Bug with VA3 curtain wall
I’ve noticed a bug with the Curtain Wall from Curves feature in VA3. It seems that despite choosing Align Right along a curve, the curtain wall is not aligning correctly to the curve both horizontally and vertically. See file attached.
Thanks
Curtain Wall problem2.3dm (9.9 MB)
Hi @avatarlucas Thanks for reporting this error. I’ve forwarded to the development team.
Is it just me @fsalla or is there a problem with Hipped roofs? I can’t seem to change any angles on them? Perhaps I am doing it incorrect but no matter the hipped roof I build, it’s the same angle and I can’t edit it either. I’m not sure if this is a VA3 thing or I’m doing it incorrectly
Hi @avatarlucas can you provide more details of this problem? what happens when you change the slope from the roof properties?
Seems to be working in an empty file, perhaps I have a corrupt one. I will transfer it over. Thanks
@avatarlucas As mentioned in the other post, this error is fixed in the VA 3.2 RC1 version: VisualARQ 3 - Version 3.2 RC1 released
But I could see the new error appearing. I’ll keep you posted when we fix it.
