Rhino 6 Service Release 24 Release Candidate Available
Rhino 6 SR24 Release Candidate 1 for Windows and Mac (6.24.20055) is now available.
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
  • Annotation: Text is yellow but not selected after changing Horizontal alignment (RH-56886)
  • Export: Export fails with CM units (RH-56590)
  • File IO: Can't export (RH-55295)
  • Properties: Dead zones in Layer drop down menu (RH-56902)
  • SDK: RhinoCommon: Mesh.Faces.RemoveZeroAreaFaces() removes all faces (RH-56867)
  • Sun: Wrong timezone for Riga and Vilnius at Sun tab (RH-56802)
  • Toolbar: Double RMB-click shouldn't place a text file on the desktop (RH-56996)
Enhancements:
  • Match: Keep the point spacing on curve being changed (RH-56957)
Regressions Fixed:
  • TextObject: Font=<Name> in macro is not accepted (RH-56801)
SDK Enhancement:
  • SDK: RhinoCommon: Expose CRhinoGetPoint::SnapEvent() and CRhinoSnapEvent to RhinoCommon (RH-56769)
Mac-Only Changes
Bugs Fixed:
  • Annotation: Text: Font issues (RH-56600)
  • Grasshopper: File > Recent Files vertical text alignment problems (RH-55339)
  • Preferences: Unhide OpenGL tessellation shader checkbox (RH-57076)
Crashes Fixed:
  • Object reference not set to an instance of an object (RH-57060)
Features Added:
  • SDK: RhinoCommon:
    • Update embedded Mono to 6.6.0.155 (RH-57011)
    • Update embedded Xamarin.Mac to 6.10.0.17 (RH-57012)
Performance Improvements:
  • Grasshopper: Opening file takes a long time (RH-56920)
Tasks Completed:
  • Display: OpenGL 3.3: Tessellation Shaders in macOS Catalina 10.15.4 Beta (RH-56984)
Windows-Only Changes
Bugs Fixed:
  • Annotation: Text: Windows text control doesn't work right with Arial Narrow (RH-56777)
  • Eto: CheckBoxCell requires 3 clicks to set check state under WPF control (RH-56708)
Rhino 6 SR24 Release Candidate 2 for Windows and Mac (6.24.20064) is now available.
Bugs Fixed:
  • Display:
    • Object based conduits reset the object’s draw state by default thereby destroying the state any previous conduits may have set. (RH-57100)
    • Surfaces disappear in Shade command (RH-57140)
  • SDK: Python: SDK Python: Bug in rs.AddHatch() (RH-57120)
Mac-Only Changes
Bugs Fixed:
  • Display: Enable Tessellation Shaders on macOS 10.15.4 or later (RH-56985)
Enhancements:
  • Grasshopper: GrasshopperPluginList: Shows assembly for component in Help (RH-57015)
Crashes Fixed:
  • Delete: Delete Command: RhinoCore!CCommandDelete::RunCommand – Access Denied (RH-57086)
Rhino 6 SR24 Release Candidate 3 for Windows and Mac (6.24.20078) is now avilable.
Regressions Fixed:
  • Print: Shaded details left out (RH-57310)
