Rhino 6 SR 15 Release Candidate Available
Rhino 6 SR15 Release Candidate 1 (6.15.19120) is now available.
To get it, subscribe to the Release Candidate update stream .
Bugs Fixed:
  • Annotation: Case Buttons are too big (RH-51351)
  • Annotation: Hatch: Pattern Gets Scrambled (RH-51516)
  • Annotation: Styles: Preview image is only seen for the current style in Options (RH-51791)
  • BlendSrf: Same Height in new Surface Blend is not applied if already ticked (RH-51181)
  • Camera: v6 large object millimeters template- camera rotation value is not zero. (RH-45545)
  • Core bugs: GetGlobalSelectionFilter returns value which does not correspond to filter settings (RH-51370)
  • Cycles: Transparency mapping repeat value not used in Raytraced (RH-51531)
  • Display:
    • Blocks display incorrectly in the Technical display mode (RH-36913)
    • Disable HW driver doesn’t seem to do anything (RH-51353)
    • Display on changing the view with a selection (RH-49052)
    • DrawArrow clipping in GetPoint (RH-51369)
    • Texture mapping is busted in the latest source… (RH-51580)
  • Export: Dimensions with tolerances are not exported to DWG correctly (RH-51754)
  • Extend: Menu item script has an extra Pause (RH-51425)
  • File IO:
    • More saving problems in Dropbox folders (RH-51479)
    • SketchUp export bails early if the scenes created do not have unique names. (RH-51570)
    • Text missing in this PDF import. (RH-51513)
    • Wrong Text Format when importing from PDF (RH-50444)
  • FilletEdge: Allows selecting of edges within a block but does not do anything with them (RH-52198)
  • Grasshopper: casting Grasshopper.Kernel.Special.GH_SuireSimplifyNode to IGH_DocumentObject fails when running script (RH-51188)
  • Help: MoveUVN on Curve? (RH-51244)
  • Installer: Should download all packages over HTTPS (RH-51352)
  • Lasso: Lasso in ChamferEdge (RH-51914)
  • Layer: Extra groups (RH-51426)
  • Mesh: Esc cancels selection (RH-52096)
  • NamedCPlane: Cursor stuck (RH-51679)
  • No Subsystem:
    • Bogus tree nodes appear (RH-51572)
    • Dragging Default Material replaces it and breaks the RDK (RH-51235)
    • Dragging a texture to the texture palette doesn’t work (RH-51616)
    • Match doesn’t play well with proxies (V4 materials) (RH-51105)
    • Need Rhino Viewport ability added to ViewCaptureSettings constructor. (RH-51229)
    • Texture name changes when dragged between sub-nodes (RH-51617)
    • Thumbnail OpenGL rendering broken (RH-52268)
    • Using unique_ptr with CRhRdkContent causes ASSERTs (RH-51338)
  • OSnap: Disable/ enable osnaps propagates between sessions (RH-51730)
  • Panels:
    • “Test Layer States” appears in the panel list (RH-51607)
    • Material list selection (RH-42912)
    • Too many bells (RH-40091)
  • Properties: Scriptable command fails for Materials etc (RH-48743)
  • RDK:
    • Assert fires in CRhRdkContent destructor: m_bInitialized and m_bUninitialized both false (RH-51525)
    • Debug ASSERT in CRhRdkContent destructor (RH-51271)
    • Live update does not work for blocks (RH-51772)
    • Remove name conflict dialog and auto-rename conflicting items (RH-50907)
    • Unable to change type of private materials and V4 materials (RH-51218)
  • Rendering: Dithering setting in Rendering panel doesn’t get applied in Render window (RH-51749)
  • Rendering: Materials: Deleting a material that is assigned to an object does not update the properties panel (RH-48439)
  • SDK: RhinoCommon:
    • File3dm.ReadRevisionHistory createdOn returning DateTime.MinValue (RH-51967)
    • Layer UserDictionary cleared when property is changed (RH-51299)
    • MeshVertexList.Hide and MeshVertexList.Show don’t work (RH-51975)
    • RhinoCommon - Unroll with properties (RH-31413)
  • SelBrush: Select mesh faces from visible side only (RH-35034)
  • Selection: Pops up more in V6 than in V5 (RH-52016)
  • Space Ball:SpaceMouse: 3DxRhino Default button assignments do not work and no icon is displayed. (RH-52012)
  • Sweep2: History update error (RH-51154)
  • UserText: “Undo” restores the deleted key but not value (RH-51409)
  • ViewCaptureToFile: Printing Layout views only produces partial results. (RH-51631)
Cosmetics:
  • File IO: PDF Select Page - UI glitch (RH-51471)
Crashes Fixed:
  • FBX: RhinoCore!CRhinoMeshWorkerThread::Worker – Access Denied (RH-50808)
  • No Subsystem: tl!__chkstk – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-52197)
  • Offset: tl!TL_EvBezier – (NTSTATUS) 0xc00000fd - A new guard page for the stack cannot be created. (RH-50447)
  • Project: tl!TL_NurbsCurve::MorphTo – Access Denied (RH-51541)
  • RDK: rdk!IndexedArray_Key – Access Denied (RH-51035)
  • Surface-surface intersection: tl!SSXnew::IntersectSurfaceEdge – Access Denied (MERGE) (RH-50801)
Enhancements:
  • CurveThroughPt: Ignore duplicate points (RH-51704)
Features Added:
  • SelBrush: New option - SelectThroughObjects=Yes/No (RH-51584)
Regressions Fixed:
  • Annotation: Styles: Font - Height and Text gap missing (RH-51713)
  • Display: Wrong texture mapping on meshes when VBO cache is enabled (RH-51500)
  • File IO: PDF file where V5 reads some curves that V6 does not. (RH-51348)
  • OSnap: Projects to CPlane, not closest point (RH-51357)
  • Rendering: CopyRenderWindowToClipboard doesn’t work (RH-51514)
  • Rendering: Materials: ModifyObjectAttributes doesn’t update material object properties page (RH-48942)
SDK Enhancement:
  • RDK:
    • CustomRenderMeshes do not update when not modifying object attribute user data (RH-51468)
    • Documentation for Custom Render Meshes (RH-50837)
    • RDK data no longer available in OpenNURBS (RH-49328)
  • Rendering: Materials: Rendered view doesn’t update properly on some changes in OctaneMaterial (RH-50623)
  • SDK: RhinoCommon:
    • New method to create custom mesh mapping (RH-46112)
    • Support wire thickness scaling in ViewCapture based on ViewCaptureSettings (RH-51407)
Tasks Completed:
  • Annotation: Hatch: Keep hatch display consistent in Layout regardless of scale (RH-51916)
Usability Problems Fixed:
  • File IO: PDF (vector) import - improvement desired (RH-33452)
  • Textures: Bitmap Texture color mask button is too narrow (RH-51853)
Rhino 6 SR15 Release Candidate 2 (6.15.19127) is now available.
Bugs Fixed:
  • Analytics: Always Ignore hidden groups members (RH-52176)
  • Eto: Named Item Copy and Paste limitations (RH-52251)
  • RDK: Can’t paste multiple materials as instances (RH-52287)
  • SDK: RhinoScript: Chr(10) adds a space after new line (RH-52261)
Crashes Fixed:
  • Cap: ntdll!RtlpReAllocateHeap – Access Denied (RH-51893)
  • RDKCrash: Pasting multiple materials can crash Rhino (RH-52310)
  • SDK: Crash when no active doc (RH-52317)
  • ViewCaptureToFile: Key ‘Dpi’ value type is not an integer. (RH-52214)
Enhancements:
  • Length: Changed to respect Groups (RH-52233)
  • Selection: Select material diffuse color in Rendered mode (RH-51743)
Regressions Fixed:
  • SDK: RhinoScript: TextObjectJustification wrong for values of 4 an 7 in Rhino 6 (RH-52286)
Rhino 6 SR15 Release Candidate 3 (6.15.19134) is now available.
Regression Fixed:
  • CPlane: _CPlane all=yes does not work properly (RH-51476)
Rhino 6 SR15 Release Candidate 4 (6.15.19148) is now available
Bugs Fixed:
  • CommandHelp: Still has access to online help when DisableInternetAccess=1 (RH-52789)
  • Licensing and Validation: Do not display “Login” when DisableInternetAccess=1 (RH-52788)
  • Textures: Texture files are still downloaded when DisableInternetAccess=1 (RH-52822)
Crashes Fixed:
  • Annotation: Styles: V6 Crash when editing dim style name with spaces. (RH-52213)
Regression:
  • Annotation: Text: Edit text on double-click (RH-51703)
Rhino 6 SR15 Release Candidate 5 (6.15.19162) is now available
Bugs Fixed:
  • Block: Arrowheads are scaling in blocks (RH-52343)
  • Localization: ExtractPt command - Output option toggle doesn’t work (RH-52942)
  • No Subsystem: RhinoPbrMaterial references RhinoCyclesCore (RH-52091)
  • OpenNURBS:
    • Compile on Linux fails due to incomplete makefile (RH-52371)
    • Public opennurbs - need a linux compile test (RH-51634)
  • SDK: RhinoCommon:
    • Add Rhino.Runtime.HostUtils.GetCurrentProcessInfo (RH-52280)
    • FilePdf ignores display mode point radius (RH-52835)
Crashes Fixed:
  • BlockEdit: System.ArgumentNullException: System.ThrowHelper.ThrowArgumentNullException (ExceptionArgument argument) (RH-50667)
Regression:
  • Print: Color variation between blocks and exploded blocks (RH-52539)
  • SDK: RhinoScript: AddAlignedDimension - style failes (RH-52218)
Tasks Completed:
  • OpenNURBS: Release 6.15 public opennurbs with linux support (RH-53147)
