brian
(Brian Gillespie)
1
Rhino 6 SR5 Release Candidate 1 (6.5.18128) is now available.
To get it, subscribe to the Release Candidate update stream.
New in SR5 RC1:
Crashes fixed:
- CPlane: RhinoCore!CCommandCPlane::SetNewCPlane – Access Denied (MERGE) (RH-45734)
- Core bugs: InsertKnot Command: RhinoCore!CRhGetInsertKnotCurvePoint::OnMouseMove – Access Denied (RH-45678)
- No Subsystem: :UseRhinoFont – (NTSTATUS) 0xc0000094 - {EXCEPTION} Integer division by zero.(MERGE) (RH-45714)
- Options: Advanced option list crash (RH-45689)
- Print: UNKNOWN!Rhino.SettingValue.TryGetPoint3d – Access Denied (RH-45736)
- Viewports: RhinoCore!CRhinoViewport::SetTraceImage – Access Denied (RH-45851)
Cosmetics:
- PackageManager: Show url in online tab of Package Manager (RH-45622)
Bugs fixed:
- Annotation:
- Fix ON_Font::GetInstalledFontFamily() so it works right. (RH-45838)
- Support Simulated fonts like Arial-Black Italic and CountryBlueprint Bold in Rhino 6 for Windows. (RH-45755)
- Annotation: DimLinear: Automatic signs in tolerance overdoing it (RH-44355)
- Annotation: DimRadial: Tail on Diameter and Radius Dimension Incorrect on Layout (RH-45794)
- Annotation: Hatch: HatchBase Lost When Blocked (RH-44542)
- Annotation: Text:
- ON_Font::ManagedFontFromRichTextProperties() fails to return correct face in some cases. (RH-45888)
- Rhino 6.5 tools for getting regular, bold, italic, and bold-italic font family members (RH-45864)
- CheckOutLicense: Checkout feature nonfunctional (RH-45788)
- Close: Leak warning (RH-45610)
- Display:
- DFKai font glyph rendering is bad (RH-41931)
- SubD - subobject highlight broken - needed for Shape to Fabrication (RH-45533)
- Transparent backface material causes selection to not highlight (RH-32885)
- Eto: Icons over scaled at DPI 200% (RH-45869)
- File IO:
- ACAD 2004 is still listed in ACAD export schemes (RH-45651)
- Bad STP import (RH-45697)
- Error message in ShrinkGetEdgeParameterSearchDomains() (RH-11330)
- Geometry Core: Fix potential crash in ON_SimpleArray::Append( int count, const T* p) (RH-45812)
- Grasshopper: Flip Mesh Face input Typo (RH-43971)
- Layer: Make the layer visible in the panel (RH-45621)
- LayerStateManager: Layer State Not Saving or Restoring Properly for Linked & Embedded Block Layers (RH-45549)
- No Subsystem: DWrite fails with X-Files font (RH-45768)
- OpenNURBS: ON_PolylineCurve::GetNormalizedArcLengthPoint issue (RH-45751)
- Options:
- Advanced options page request (RH-45779)
- Export Advanced setting list (RH-45694)
- Osnap:Point: Point osnap and points in blocks (RH-45715)
- PackageManager: Don’t use minor version in package folder path (RH-45117)
- Print:
- Exception thrown when writing PDF (RH-45490)
- Settings are not remembered between sessions (RH-29999)
- RDK:
- Decals Datasource changed event send only to the specific controller that made the change. (RH-45695)
- Incorrect dot color for material in layer panel with metal and glass materials (RH-43238)
- Rendering:
- Changing reflectivity bounces through script doesn’t work properly (RH-45613)
- Colors are wrong in renderings made with Rhino Render and Brazil (RH-45670)
- Rendering: Materials: Editing a layer panel material brings back a deleted light (RH-45723)
- SDK: MRhinoApp::RunScript signature incorrect (RH-45781)
- SDK: Python: GetObjectsEx group param is ignored (RH-45674)
- SDK: RhinoCommon:
- Add CreateMesh for Surfaces and Extrusions (RH-45555)
- Missing Enum Values in public enum SideFill in Rhino common (RH-45865)
- Rhino.UI.OpenFileDialog with MultiSelect=True not working (RH-37371)
- [RhinoCommon] SaveFileDialog does not handle Filter correctly (RH-28815)
- SelLinetype: Cannot select linetype (RH-45764)
- Selection:
- Keep selection between active details (RH-45744)
- Shaded brep selection point not always under the cursor (RH-45818)
- Solid tools: Make hole always goes both directions no matter the option (RH-45424)
- Space Ball:SpaceMouse: Rhino 6 laggy viewport performance (RH-45726)
- Surface-surface intersection: Fails, OK in V5 (RH-45095)
- UnrollSrf: Can’t compute area (RH-45506)
- ViewCaptureToClipboard:
- ViewCaptureToClipBoard Uses Layer Color - Not the Object’s Display Color (RH-45611)
- Z Buffer is broken… (RH-45889)
Enhancements:
- Cycles: Potential memory leakage in RhinoCycles (RH-37135)
- RDK: Render Frame UI contains lots of business logic (‘back-end’ code) (RH-45121)
- SDK: RhinoCommon: Text Object alignment options to be added to Rhino Common: Text3D object (RH-38784)
- SetUserText: Allow column sorting in User/Document text panels (RH-45092)
brian
(Brian Gillespie)
3
Rhino 6 SR5 Release Candidate 2 (6.5.18132) is now available.
Bugs fixed:
- Annotation: DimAngular: DimAngles are on the CPlane (RH-45722)
- Block: Instances In DWG Being Ignored with Link/Reference Option (RH-45434)
- BlockEdit: Paste in blockedit (RH-45620)
- File IO: SW import makes too many layers (RH-45432)
- SDK: RhinoCommon:
- Dialogs.ShowListBox does not consider the selected item (RH-44715)
- rs.AddText() makes text with invalid vertical alignment (RH-45771)
- SelectionFilter: Command-line filter “Edge” is unknown (RH-45657)
brian
(Brian Gillespie)
4
Rhino 6 SR5 Release Candidate 3 (6.5.18143) is now available.
Crashes fixed:
- Geometry Core: opennurbs!ON_Brep::PrevTrim – Access Denied (MERGE) (RH-46101)
- No Subsystem: MILERR_WIN32ERROR (Exception from HRESULT: 0x88980003)(MERGE) (RH-45882)
Enhancements:
- Grasshopper: MRU Tiles show full filename. (RH-42716)
Bugs fixed:
- Annotation:
- Dimensions made with plain user text from reading old files don’t display any text (RH-45938)
- Set Layout scaling off reading v4 files (RH-45937)
- Text from V4 files displayed in the wrong location (RH-45939)
- Undisplayed text not saved to V5 (RH-45987)
- AutoSave: No Autosave on re-open (RH-46138)
- BackgroundBitmap: Embedded Background bitmap not displaying when file reopened (RH-45959)
- BoxEdit: Issues in Rhino 6 (RH-46010)
- Cycles: Setting Samples count to 0 crashes Rhino when switching to Raytraced view. (RH-46086)
- Display: Ghosted display mode render problems with Picture (RH-46068)
- Eto: Eto" Method not found GetEtoWindow() (RH-45933)
- Fillet: On wrong segments (RH-46073)
- Grasshopper: Groups are missing in Custom Display Render pipeline. (RH-45900)
- Grasshopper: Components:
- Conic Graph mapper broken. (RH-45984)
- Integer Complex multiplication undefined. (RH-45776)
- Help: Object snaps with mesh wires? (RH-45997)
- Make2D:
- Does not project point objects (RH-44511)
- Incomplete clipping plane intersection (RH-44573)
- Print: Blocks are offset (RH-44585)
- RDK:
- CRhRdkAtpSnoop::Notify uses ActiveDoc (RH-45399)
- Custom Content Editor ‘actions’ no longer work (RH-45858)
- ShowNotifications: NotificationModal crashes when using the updater (RH-45789)
- SmartTrack: Mid & Smarttrack smart points (RH-45833)
- Undo: Error about Make2d - the Group option in the Make2d will delay the run time (RH-43205)
- ViewCaptureToFile: ViewCaptureToFile - “Unit” option not working in non-english Rhino (RH-45760)
