VisualARQ 3.4 is now available for
download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
New Features (2)
- Grasshopper: Components:
#14878: Make Model Object working with VisualARQ objects#14861: Make Query Model Object working with VisualARQ objects
Improvements (4)
- Attributes:
#14896: Section Print Width is missing in View overrides for section and plan view styles
- Block:
#14867: Disable “BlockEdit” command for VisualARQ objects
#14962: Support conversion from “Block Instance” to VisualARQ object
- Level:
#14882: Hide irrelevant icons in the Level Manager in a page layout
Changes (1)
#10593: Add Alignment offset to the Beam Options and Deconstruct Options components
Fixed Errors (43)
- Attributes:
#14931: New materials don’t appear in the style properties drop down#14812: “No Print” option is not available for section boundary Print Width
- Crash:
#14902: Crash after inserting an IFC file as a “Linked” block
- Display:
#14976: Support for model On Layer visibility in VisualARQ objects created from blocks
- DWG Export:
#14893: Section hatch scale is not preserved in a DWG Export.#14827: Layout exports section drawings with the level cut plane on#14792: Texts are exported upside down#14205: Text inside a block is not exported to DWG
#14797: Output parameters can’t be retrieved from new objects in Grasshopper#14181: Get value doesn’t work with blocks obtained from the Query Model Objects
- IFC:
#15073: Nothing appears in this IFC file#15070: Crash when importing this IFC4 file#14928: IFC 4 file doesn’t open#14912: Missing geometry in IFC file with V4 Engine#14908: V4 Engine doesn’t read materials on the geometry#14047: Rhino gets stuck at opening an IFC file#12990: IFC file cannot be imported to VisualARQ#12649: It takes too long to import these files#12527: Beams are imported wrong in this file#12229: IFC file doesn’t open#12069: VisualARQ can’t open this IFC file#11005: VisualARQ imports IFC file with extremely thick slabs#10756: Rhino gets stuck at opening an IFC file#10231: It takes a long time to open this IFC file#10088: Cannot open this IFC file
- Interferences:
#14913: Negative value format not accepted in Imperial units document
- Layout:
#14880: Construction plane inside Detail view changes across layouts
- Level:
#14809: Double click on a level doesn’t hide an upper level#14240: Disable the “isolate” option when not all buildings have a boundary
- Object: Furniture:
#14579: Some Furniture and Element objects are not generated properly
- Object: Opening Elevation:
#14840: Wrong Opening Elevation of a window
- Object: Section:
#14849: Isolate objects is slow when the Section Manager is visible
- Object: Section View:
#14872: Text in section view is generated with a different style than the original one#14871: Text size change in Section views across worksessions#14870: Texts are rotated in elevation views
- Object: Space:
#10134: Space values are not updated when scaled
- Object: Table:
#13748: 2D table is not visible after inserting it in the model
- Object: Views:
#15010: View overrides fail in Rhino 7#14901: Plan view, dwg and section view edges don’t cut non-sectionable objects
- Object: Wall:
#15021: Invisible walls#14997: Wall disappears in the model space#14841: Wrong representation of walls when activating a section
- View: Plan and RCP:
#14890: Reflected ceiling plan fails to show geometry when the cut plane is on
Previous versions:
Enjoy!
Enric
