dan
(Dan)
August 24, 2021, 9:58pm
36
Rhino 7 SR10 Release Candidate 3 for Windows and Mac (7.10.21236) is now available
To get it, subscribe to the Release Candidate update stream on Windows or on Mac .
Enhancements:
Translation (localization) updates
brian
(Brian Gillespie)
September 1, 2021, 9:30pm
37
Rhino 7 SR10 Release Candidate 4 for Windows and Mac (7.10.21243) is now available
Bugs Fixed:
Trim: Object being cut remained selected (RH-65316 )
Enhancements:
Keyboard: Arrow keys are able to select through items in named panels (RH-64824 )
brian
(Brian Gillespie)
September 14, 2021, 10:47pm
38
Rhino 7 SR11 Release Candidate 1 for Windows and Mac (7.11.21257) is now available
Bugs Fixed:
Annotation: DimAngular:
Flipped between angle and reflex angle when moving the whole dimension (RH-65501 )
Moving resulted in a different angle (RH-65502 )
Display: Skylight shadow shading issues when selecting objects (RH-65518 )
EditText: Non-native Windows fonts could not be set italic for text in groups (RH-58645 )
ExtrudeSubD: Faces in child segment of a single reflect symmetry could be selected (RH-65470 )
File IO:
PDF Export - Preview stretched (RH-65517 )
SketchUp Import - Group materials were assigned to objects that did not have materials (RH-65531 )
Match: Match - scripted mode option missing (RH-65530 )
Panels: Bugs in named item thumbnail mode (RH-64631 )
Rendering: Materials: Duplicate material acted as if the texture is instanced (RH-65449 )
SDK: RhinoCommon:
Bug in the copying of SubD objects (RH-64960 )
Convert quaternion to Euler angles and vice versa (RH-65317 )
Crashes Fixed:
PackageManager: Null reference exception (RH-65550 )
Enhancements:
Display: Caches analysis meshes for EMap (RH-65252 )
File IO: CSV Export - Saves text fields as evaluated values instead of formula strings (RH-65483 )
Gumball: Remembers mouse dragged distance/angle/scale values for next click input (RH-65480 )
Match:
Keeps SubDFriendly+ properties (RH-52487 )
Preview missing in scripted mode (RH-65561 )
SubD Symmetry:
Radiate command - Added “pie slice” feedback display for Reflect+Radiate symmetry (RH-65233 )
Added “Flip” option to Reflect, Reflect+Reflect, and Reflect+Radiate symmetries (RH-65421 )
Radiate now uses a cleanup tolerance (based on document’s absolute tolerance) when creating child motifs (RH-65081 )
Radiate command - Flips “cheese wedge” display when cursor moving across object bounding box center (RH-65498 )
Reflect command - Automatically adjust reflection plane direction, while picking, towards SubD’s bounding box center (RH-65499 )
InsertPoint command is allowed to modify only primary motif (RH-64634 )
TextField: Exports evaluated values instead of formula strings (RH-63311 )
Features Added:
SDK: RhinoCommon: Added ability to crease/smooth SubD edges to Rhino 7 grasshopper (RH-63863 )
Regressions Fixed:
UI Change:
Toolbar: Added SubDRevolve command (RH-63941 )
Mac-Only Changes
Bugs Fixed:
File IO: PDF Export - Failed when exporting some, but not all, layouts (RH-64221 )
RDK: Renaming viewport title did not update "Specific Viewport" list (RH-64853 )
Rendering: Content Panels: Quick preview was initialized slowly (RH-65469 )
Rendering: Realtime SDK:
Issues with Raytrace Mode and Two Docs (RH-61046 )
Raytraced in multiple documents fails (RH-65043 )
Crashes Fixed:
Grasshopper: Frequent crashes (RH-65514 )
Incomplete Port:
Grasshopper: CMD+A did not select all text in Scribble component (RH-60286 )
Windows-Only Changes
Bugs Fixed:
File IO:
STEP Export - Failed with some folder names in Japanese/Korean (RH-63414 )
PDF Export - Preview did not update when switching from “Window” to “Multiple Layouts” (RH-65529 )
Undo: Did not work with material changes made by RhinoScript (RH-65476 )
Tasks Completed:
Help: Added simplified Chinese V7 for Windows offline help (RH-65194 )
brian
(Brian Gillespie)
September 21, 2021, 10:09pm
39
Rhino 7 SR11 Release Candidate 2 for Windows and Mac (7.11.21264) is now available
Bugs Fixed:
Rendering: Textures: Texture baker freezes Rhino (RH-65628 )
SmartTrack: Rotate does not place a smart point with no snap. (RH-65668 )
SDK Enhancement:
SDK: Added support for manipulating per-face materials without having to know the details (RH-64719 )
SDK: RhinoCommon: Added abilities to convert angles between quaternion and Euler angles (RH-65317 )
dan
(Dan)
September 28, 2021, 10:14pm
40
Rhino 7 SR11 Release Candidate 3 for Windows and Mac (7.11.21271) is now available
Bugs Fixed:
Gumball: remembered value is used too agressively (RH-65751 )
History: Showed false breaking warning when editing converted parent from Extrusion to polysurface (RH-65728 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Some icons on context menus were not scaled properly (RH-65658 )
Rendering: Realtime SDK: Raytraced mode failed with multiple documents (RH-65043 )
brian
(Brian Gillespie)
October 5, 2021, 10:58pm
41
Rhino 7 SR11 Release Candidate 4 for Windows and Mac (7.11.21278) is now available
Bugs Fixed:
Rendering: Textures: Loops of texture baking failures froze Rhino (RH-65697 )
brian
(Brian Gillespie)
October 13, 2021, 4:35pm
42
Rhino 7 SR12 Release Candidate 1 for Windows and Mac (7.12.21285) is now available
Bugs Fixed:
Annotation:
Editing a dimension changed the font (RH-62700 )
Some special European characters did not work with SLF-RHN Architect font (RH-64192 )
Block: Block attributes were not copy-pasted correctly (RH-62661 )
BoundingBox: Incorrect for blocks (RH-49510 )
BoxEdit: Size settings were broken (RH-65683 )
ClippingPlane: View clipping was removed by 4View and 3View commands (RH-65693 )
Display:
FlatShade did not work with SubD objects (RH-49558 )
“Treat as linear” checkbox in PBR materials did not work (RH-65874 )
ExtendCrvOnSrf: A curve could be extended beyond a trimmed edge (RH-65818 )
ExtractIsocurve: Failed at untrimmed edges (RH-4707 )
GrasshopperPlayer: Support input from a defined set (RH-57836 )
InsertPoint: Did not allow to insert points on edges on reflect plane (RH-65606 )
Line: Normal option found the wrong face in a polysurface (RH-65719 )
MultiPipe: Could not be canceled by ESC key or other commands (RH-59772 )
Offset: Trim=No was not as accurate as Trim=Yes (RH-65627 )
OpenNURBS: ON_PolylineCurve::IsValid returns true when curve has zero points (RH-65906 )
Pull: Result was incomplete (RH-65780 )
RDK:
Scripted materials were lost on re-loading (RH-65772 )
Most procedural noise types did not work (RH-65896 )
RecordAnimation:
Light size in reflection was different from Raytraced viewport (RH-64467 )
No lighting and shadows from Raytraced mode (RH-64465 )
Reflect: Missing XAxis or YAxis option for second reflect plane (RH-65709 )
Rendering: Cycles Viewport: Slow when rendering sun with shadows-only Ground Plane (RH-64526 )
Rendering: Realtime SDK: Raytraced mode did not render backface material luminosity (RH-65726 )
Rendering: Textures: Missing Images Dialog: Bulk Replace did not search subfolders (RH-65626 )
RevCloud: Failed when input curve was not parallel to world top plane (RH-65771 )
SDK: C# Rhino.Render.SafeFrame should be public (RH-65788 )
SDK: RhinoCommon: Add ConstrainNormal property to SporphSpaceMorph in RhinoCommon (RH-65933 )
Toolbar: Some of the layer icons were blurry (RH-65775 )
Enhancements:
Gumball: Allows to extrude multiple faces in the same polysurface (RH-65651 )
Lights: Shadow intensity changes area of a rectangular light and radius of a linear light in rendering (RH-64141 )
Rendering: Textures: DownloadLibraryTextures command allows to import textures from a zip file or a folder (RH-58106 )
Features Added:
Grasshopper: Automatic text shapes oriented to surface in Grasshopper 1.0 (RH-65799 )
SDK Enhancement:
GrasshopperPlayer: Now calls IGH_BakeAwareData::BakeGeometry (RH-60825 )
RDK: Added support for adding custom data UI sections to RenderContent (RH-64871 )
SDK: Added Circle-Circle and Arc-Arc intersection methods (RH-62819 )
Mac-Only Changes
Bugs Fixed:
RDK: Date & Time controls for Physical Sky Texture did not work on Mac (RH-65535 )
SDK: Python: A script failed on Mac (RH-65056 )
Tasks Completed:
Installer: RhinoScriptCompiler is removed on Mac (RH-65532 )
Enhancements:
GrasshopperPlayer: Added new contextual Boolean parameter (RH-57897 )
brian
(Brian Gillespie)
October 19, 2021, 10:00pm
43
Rhino 7 SR12 Release Candidate 2 for Windows and Mac (7.12.21292) is now available
Bugs Fixed:
Annotation: Text: Editing text showed debug messages in command history (RH-65959 )
Display:
Background of Pen display mode was brighter in inactive detail views (RH-63140 )
rotating uv mapping (at least box) can cause stretching (RH-65817 )
ExtractPt: Created duplicate points at polycurve segment ends (RH-65980 )
File IO: A simple polysurface was exported to 3DS with too many faces (RH-65936 )
OSnap: Percentage snap: numbers displaced (RH-65995 )
SubD Symmetry: Duplicating SubD damaged symmetry (RH-65584 )
Enhancements:
Gumball: Plane controls work with distance, angle, direction, and ortho constraints (RH-65298 )
brian
(Brian Gillespie)
October 26, 2021, 10:49pm
44
Rhino 7 SR12 Release Candidate 3 for Windows and Mac (7.12.21299) is now available
Bugs Fixed:
Rendering: Materials: Drag and drop import stopped working for PBR materials (RH-65998 )
Regressions Fixed:
brian
(Brian Gillespie)
November 10, 2021, 12:05am
45
Rhino 7 SR13 Release Candidate 1 for Windows and Mac (7.13.21313) is now available
Bugs Fixed:
Annotation: Hatch:
Hatch - Reset between sessions (RH-66093 )
Fill style might be out of sync between the dialog and viewport (RH-66062 )
BlendSrf:
History connection did not work correctly on duplicated objects (RH-66102 )
“Same height” did not work when it was initially enabled (RH-65992 )
BlockManager:
Block Missing Dialog Shows Up in Macro/Script (RH-66180 )
“_-BlockManager _Update _All” shows Block name conflict dialog box (RH-59783 )
Color Picker: Slow on loading color wheel (RH-66022 )
CreateUVCrv: UV rectangle missing (RH-66138 )
Display:
Cage visibility was toggled by surface edge visibility (RH-65996 )
Adding vertex colors to a mesh broke look of PBR materials (RH-65971 )
Grasshopper:
Added Enable/Disable and Preview to contextual parameters (RH-65925 )
“Import 3DM” component did not read hidden objects (RH-65776 )
Gumball: Failed to extrude a planar closed curve inward or outward (RH-66037 )
Layout: Remove View[[1897]] localized string from LayoutsPanelViewModel (RH-65383 )
Match: Continuity inconsistent when matching arcs (RH-65729 )
NamedCPlane: : interferes with Undo (RH-66131 )
Paste: Command: _PasteSvg doesn't work (RH-65824 )
Print: "Only Selected Objects" setting sticking between sessions caused confusion (RH-66125 )
Rendering: Materials: Material assignment: drag and drop to group (RH-66124 )
RibbonOffset: RibbonOffset- fails (RH-66104 )
SDK: Mesh.CreateContourCurves tolerances (RH-65835 )
SDK: RhinoCommon:
IGES exporter doesn’t follow unit settings from headless doc (RH-66189 )
Expose ON_Brep::DestroyRegionTopology to RhinoCommon (RH-66199 )
Quaternion.GetRotation() method not found in Rhino3dm 7.7.0 nuget (RH-65724 )
Rhino.Geometry.Squisher.SquishMesh made meshes with desynchronised single / double precision vertices (RH-66087 )
SelBrushPoints: SelBrushPoints on point clouds (RH-66159 )
SubD Editing: Deleting edge at corner of SubD incorrectly removed vertex (RH-65864 )
Sweep1: History connection did not work correctly on duplicated objects (RH-65891 )
TextField:
Did not update properly in Document User Text panel (RH-65904 )
Document changes did not update Document User Text (RH-65905 )
TextObject: Result incorrect when rotation and spacing settings were both changed (RH-66024 )
ViewCaptureToFile: Transparent background made clipping plane section edges transparent (RH-66119 )
Crashes Fixed:
File IO: Rhino crashed when reading WRL files with colorpervertex setting not conforming to file specs (RH-65955 )
Enhancements:
Mapping widget command: Added ShowOCSFrame option to MappingWidget command (RH-66049 )
QuadRemesh: Updated to a new versions (RH-65907 )
Rendering: Render: add 4k to size pre-sets (RH-66116 )
Tutorials: Model zip file lists on top and next to PDF (RH-64819 )
Features Added:
Grasshopper: New "Get File Path" component (RH-61663 )
GrasshopperPlayer: Allows baking output of Group components (RH-60307 )
Regressions Fixed:
Cap: Did not process other edges when any self-intersected edge was detected (RH-66126 )
Print: Margins did not print (RH-65718 )
SDK: RhinoBrepSplit returned nullptr in resulting array (RH-64910 )
UI Change:
Annotation: Hatch: Removed StartPoint and EndPoint command-line options during editing gradient (RH-66064 )
Mac-Only Changes
Bugs Fixed:
RDK: Missing path incomplete in dialog (RH-66242 )
Crashes Fixed:
Export: PDF: Crash with custom paper size (RH-66110 )
Bugs Fixed:
Color Picker:
Flickering slider froze Rhino (RH-65736 )
Resizing dialog when the third value was highlighted froze the screen (RH-65735 )
GrasshopperPlayer: Referenced input was not cleared between runs (RH-65369 )
Enhancements:
Grasshopper: "Import 3DM" component explodes point clouds in .e57 files and returns a list of points (RH-65966 )
brian
(Brian Gillespie)
November 24, 2021, 6:00am
46
Rhino 7 SR13 Release Candidate 2 for Windows and Mac (7.13.21327) is now available
Bugs Fixed:
RecordAnimation: jpegs are png (RH-66358 )
SetDocumentUserText: Document User Text panel not updating (RH-66375 )
brian
(Brian Gillespie)
November 30, 2021, 11:19pm
47
Rhino 7 SR13 Release Candidate 3 for Windows and Mac (7.13.21334) is now available
Regressions Fixed:
RDK: Placeholder material gets duplicated (RH-66489 )
brian
(Brian Gillespie)
December 7, 2021, 10:52pm
48
Rhino 7 SR13 Release Candidate 4 for Windows and Mac (7.13.21341) is now available
Enhancements:
Annotation: Hatch: Right-click to only check a pattern in the list, and allows check/uncheck all selected patterns at once (RH-66538 )
Bugs Fixed:
Rendering: Cycles: Crashed when using OpenCL as the render device (RH-66535 )
brian
(Brian Gillespie)
December 15, 2021, 12:30am
49
Rhino 7 SR14 Release Candidate 1 for Windows and Mac (7.14.21348) is now available
Bugs Fixed:
Annotation: DimLinear: Dimension update glitch (RH-66493 )
ClippingPlane: Section update was not responsive in all viewports (RH-28983 )
Display: Subobject material render preview mapping bug (RH-66436 )
File IO:
SketchUp import prompted command-line options in batch mode (RH-66490 )
Import FBX shows UI on a headless import (RH-66552 )
STEP Export - Made writing wchar_t step files optional (RH-66270 )
Scripting mesh format export did not skip meshing options when only meshes were selected (RH-66271 )
Line: Normal option created a line different from the typed length (RH-66295 )
MeshBox: MeshBox and SubDBox swapped XCount and YCount when picking or entering a negative height (RH-65611 )
PackageManager: Did not look into subdirectories of a custom package repository (RH-66386 )
ProjectToCPlane: Failed with vertical segments (RH-66441 )
Properties:
Per face display color returned wrong face index (RH-66546 )
Settings of Render mesh modifiers might not be editable when they were turned off (RH-66366 )
RDK: Texture adjustment texture did not show all settings (RH-66539 )
Rendering: Texture Mapping: Multiple channels on meshes did not work in Rendered mode (RH-66235 )
Rendering: Textures: Texture baking caused noticeable freezes every 20 seconds (RH-65812 )
SDK: RhinoCommon: Problem with sweep2 in grasshopper (RH-66617 )
Section: Tolerance was not small enough for sectioning meshes (RH-66589 )
Split: SubD could not be the cutting object (RH-65540 )
SubDAppearance: SubDDisplayToggle command did not work with SubD objects in blocks (RH-65545 )
Undo: Broken for numerical inputs when using GH Player (RH-66322 )
Crashes Fixed:
File IO: Crash when publishing a few hundred pages into single PDF file (RH-66324 )
Enhancements:
SDK: Curve.Rebuild periodic to minimum pointcount (RH-66336 )
SDK: RhinoCommon: Add a method to join SubD objects to RhinoCommon (RH-66642 )
Regressions Fixed:
File IO: Print to vector PDF overrode display settings (RH-66272 )
Rendering: Post Effect: The render window did not ask to save post effects to document (RH-66261 )
SDK Enhancement:
OpenNURBS: Wish of ON_3fPoint::SquaredDistanceTo (RH-38899 )
SDK: Added MeshUnwrapper to C++ SDK and RhinoCommon (RH-62349 )
Usability Problems Fixed:
Mapping widget command: Object snap did not snap to OCS frame origin correctly (RH-66054 )
Mac-Only Changes
Bugs Fixed:
Grasshopper:
TextBox grabbed focus on macOS Monterey (RH-66293 )
mac monterey/ GH display issue (RH-66338 )
Layout: Initial settings were not sticky between sessions (RH-52519 )
Rendering: Textures: Missing image files dialog got cut off (RH-66267 )
SDK: Rhino.Input.Custom.OptionColor bug on Mac (RH-66240 )
Grasshopper: Parameter input keyboard shortcuts required enter or space to complete (RH-57216 )
brian
(Brian Gillespie)
December 29, 2021, 10:25pm
50
Rhino 7 SR14 Release Candidate 2 for Windows and Mac (7.14.21362) is now available
Bugs Fixed:
SDK: RhinoCommon:
CreateFromSweepSegmented problem when specifying an endpoint (RH-66765 )
Problem with Sweep2 in Grasshopper (RH-66617 )
UI Change:
Gumball: Move/extrude/scale/rotate by mouse dragging no longer sets gumball click default value (RH-65698 )
brian
(Brian Gillespie)
January 5, 2022, 12:32am
51
Rhino 7 SR14 Release Candidate 3 for Windows and Mac (7.14.22004) is now available
Crashes Fixed:
SDK: RhinoCommon: Crash Grasshopper in sweep2 (RH-66839 )
brian
(Brian Gillespie)
January 11, 2022, 10:34pm
52
Rhino 7 SR15 Release Candidate 1 for Windows and Mac (7.15.22011) is now available
Bugs Fixed:
Material assignment lost when material plug-in is loaded (RH-66913 )
Display: Incorrect shadow in Rendered mode (RH-66793 )
Export: Rhino PDF slow (RH-66827 )
GrasshopperPlayer: Hops did not give the same result (RH-66387 )
Gumball: Scale handle + Ctrl(CMD) did not work on SubD faces (RH-66469 )
MeshIntersect: Winding of Mesh|Mesh interactions (RH-65833 )
OffsetSrf: Solid=Yes with DeleteInput=No did not create object on current layer (RH-66779 )
Rendering: Post Effect: NVIDIA denoiser execution error when adding Glow post-effect (RH-66537 )
SDK: RhinoCommon: ON_Geometry_GetTightBoundingBox should call ON_Brep::GetTightBoundingBox (RH-66874 )
Selection: Ctrl(CMD)+Double-Click highlighted unselected edges in commands requesting edge input (RH-66781 )
SquishBack: Did not recognize Squished meshes made by Quadremesh (RH-66211 )
UndoView: Did not undo the first view change in a new detail view (RH-66701 )
Enhancements:
SDK: RhinoCommon: Expose display pipeline method to draw instance definitions (RH-66855 )
Regressions Fixed:
Rendering: Checkered background (RH-66767 )
Rendering: Textures: Missing textures in Rendered mode after reopening model (RH-65740 )
SDK Enhancement:
SDK: RhinoCommon: Updated RhinoCommon and Grasshopper templates to work with Visual Studio 2022 (RH-66581 )
Tasks Completed:
Tutorials: Updated adjustable lamp video tutorial (RH-61845 )
Mac-Only Changes
Bugs Fixed:
SDK: RhinoCommon:
AddPageView on mac always wrong size and orientation (RH-65134 )
Creating a page view gets it wrong (RH-53159 )
Crashes Fixed:
Display: Rhino crashed on Macs after updating to macOS Catalina 10.15.7 (RH-66183 )
Regressions Fixed:
Rendering: Materials: Rhino hanged when panel was set to tree view (RH-66653 )
Bugs Fixed:
FilletEdge: Ctrl+Double-Click highlighted unselected edges in FilletEdge-like commands (RH-66696 )
brian
(Brian Gillespie)
January 18, 2022, 11:09pm
53
Rhino 7 SR15 Release Candidate 2 for Windows and Mac (7.15.22012) is now available
Bugs Fixed:
Localization: RecordAnimation underscored options problems (RH-66771 )
brian
(Brian Gillespie)
February 9, 2022, 4:23am
54
Rhino 7 SR16 Release Candidate 1 for Windows and Mac (7.16.22039) is now available
Bugs Fixed:
Contour: Created open curves from closed sections of meshes (RH-66997 )
Drag: Allow gumball dragging even if object or control point dragging is disabled (RH-67320 )
File IO:
Step Import failed to detect a planar NURBS if it was trivially trimmed (RH-67122 )
Exports slightly non-planar surfaces to STEP as planes (RH-67211 )
IGES export ignored the Units setting (RH-67142 )
FBX headless import unexpectedly showed a dialog box (RH-66552 )
FBX import did not read all textures (RH-66914 )
Scripting PDF import interrupted by the “Embedded PDF fonts cannot be loaded” message appearing in a dialog box (RH-67067 )
Length: Inconsistent on SubD Edges (RH-67078 )
OSnap:Mid: OSnap Mid: Snapping on polysurface edge was incorrect (RH-67276 )
RDK:
DotNet garbage collection crashed on exit (RH-66942 )
CRhRdkMaterial::FromOnMaterial() did not set the material name for PBR materials (RH-67293 )
Eto UI wrote incorrect strings to documents (RH-67213 )
Rendering: "Use lights on layers that are off" option did not work (RH-66917 )
Rendering: Cycles: Flipped wallpaper upside down (RH-67327 )
Rendering: Decals: Selecting Properties > Decal crashed Rhino (RH-67140 )
Hard to select mapping item in Properties panel (RH-66245 )
Custom UV had artifacts on SubD, but not on mesh (RH-66487 )
SDK: CRhinoObjectIterator did not respect all 'object_state' flags (RH-67230 )
SDK: RhinoCommon:
LinetypeTable.FindName comments for return value are not clear (RH-67092 )
Could not deserialize leaders (RH-61100 )
Crashes Fixed:
File IO: Rhino silently crashed when reading a SLDASM file (RH-67118 )
Enhancements:
File IO: STEP export now converts non-rectangular planar surfaces to planes (RH-67060 )
Regressions Fixed:
Annotation: Zooming in detail broke radius and diameter dimensions on arcs (RH-67054 )
MeshSplit: Mesh.Split() failure with user case (RH-63422 )
SDK Enhancement:
SDK: RhinoCommon:
Added an additional override to InstanceDefinitionTable.Modify for specifying/modifying Url and UrlTag fields (RH-67038 )
Exposed more properties of an Ellipse (RH-67116 )
Mac-Only Changes
Bugs Fixed:
Code Editor Control: GHPython script component crashed when using type() in script (RH-65457 )
Eto: GroupBox on Mac could cause crashes (RH-67214 )
Grasshopper: Save dialog popped up repeatedly when quitting with multiple Rhino and GH documents open (RH-57116 )
Hyperlink: CMD-Click did not open URL in object on Mac (RH-67344 )
Crashes Fixed:
4View: Unnecessarily replacing views and pipelines multiple times caused a crash on Mac (RH-66953 )
File IO: Crashed when meshing 3dm files from older versions on opening (RH-65537 )
Regressions Fixed:
No subsystem: Mac Technical Display Mode Silhouettes not showing. (RH-66777 )
Bugs Fixed:
ExtractMeshEdges: New geometry was not added to worksession active model (RH-67282 )
ExtractMeshFaces: New geometry was not added to worksession active model (RH-67281 )
ExtractMeshFacesByArea: New geometry was not added to worksession active model (RH-67283 )
ExtractMeshPart: New geometry was not added to worksession active model (RH-67284 )
RDK: Sun year might not be able to set smaller than 1980 (RH-67089 )
Worksession: Copy and detaching issues (RH-67095 )
Enhancements:
Layer: Allows "Copy Objects to Layer" on context menu working with worksession attached objects (RH-56390 )
brian
(Brian Gillespie)
February 16, 2022, 4:56pm
55
Rhino 7 SR16 Release Candidate 2 for Windows and Mac (7.16.22046) is now available
Bugs Fixed:
Annotation: DimRadial: Radius and Diameter Dimension Text Were Incorrect (RH-67328 )
Display: Point clouds imported from PLY files were invisible (RH-66750 )
SDK: Python: IronPython is not reported for platform.python_implementation (RH-67339 )
Regressions Fixed:
DevLoft: Issue when two rails met at one end (RH-67434 )
Mac-Only Changes
Enhancements:
Rendering: Materials: SBSAR image data is now stored in 3dm as PNG instead of TIFF (RH-67449 )
Bugs Fixed:
EditPythonScript: EditPythonScript and GHPython did not load (RH-67409 )
Crashes Fixed:
SDK: RhinoCommon: Rhino.Inside Grasshopper Sweep2 crash (RH-67456 )
