VisualARQ 3.2 - Release Candidate 2 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.2 is scheduled for official release on
Wednesday, February 5th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
New Features (3)
- Object: Beam:
#7314: Australian structural profile library (BHP)
- Template:
#6928: Add UK standard profiles library#5213: Add Australian structural profiles library
Improvements (4)
- Grasshopper: Components:
#11307: Change the value used to define that roof edge cut is a “by style” value
- Grasshopper: Style:
#11557: Support for Mesh parameters as Grasshopper style inputs
- Interface:
#14549: Add scroll bar in the VisualARQ Layers in Document Properties
- Object: Curtain Wall:
#14391: Assign a default profile to new mullion/frame component
Changes (1)
- Menu:
#14324: Add a link to the Online help in the VisualARQ menu
Fixed Errors (12)
- Block:
#14590: VisualARQ objects added to a block using “BlockEdit” are converted to blocks
- Language: Chinese:
#14427: Japanese text appears in VisualARQ in Chinese
- Layout:
#14341: Geometry in hidden layer per detail is exported to DWG
- Level:
#14618: Wrong cut plane elevation section#14099: Missing section caps when hiding levels from different buildings#13710: Objects cannot be selected after hiding levels
- Object:
#14617: I cannot select many objects in this model
- Object:`: Opening Elevation:
#14504: Opening elevations failure from windows created from curves
- Object: Space:
#9699: Space hatch is drawn on top of other objects
- Performance:
#11028: Slow performance inserting and dragging an object created with a Gh style
- Print: Hidden Vector:
#13875: Linetypes are not properly printed to vector output
- View:
#14619: 2D door arcs and space labels are not displayed in plan view
Download links:
Previous versions:
Enjoy!
Enric
