VisualARQ 3 - Version 3.3 RC1 released
VisualARQ 3.3 - Release Candidate 1 is now available for download.
:information_source:  NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.3 is scheduled for official release on :spiral_calendar: Wednesday, April 2th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
New Features (1)
  • DWG Export:
    • 12745: Export text as text when exporting to DWG
Changes (1)
  • Language: Russian:
    • 14114: Remove Russian from VisualARQ
Fixed Errors (12)
  • Crash:
    • 14674: Crash after opening a file
  • DWG Export:
    • 14677: Guides are exported in a wrong position to DWG
    • 14663: Space labels are not exported to DWG
    • 14662: Tag texts are not exported to DWG
    • 14661: Section reference text is not exported to DWG
    • 14659: Wall section hatches are out of position in a DWG export
    • 14281: Geometry rotated in the export to DWG
  • Grasshopper: Components:
    • 13563: VisualARQ objects are not working with the “Content Cache” component
  • Menu:
    • 14587: Wrong link to Sales page in VisualARQ menu
  • Object: Space:
    • 14700: Space label moves when changing the text alignment
  • Object: Wall:
    • 14641: Wall cannot be created from that curve
  • View: Plan and RCP:
    • 14698: Wrong representation of RCP
Download links:
Previous versions:
Enjoy!
Enric
Hello dear VA developers!
I have tried the 3.3 RC1 for Rhino 8, because I have had big trouble with dwg exporting.
I see no differences with the previous version whatsoever! Texts are not being exported, dimensions and tags are a mess, but more than anything, instead of a clean selected layout, I get other (not selected) drawings in the background!
Also, when hitting the export to dwg command, I do not get a dialogue box with options for the dwg format.
Is it my fault or is this command still not working properly?
Hi @Ioannis_Poularakis we are revising some issues related to the DWG Export command, and have already fixed most of them for the next RC of VisualARQ 3.3. However, it would be helpful if you share your file so we can verify these issues you report are fixed.
In any case, when you export to DWG, the DWG Export Option dialog should always appear. It can take some time to show up if the model is complex though.
Thank you for the answer, Francesco!
Unfortunately, I cannot share the model file because of client confidentiality.
I’m looking forward to the next RC! Proper export to dwg is really important!
Hi Ioannis,
If there is the chance to share that file (you can be confident we will use it internally and delete it afterwards), or just a reduced or modified version of it, we will ensure all these issues are fixed. You can send it to visualarq@asuni.com. Some errors are file-specific at times, and without them, we cannot anticipate them.
Hi @Ioannis_Poularakis please try these errors with the 3.3 RC2 version we have recently published. Let me know if any of them persists.
