brian
(Brian Gillespie)
1
Rhino 6 SR13 Release Candidate 1 (6.13.19031) is now available.
To get it, subscribe to the Release Candidate update stream .
Bugs Fixed:
- Annotation: DimLinear: History update broken (RH-50567)
- Cycles: Hide RhinoCycles commands (RH-43926)
- Decals: Not showing in Rendered mode (RH-49902)
- Display: Edges too bright (RH-33240)
- Insert: Angle setting uses radians instead of degree (RH-50074)
- Installer: Does not add render content with repair or new install (RH-40843)
- Interface: Command line parsing of angles typed as negative degrees,minutes, seconds is wrong (RH-50479)
- No Subsystem: C++ SDK has been broken (RH-50534)
- RDK: Custom Render meshes don’t show in an otherwise empty Rhino document. (RH-46486)
- SDK: RhinoCommon: Zoo template needs to create object that inherits from IZooPlugIn3 (RH-44458)
- SDK: RhinoScript: Rhino.RotateView direction parameter not optional (RH-50486)
- Space Ball:SpaceMouse: 3DxRhino Fix view changes are not undoable when they originate from navigating (RH-50478)
Cosmetics:
- Localization: Japanese: Export > Adobe Illustrator dialog > Preserve model scale needs more width (RH-50273)
Crashes Fixed:
- Loft: tl!__chkstk – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-50497)
- Offset: tl!TL_EvBezier – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-50447)
Enhancements:
- Display: Warn user when OpenGL driver date older N months (RH-44512)
- OffsetSrf: Made output object adopts material from input object (RH-42584)
- SDK: Need function to split Brep with one or more Breps (RH-42917)
- UserText: Dashed Properties command should work for AttributeUserText (RH-50144)
Regressions Fixed:
- Display: It appears that one or more of the texture filtering features is/are no longer working. (RH-49245)
- OffsetSrf: Incorrectly splits the output surfaces (RH-45266)
brian
(Brian Gillespie)
3
Rhino 6 SR13 Release Candidate 2 (6.13.19035) is now available.
Crashes Fixed:
- RDKCrash: rdk!CTextureBakingAppearanceFingerprintIdentification::Identify – Access Denied (RH-50222)
Regression:
- UnwrapTextures: Previous seam selection in Unwrap doesn’t work (RH-43492)
SDK Enhancement:
- SDK: Needs function to split Brep with one or more objects (RH-42918)
brian
(Brian Gillespie)
4
Rhino 6 SR13 Release Candidate 3 (6.13.19043) is now available.
Bugs Fixed:
- Annotation: DimAngular: Curve thickness set in display modes mistakenly applies to Angle dimensions (RH-50485)
- Eto: Eto dialogs using Python no longer work in SR13 (RH-50633)
- Localization: Localize Rhino 6 Level 1 Models (RH-48176)
- Update System: Driver check link URL gives server error (503) (RH-50644)
Crashes Fixed:
- MergeEdge: RhinoCore!AdjacentEdge – Access Denied (RH-50039)
- No Subsystem: Crash on localized versions of Rhino while rendering previews (RH-49180)
- Rebuild: Crash rebuilding closed curves (RH-50639)
Features Added:
- Cycles: Textured emission channel on Cycles Emissive (RH-45658)
SDK Enhancement:
- Cycles:
- Raytraced doesn’t handle Octane simulated material properly (RH-50327)
- Set up custom material integration geared towards PBR (RH-50133)
- SDK:
- Add Shadow Only Groundplane to SupportsFeature for RenderPlugins (RH-32333)
- Variable Offset Surface SDK function request (RH-31830)
- SDK: RhinoCommon:
- Documentation for RhRdk::Realtime::ChangeQueue (RH-32016)
- Documentation for RhRdk::Realtime:DisplayMode (RH-32017)
- Hook up proxy command system in RhinoCommon (RH-48280)
brian
(Brian Gillespie)
5
Rhino 6 SR13 Release Canddiate 4 (6.13.19046) is now available:
Bugs Fixed:
- Localization: Object Description dialog shows English strings (RH-50618)
Crashes Fixed:
- SDK: RhinoCommon: Crash with preview rendering (RH-50823)
Enhancements:
- Grasshopper: Components: Grasshopper Components Update Kangaroo to v2.5.0 (RH-50768)
Regression:
- Annotation: Font in drop-down changes to Arial when highlighting text using “Gill Sans MT Condensed” font (RH-50733)
SDK Enhancement:
- Cycles: Adding new Octane material while Raytraced running then using it doesn’t properly update (RH-50762)
