VisualARQ 3.2 is now available for
download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
New Features (3)
- Object: Beam:
#7314: Australian structural profile library (BHP)
- Template:
#6928: Add UK standard profiles library#5213: Add Australian structural profiles library
Improvements (4)
- Grasshopper: Components:
11307: Change the value used to define that roof edge cut is a “by style” value
- Grasshopper: Style:
11557: Support for Mesh parameters as Grasshopper style inputs
- Interface:
14549: Add scroll bar in the VisualARQ Layers in Document Properties
- Object: Curtain Wall:
14391: Assign a default profile to new mullion/frame component
Changes (1)
- Menu:
14324: Add a link to the Online help in the VisualARQ menu
Fixed Errors (40)
- Block:
14590: VisualARQ objects added to a block using “BlockEdit” are converted to blocks
- DWG Export:
14676: Model is not exported to DWG in section14635: Guides are not exported to DWG14283: Export solid hatches to DWG
14262: Grasshopper door style is very slow when inserted or edited14155: Moving a VisualARQ Grasshopper style makes it disappear
- IFC:
14719: Rhino crashes when opening an IFC file with the Parametric Objects option
- Language: Chinese:
14427: Japanese text appears in VisualARQ in Chinese
- Layout:
14522: Hidden details are exported to DWG Acons14341: Geometry in hidden layer per detail is exported to DWG
- Level:
14673: Rhino freezes after closing the Add Levels… dialog14099: Missing section caps when hiding levels from different buildings13710: Objects cannot be selected after hiding levels
- Object:
14651: vaSelAll command doesn’t work14617: I cannot select many objects in this model
14570: Curtain wall Cell Alignment doesn’t work14547: Wrong curtain wall result with the left o right alignment9342: Extended curtain walls with fixed number of divisions keep the original division proportions
- Object: Guide:
14481: Guides are not drawn on top of objects in 2D plan views
- Object: Opening Elevation:
14504: Opening elevations failure from windows created from curves
- Object: Openings:
14699: Strange value when editing a leaf size
- Object: Plan View:
14401: Stair arrow edge appears incorrectly in plan views12652: Stair numbers remain visible for hidden steps
- Object: Railing:
14506: Railing error in 3D12941: Railing rail Margin only applies to one side12913: Crash when creating a railing from a straight polyline with intermediate points11873: Railing from curve misses a part
- Object: Roof:
14505: It is not possible to change all slopes at once in Gable roofs
- Object: Section:
14439: Difficulty to define section viewer position
- Object: Space:
9699: Space hatch is drawn on top of other objects
- Object: Stair:
12989: Stair numbers and arrow wrongly displayed
- Object: Table:
14555: A table object is listed in a table14534: Empty cells cannot be edited in table reports
- Performance:
14639: Navigating in the styles dialog is very slow14630: Moving a wall is slow due to boolean issues11028: Slow performance inserting and dragging an object created with a Gh style
- Print: Hidden Vector:
13875: Linetypes are not properly printed to vector output
- View:
14514: Display issue after undoing a change in the level manager
- View: Plan and RCP:
14705: Sphere is not displayed in a RCP14697: Ceiling plan views don’t work for sub-levels
Previous versions:
Enjoy!
Enric
