Rhino 7 Service Release Candidate Available
Rhino 7 SR11 Release Candidate 1 for Windows and Mac (7.11.21257) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
  • Annotation: DimAngular:
    • Flipped between angle and reflex angle when moving the whole dimension (RH-65501)
    • Moving resulted in a different angle (RH-65502)
  • Display: Skylight shadow shading issues when selecting objects (RH-65518)
  • EditText: Non-native Windows fonts could not be set italic for text in groups (RH-58645)
  • ExtrudeSubD: Faces in child segment of a single reflect symmetry could be selected (RH-65470)
  • File IO:
    • PDF Export - Preview stretched (RH-65517)
    • SketchUp Import - Group materials were assigned to objects that did not have materials (RH-65531)
  • Match: Match - scripted mode option missing (RH-65530)
  • Panels: Bugs in named item thumbnail mode (RH-64631)
  • Rendering: Materials: Duplicate material acted as if the texture is instanced (RH-65449)
  • SDK: RhinoCommon:
    • Bug in the copying of SubD objects (RH-64960)
    • Convert quaternion to Euler angles and vice versa (RH-65317)
Crashes Fixed:
  • PackageManager: Null reference exception (RH-65550)
Enhancements:
  • Display: Caches analysis meshes for EMap (RH-65252)
  • File IO: CSV Export - Saves text fields as evaluated values instead of formula strings (RH-65483)
  • Gumball: Remembers mouse dragged distance/angle/scale values for next click input (RH-65480)
  • Match:
    • Keeps SubDFriendly+ properties (RH-52487)
    • Preview missing in scripted mode (RH-65561)
  • SubD Symmetry:
    • Radiate command - Added “pie slice” feedback display for Reflect+Radiate symmetry (RH-65233)
    • Added “Flip” option to Reflect, Reflect+Reflect, and Reflect+Radiate symmetries (RH-65421)
    • Radiate now uses a cleanup tolerance (based on document’s absolute tolerance) when creating child motifs (RH-65081)
    • Radiate command - Flips “cheese wedge” display when cursor moving across object bounding box center (RH-65498)
    • Reflect command - Automatically adjust reflection plane direction, while picking, towards SubD’s bounding box center (RH-65499)
    • InsertPoint command is allowed to modify only primary motif (RH-64634)
  • TextField: Exports evaluated values instead of formula strings (RH-63311)
Features Added:
  • SDK: RhinoCommon: Added ability to crease/smooth SubD edges to Rhino 7 grasshopper (RH-63863)
Regressions Fixed:
UI Change:
  • Toolbar: Added SubDRevolve command (RH-63941)
Mac-Only Changes
Bugs Fixed:
  • File IO: PDF Export - Failed when exporting some, but not all, layouts (RH-64221)
  • RDK: Renaming viewport title did not update "Specific Viewport" list (RH-64853)
  • Rendering: Content Panels: Quick preview was initialized slowly (RH-65469)
  • Rendering: Realtime SDK:
    • Issues with Raytrace Mode and Two Docs (RH-61046)
    • Raytraced in multiple documents fails (RH-65043)
Crashes Fixed:
  • Grasshopper: Frequent crashes (RH-65514)
Incomplete Port:
  • Grasshopper: CMD+A did not select all text in Scribble component (RH-60286)
Windows-Only Changes
Bugs Fixed:
  • File IO:
    • STEP Export - Failed with some folder names in Japanese/Korean (RH-63414)
    • PDF Export - Preview did not update when switching from “Window” to “Multiple Layouts” (RH-65529)
  • Undo: Did not work with material changes made by RhinoScript (RH-65476)
Tasks Completed:
  • Help: Added simplified Chinese V7 for Windows offline help (RH-65194)
