brian
(Brian Gillespie)
March 24, 2020, 9:43pm
1
Rhino 6 SR25 Release Candidate 1 for Windows and Mac (6.25.20084) is now available.
To get it, subscribe to the Release Candidate update stream on Windows or on Mac .
Bugs Fixed:
Annotation: DimAngular: Annotation: DimAngular: Changing the DefPoint of an angular dimension extension doesn't work if the point is on the same line as the extension in question. (RH-57279 )
Annotation: Leader:
Annotation: Leader: Memory leak in CRhinoLeader::Pick (RH-57330 )
Annotation: Leader: Stays highlighted (RH-57364 )
Print:
Surface in Blocks Not Printing Correctly in Ghosted Detail (RH-54873 )
Single backface color causes blocks to print gray (RH-57119 )
SDK: RhinoCommon: SDK RhinoCommon: DisplayModeDescription.RenderedId returns Guid.Empty (RH-57443 )
ScreenCaptureToFile: Screen Capture: Transparent background makes object edges transparent (RH-57035 )
Crashes Fixed:
Annotation: Leader: Annotation Leader: opennurbs!ON_TextRun::WrapTextRun – Access Denied (RH-57286 )
SDK: RhinoCommon:
SDK RhinoCommon: Crash deleting RhinoCommon user data attached to a ViewportInfo object (RH-56767 )
SDK RhinoCommon: opennurbs!ON_NurbsCurve::GetClosestPoint – Access Denied (RH-57355 )
Enhancements:
Annotation: Annotations: Provides a warning when a used font is missing on the current system (RH-54667 )
Regressions Fixed:
ExtractPt: Fails on sub-objects (RH-57347 )
SDK Enhancement:
RDK: Expose CRhRdkDocument::ShowContentTypeBrowser() in C# sdk (RH-57349 )
Mac-Only Changes
Features Added:
Layer: Sorting is not fully supported (RH-36493 )
Windows-Only Changes
Bugs Fixed:
SDK: RhinoScript: SDK: RhinoScript: AddLeader returns NULL (RH-57415 )
brian
(Brian Gillespie)
April 1, 2020, 12:19am
3
Rhino 6.25 Release Candidate 2 (6.25.20091) for Windows and Mac is now available
Bugs Fixed:
Annotation: Text: Annotation Text: Italics permanent (RH-53387 )
Display: Vertex colors shouldn't override Arctic display mode (RH-57467 )
Regressions Fixed:
File IO: UseCompressionWhenSaving back-ported to advanced settings to V6 (RH-57344 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Save dialog pops up repeatedly when quitting with multiple Rhino and GH documents open (RH-57116 )
Bugs Fixed:
Annotation: Text: Annotation: Text: Properties font dropdown sometimes displays wrong font (RH-57335 )
TextField: Function selection difficulty (RH-57531 )
brian
(Brian Gillespie)
April 8, 2020, 2:41am
4
Rhino 6.25 Release Candidate 3 (6.25.20098) for Windows and Mac is now available:
Bugs Fixed:
Explode: Dimension text to dimension plane (RH-57519 )
Mac-Only Changes
Bugs Fixed:
Localization: Untranslated YesInYesNoField and NoInYesNoField strings in cs, pl, pt (RH-56982 )
brian
(Brian Gillespie)
April 14, 2020, 10:38pm
5
Rhino 6.25 Release Candidate 4 (6.25.20105) for Windows and Mac is now available:
Mac-Only Changes
Crashes Fixed:
Layer: com.mcneel.rhinoceros.RhCore:-[MRDocument _layersChanged] (RH-55122 )
brian
(Brian Gillespie)
April 21, 2020, 11:42pm
6
Rhino 6.25 Release Candidate 5 (6.25.20112) for Windows and Mac is now available:
Bugs Fixed:
File IO: SKP export: Quad faces are not exported properly (RH-57964 )
Bugs Fixed:
Installer: Install newest C-Runtimes (14.25.28508.3) with Rhino (RH-57943 )
Mac-Only Changes
Bugs Fixed:
SelLayer: Selects the wrong layer (RH-57913 )
