VisualARQ 3.3 - Release Candidate 2 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.3 is scheduled for official release on
Wednesday, April 2th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
Improvements (2)
- API: Script:
14823: Add function to the API to obtain the slab contour
- Grasshopper: Style:
14769: Keep component names after exploding an object created from a Grasshopper Style
Fixed Errors (25)
- Crash:
12052: Creating a section view freezes Rhino
- DWG Export:
14819: Dimensions are not exported to DWG14800: Section is not preserved in DWG Export14799: Objects in hidden layers are exported to DWG14789: Missing dimension arrowhead hatch in DWG export14788: Dimensions inside a block are not exported to DWG14761: Model in Detail is moved after exporting to DWG14750: Curves are partially hidden by other objects in the DWG export14749: Some texts are not exported to DWG14748: Text and arrow of stairs are not exported to DWG14747: The overhead projection of beams are not exported to DWG14746: Some arrowheads and dots appear in the wrong position in an exported DWG file14745: Some strange rectangular hatches appear in the exported DWG file14728: The overhead representation of a stair is not exported to DWG14727: Level view is changed after exporting layout to DWG14626: Texts are not exported to DWG
- Grasshopper: Components:
14822: Objects are baked twice with the Context Cache component14821: VisualARQ objects are not updated with the Context Cache component14798: Crash when pushing VisualARQ geometry with the Context Cache component13563: VisualARQ objects are not working with the Content Cache component
- IFC:
14783: No geometry appears in this IFC 4 file
- Object: Slab:
14795: Wall Normal Layers don’t intersect with Slab Normal Layers
- Performance:
14479: Inserting a slab in this model is very slow14465: Moving a wall is very slow
- View:
13298: Visual glitch when the model is displayed in section
Download links:
Previous versions:
Enjoy!
Enric
