VisualARQ 3.1 is now available for
download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Improvements (2)
- Template:
#12720: Create a Layer for Guides in VisualARQ templates5417: Generate new level name from the selected level
Changes (5)
- Menu:
#14324: Add a link to the Online help in the VisualARQ menu
- Style:
#11254: Change message when importing a not compatible .VAL file
- Template:
#14551: Remove the “Hidden” linetype assigned to the layer “Guides”#14361: Changes in VisualARQ templates#10879: Set the default layer for element object in VisualARQ templates
Fixed Errors (43)
- Attributes:
#14466: Section styles on a wall are reset after reopening a file#10494: Keep section attributes when exploding VisualARQ objects
- Block:
#14107: VisualARQ objects inside a block disappear when the block is edited with BlockEdit command
- Crash:
#14477: Crash opening this file#14475: Crash opening this file from VisualARQ 2#14474: Crash after editing a plan view#14435: Crash when listing Elements created as Grasshopper styles#14340: Rhino doesn’t respond when opening this file
- Display:
#14414: VisualARQ sections and levels don’t respect the “shadows ignore user defined clipping planes” setting
- Grasshopper: Components:
#14485: Missing Grasshopper components dialog shows up when starting VisualARQ
- IFC:
#14501: Hollow tube in IFC 4 file opens as a closed solid#14470: Missing geometry in IFC 4 file#14387: IFC import error when using the Import command#14215: Crash after opening an IFC file
- Language:
#14419: Translate VisualARQ templates
- Level:
#14529: Objects disappear in top viewport when activating a cut plane#14454: Cut plane doesn’t work
- Object:
#14459: Slab normal layers don’t show the intersection line with a beam#14458: Slab and wall layers don’t hide intersection line
- Object: Annotation:
#14417: Annotation doesn’t take the linetype width#14416: Strange line appears when moving an annotation
- Object: Door:
#14395: Doors don’t show the 2D representation in this file
- Object: Element:
#14489: Sink Wall mount Element style has a wrong width in VisualARQ Millimeters template
- Object: Plan View:
#14471: Space labels and tags are generated as 2D curves in plan views#14457: Wall joints are visible in 2D plan views#10379: Leader text alignment is changed when creating plan views
- Object: Railing:
#9569: The handrail of this railing solves the intersection in a point different than the vertices
- Object: Section:
#14507: Jogged section doesn’t work in this file
- Object: Slab:
#14461: Slab loses its section attributes when I delete a beam that was intersecting with it#14339: Slab layer thicknesses change when saving a Rhino 8 file as Rhino 7 file
- Object: Space:
#10133: Spaces from curves don’t take the Level height
- Object: Table:
#14450: Crash while editing a table
- Object: Tag:
#14569: Tag alignment can’t be changed
- Object: Views:
#14149: Guides are not generated in 2D plan views
- Object: Wall:
#14491: Deleting a clipping plane leaves a crack on a wall#11771: Wall issues when they have layers with thickness set to 0
- Object: Window:
#14087: Window doesn’t show the overhead representation#12919: Window geometry is not displayed
- Parameter:
#14453: Parameters icon is not available
- Print:
#14473: Print width of Annotation objects are not correct when printing to vector output using Wireframe display#14472: 2D blocks are not printed to vector output when using Hidden display mode#14363: Walls of the same style are printed with different line weights
- View:
#14469: Section Solid hatch Z-fighting issue in Perspective views
Previous versions:
Enjoy!
Enric
