Rhino 6 SR22 Release Candidate 1 for Windows and Mac (6.22.19351) is now available.
To get it, subscribe to the Release Candidate update stream on Windows or on Mac.
Bugs Fixed:
- Dragging a texture between child slots removes the instancing (RH-55961)
- Animation: Animation name does not stick in scripted version (RH-56081)
- Annotation: Text: Does not remember height (RH-55854)
- Cycles: Groundplane mapping with texture set to WCS or WCS Box incorrect (RH-55981)
- Display: Editing text is clipped (RH-55937)
- Eto: Initial location of Eto dialog is incorrect when parented (RH-55856)
- OpenNURBS: Update Mac Futura font name information for Mac Rhino (RH-56085)
- SDK: RhinoCommon: Mesh.CreateFromClosedPolyline bug (RH-56218)
- Snapshot: Snapshots - Unavailable clients displayed in the edit dialog (RH-56053)
Enhancements:
- SystemInfo: Added the scriptable version (RH-55906)
Regressions Fixed:
- History: Model dimensions on Layouts lose history when copied to other layout (RH-56193)
Mac-Only Changes
Bugs Fixed:
- ClippingPlane: Surface edges and isocurves not seen through clipping plane (RH-55600)
- Dark Mode: Figure out why white and black button pixels both get converted to white in dark mode. (RH-56287)
- EditPythonScript: Different Go buttons (RH-55478)
- File IO:
- Quicklook: 3dm files shared via smb volumes open in read-only mode (RH-53222)
- Rendering: Materials:
- Rendering: Realtime SDK: Raytraced Mode HUD and its icons too small (RH-53497)
Cosmetics:
- Icons: add major version number to application icon (RH-55763)
Crashes Fixed:
- Display: System.ArgumentNullException: Value cannot be null. (RH-55809)
Windows-Only Changes
Bugs Fixed:
- Annotation: Text: Input field alignment (RH-54728)
Regressions Fixed:
- Annotation: Dot: Flashing Properties Panel (RH-56254)
