VisualARQ 3 - Version 3.4.3 released
VisualARQ 3.4.3 is now available for :arrow_down: download.
This is a minor release that solves most of the critical issues and crashes reported by users. Please report any problem or suggestion here or send us an email to visualarq@asuni.com.
Here is the list of changes:
Fixed Errors (16)
  • Object: Slab:
    • #15162: Slab layers disappear
    • #15139: Slab is not generated properly
    • #15000: Wrong slab geometry
  • Object: Wall:
    • #15155: Wall is not generated
    • #15154: Wrong intersection between a wall and a slab
    • #15141: Wall layers disappear when doors cut them completely
    • #15129: Wall layer disappears when inserting a door
    • #15126: Boolean Intersection Column/wall Fail
    • #15106: Wall segments disappear
    • #15101: A wall segment next to an opening is not generated
    • #15100: Some wall layers are not generated
    • #15088: Some wall layers disappear when I start adding openings
    • #15050: Wall intersection generates a wrong result in 3D
    • #15030: Invisible wall segment
    • #14937: Wrong result of an extended wall with 0 thickness layers
    • #14644: Wall layer is not visible
Previous versions:
Enjoy!
Enric
