VisualARQ 3.4 - Release Candidate 1 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.4 is scheduled for official release on
Wednesday, June 4th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
Improvements (3)
- Attributes:
14896: Section Print Width is missing in View overrides for section and plan view styles
- Block:
14867: Disable BlockEdit command for VisualARQ objects
- Level:
14882: Hide irrelevant icons in the Level Manager in a page layout
Changes (1)
- Grasshopper: Components:
10593: Add “Alignment offset” to the Beam Options and Deconstruct Beam Options components
Fixed Errors (34)
- Attributes:
14812: “No Print” option is not available for section boundary Print Width
- Crash:
14902: Crash after inserting an IFC file as a “Linked” block
- DWG Export:
14907: Section hatch in a closed extrusion is not exported to DWG14827: Layout exports section drawings with the level cut plane on14792: Texts are exported upside down14205: Text inside a block is not exported to DWG
14797: Output parameters can’t be retrieved from new objects in Grasshopper
- IFC:
14928: IFC 4 file doesn’t open14912: Missing geometry in IFC file with V4 Engine14908: V4 Engine doesn’t read materials on the geometry14047: Rhino gets stuck at opening an IFC file12990: IFC file cannot be imported to VisualARQ12649: It takes too long to import these files12527: Beams are imported wrong in this file12229: IFC file doesn’t open12069: VisualARQ can’t open this IFC file11005: VisualARQ imports IFC file with extremely thick slabs10756: Rhino gets stuck at opening an IFC file10231: It takes a long time to open this IFC file10088: Cannot open this IFC file
- Interferences:
14913: Negative value format not accepted in Imperial units document
- Layout:
14880: Construction plane inside Detail view changes across layouts
- Level:
14809: Double click on a level doesn’t hide an upper level14240: Disable the “isolate” option when not all buildings have a boundary
- Object: Opening Elevation:
14840: Wrong Opening Elevation of a window
- Object: Section:
14849: Isolate objects is slow when the Section Manager is visible
- Object: Section View:
14872: Text in section view is generated with a different style than the original one14871: Text size change in Section views across worksessions14870: Texts are rotated in elevation views
- Object: Space:
10134: Space values are not updated when scaled
- Object: Table:
13748: 2D table is not visible after inserting it in the model
- Object: Views:
14901: Plan view, dwg and section view edges don’t cut non-sectionable objects
- Object: Wall:
14841: Wrong representation of walls when activating a section
- View: Plan and RCP:
14890: Reflected ceiling plan fails to show geometry when the cut plane is on
Download links:
Previous versions:
Enjoy!
Enric
