When I make a new Layout and choose RhinoPDF, Landscape and A3 all is good, but when I then go to print I get a preview of a Portrait Letter in A4… and that’s obviously not what I want since I have allready chosen the above settings for the Layout, so Rhino basically asks me if I want to crop the Layout that I just made and print it to a size that none of the countries surrounding us are using, and that is a strange question to ask a designer
So please fix it so RhinoPDF reads the data from the Layout and uses that as default
Halla Jørgen,
I think that this one covers that issue, right?
https://mcneel.myjetbrains.com/youtrack/issue/RH-39513
Halla mr McNeel Norway
Vi må ta en kaffe snart!
The link you provided returned an error:
That is a different issue Wim. It has to do with printing different sheet sizes to a single PDF.
Kaffe står høyt på lista!
It should be visible now, try again.
Yes, but if that’s fixed, that would also mean that printing a single sheet to PDF would know the size it should print to, no?
Sure, but that is a feature request that I will not be working on for V6. Jorgen found a smaller bug that could be fixed in V6 since it would not require any changes to the UI
