VisualARQ 3.3 is now available for
download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
New Features (1)
- DWG Export:
#12745: Export text as text when exporting to DWG
Improvements (3)
- API: Script:
14823: Add function to the API to obtain the slab contour
- Grasshopper: Style:
14769: Keep component names after exploding an object created from a Grasshopper Style
- Object: Views:
6287: Draw texts as texts and not as curves in 2D Plan and 2D Section views
Changes (4)
- Language: Russian:
14114: Remove Russian from VisualARQ
- Level:
14720: Do not switch off the sub-levels of other levels when doing double click on a level
- Object: Table:
14883: Changes in the way Table Report updates content
- Template:
12153: Unify Curtain Wall and wall styles height in all templates
Fixed Errors (56)
- Attributes:
14897: Section attributes assigned “By Parent” to VisualARQ objects inside blocks don’t work
- Crash:
14922: Rhino freezes when moving a wall14844: Crash after importing Furniture styles14834: Crash when working with tables14674: Crash after opening a file12052: Creating a section view freezes Rhino
- DWG Export:
14926: vaExportToDWG exports nothing when Detail Print Width is set to “No Print”14819: Dimensions are not exported to DWG14800: Section is not preserved in DWG Export14799: Objects in hidden layers are exported to DWG14789: Missing dimension arrowhead hatch in DWG export14788: Dimensions inside a block are not exported to DWG14761: Model in Detail is moved after exporting to DWG14750: Curves are partially hidden by other objects in the DWG export14749: Some texts are not exported to DWG14748: Text and arrow of stairs are not exported to DWG14747: The overhead projection of beams are not exported to DWG14746: Some arrowheads and dots appear in the wrong position in an exported DWG file14745: Some strange rectangular hatches appear in the exported DWG file14728: The overhead representation of a stair is not exported to DWG14727: Level view is changed after exporting layout to DWG14677: Guides are exported in a wrong position to DWG14663: Space labels are not exported to DWG14662: Tag texts are not exported to DWG14661: Section reference text is not exported to DWG14659: Wall section hatches are out of position in a DWG export14626: Texts are not exported to DWG14281: Geometry rotated in the export to DWG
- Dynamic Section:
14904: Section caps of VisualARQ objects inside a block are drawn displaced
- Grasshopper: Components:
14822: Objects are baked twice with the Context Cache component14821: VisualARQ objects are not updated with the Context Cache component14798: Crash when pushing VisualARQ geometry with the Context Cache component14736: Get Level returns a list of non-existing sub-levels13563: VisualARQ objects are not working with the Content Cache component13246: Bake Component is not working with VisualARQ objects
- IFC:
14843: I can’t open this IFC file14805: I cannot open this IFC file14783: No geometry appears in this IFC 4 file13558: IFC file gets stuck at 60% when opening
- Interferences:
14839: Intersection errors between a wall and a slab
- Menu:
14587: Wrong link to Sales page in VisualARQ menu
- Object: Plan View:
14859: Duplicated section hatch patterns in 2D plan views
- Object: Section View:
14864: Texts do not appear in 2D Section views
- Object: Slab:
14795: Wall “Normal” layers don’t intersect with slab “Normal” layers
- Object: Space:
14700: Space label moves when changing the text alignment14348: Space shows 0.00m2 until it updates
- Object: Table:
14917: Play and Update icons out of position14449: Table shows duplicated data in the list
- Object: Views:
13316: Rhino freezes when trying to update a section or plan view
- Object: Wall:
14845: Walls cannot be created from a rectangle14641: Wall cannot be created from that curve
- Performance:
14479: Inserting a slab in this model is very slow14465: Moving a wall is very slow
- Print:
14704: Print issues of a RCP: walls section hatches are missing
- View:
13298: Visual glitch when the model is displayed in section
- View: Plan and RCP:
14698: Wrong representation of RCP
Previous versions:
Enjoy!
Enric
