Rhino 6 SR30 Release Candidate Available
Rhino 6 SR30 Release Candidate 1 for Windows and Mac (6.30.20238) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac .
Crashes Fixed:
  • PluginManager: Options Command: System.ArgumentOutOfRangeException: System.ThrowHelper.ThrowArgumentOutOfRangeException (ExceptionArgument argument, ExceptionResource resource) (RH-59849)
Mac-Only Changes
Incomplete Port:
  • Grasshopper: Remote Control Panel GUI issues (RH-57691)
Rhino 6 SR30 Release Candidate 2 for Windows and Mac (6.30.20246) is now available.
Mac-Only Changes
Bugs Fixed:
  • Work around issue with NSBitmapImageRep(NSData) constructor (RH-60086)
Crashes Fixed:
  • Grasshopper: Crashes on Mojave (RH-60043)
Windows-Only Changes
Bugs Fixed:
  • Build Process: Check for Updates opens an insecure (HTTP) URL (RH-60128)
Rhino 6 SR30 Release Candidate 3 for Windows and Mac (6.30.20258) is now available.
Bugs Fixed:
  • File IO: DWG Export: Blank leaders are skipped (RH-59976)
  • TextObject: Set DrawForward to false (RH-60214)
Crashes Fixed:
  • Annotation: System.NullReferenceException: Rhino.UI.Controls.AnnotationPanel.<>c.<.ctor>b__38_19 (Object s, DropDownFormatEventArgs e) (RH-59631)
Mac-Only Changes
Bugs Fixed:
  • Grasshopper:
    • Slow with large definitions (RH-59737)
    • Inactive area of Grasshopper is very slow (RH-60220)
Rhino 6 SR30 Release Candidate 4 for Windows and Mac (6.30.20266) is now available.
UI Change:
  • Toolbar: Add GrasshopperPluginList command (RH-58413)
Bugs Fixed:
  • Installer: Move RsApi.dll from System to Plugins (RH-60402)
  • RhinoStart: RhinoScript fails to load (RH-60365)
Rhino 6 SR30 Release Candidate 5 for Windows and Mac (6.30.20280) is now available.
Bugs Fixed:
  • Display: Moving background image breaks viewport display (RH-60411)
  • Rhino Installer Engine: Fixed Python plug-in/rhi file failure (RH-60764)
Mac-Only Changes
Bugs Fixed:
  • Print: Hatches have Very Fine Random Lines on PDF (RH-59353)
Bugs Fixed:
  • Installer: Warning during update of Rhino 6 - trouble setting links (RH-60841)
Rhino 6 SR30 Release Candidate 6 for Windows and Mac (6.30.20287) is now available.
Bugs Fixed:
  • File IO: File overwritten with a blank on startup (RH-60808)
Bugs Fixed:
  • Grasshopper: Grasshopper plugin loading check needs to be made optional. (RH-60870)
