VisualARQ 3.5 - Release Candidate 2 is now available for download.
NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.5 is scheduled for official release on
Wednesday, August 6th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
Improvements (1)
- Grasshopper: Style:
15016: Block instances are exploded inside VisualARQ Grasshopper styles
Changes (2)
- License:
15081: Reduce the extension of evaluation period for updates to 7 days
- Panel: Tables:
15060: Remove “Test” from “Pause test” and “Resume test” buttons on “Tables” panel
Fixed Errors (10)
- Attributes:
15078: Print color doesn’t work on VisualARQ objects in Shaded display
- Crash:
14865: Crash after importing a file
- Grasshopper: Components:
15089: User texts are not detected on referenced VisualARQ objects in Grasshopper
- Object: Column:
15072: vaColumnExtend command doesn’t work when UseExtrusions is set to Polysurfaces
- Object: Element:
15075: Blocks inside VisualARQ elements doesn’t work with vaSubtractSolids command
- Object: Roof:
15024: Roof slopes are not listed completely
- Object: Table:
14884: A corrupt table appears in the list after inserting a 2D table
- Performance:
15004: Moving objects makes Rhino freeze
- Print:
14583: Wrong print color in raster output13658: Wrong print color when printing to raster
Download links:
Previous versions:
Enjoy!
Enric
