VisualARQ 3.1 - Release Candidate 1 is now available for download.
NOTE: This is a release candidate (RC), which means it is not the final version, but it has been tested internally and we consider it stable enough to be tested by end users. VisualARQ 3.1 is scheduled for release on Wednesday, December 4th, 2024.
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestions here or email us at visualarq@asuni.com.
Here is the list of changes:
Improvements (1)
- Template:
#5417: Generate new level name from the selected level
Changes (1)
- Style:
#11254: Change message when importing a not compatible .VAL file
Fixed Errors (28)
- Attributes:
14466: Section styles on a wall are reset after reopening a file
- Crash:
14477: Crash opening this file14475: Crash opening this file from VisualARQ 214474: Crash after editing a plan view Actions14340: Rhino doesn’t respond when opening this file
- Display:
14414: VisualARQ sections and levels don’t respect the “shadows ignore user defined lipping planes” setting
- Grasshopper: Components:
14485: Missing Grasshopper components dialog shows up when starting VisualARQ
- IFC:
14470: Missing geometry in IFC 4 file
- Level:
14454: Cut plane doesn’t work
- Object:
14459: Slab normal layers don’t show the intersection line with a beam14458: Slab and wall layers don’t hide intersection line
- Object: Annotation:
14417: Annotation doesn’t take the line-type width14416: Strange line appears when moving an annotation
- Object: Door:
14395: Doors don’t show the 2D representation in this file
- Object: Element:
14489: Sink Wall mount Element style has a wrong width in VisualARQ Millimeters template
- Object: Plan View:
14457: Wall joints are visible in 2D plan views10379: Leader text alignment is changed when creating plan views
- Object: Slab:
14461: Slab loses its section attributes when I delete a beam that was intersecting with it14339: Slab layer thicknesses change when saving a Rhino 8 file as Rhino 7 file
- Object: Space:
10133: Spaces from curves don’t take the Level height
- Object: Views:
14149: Guides are not generated in 2D plan views
- Object: Wall:
14491: Deleting a clipping plane leaves a crack on a wall11771: Wall issues when they have layers with thickness = 0
- Parameter:
14453: Parameters icon is not available
- Print:
14473: Line-weighs of Annotation objects are not correct when printing to vector output using Wire-frame display Actions14472: 2D blocks are not printed to vector output when using Hidden display mode ctions14363: Walls of the same style are printed with different line weights Actions
- View:
14469: Section Solid hatch Z-fighting issue in Perspective views
Download links:
Enjoy!
Enric
