origin hatches and printing (RH-80436 )
RDK: Automatic UI Combobox control value does not stick. (RH-80440 )
Crashes Fixed:
Rebuild: Command: opennurbs!ON_EvaluateNurbsSpan – Access Denied (RH-80406 )
brian
(Brian Gillespie)
February 17, 2024, 1:55am
21
Rhino 8 SR5 Release Candidate 3 for Windows and Mac (8.5.24047) is now available
Requires Rhino 8
Bugs Fixed:
Rebuild: Rebuild- no deviation feedback (RH-80458 )
Rendering: Texture Mapping: New test command TestFillInLegacyTextureCoordinates (RH-80470 )
ScriptEditor: Reopen glitch (RH-79718 )
Toolbar: Make it scriptable (RH-77225 )
Regressions Fixed:
Print: Printer Margins Not Displayed In Preview (RH-79930 )
brian
(Brian Gillespie)
February 21, 2024, 12:33am
22
Rhino 8 SR5 Release Candidate 4 for Windows and Mac (8.5.24051) is now available
Requires Rhino 8
Bugs Fixed:
Copy: Can't snap to block object after _Copy (RH-80472 )
Crashes Fixed:
Rendering: Cycles Viewport: Crash changing gamma setting with active Raytraced (RH-80480 )
