VisualARQ 3 - Version 3.6 RC1 released
VisualARQ 3.6 - Release Candidate 1 is now available for download.
:information_source:  NOTE: This is a release candidate (RC), meaning it is not the final version but has undergone internal testing and is considered stable enough for end-user testing. VisualARQ 3.6 is scheduled for official release on :spiral_calendar: Wednesday, October 1th, 2025
This release fixes most of the problems and crashes reported by users. Please report any problems or suggestionas here or email us at visualarq@asuni.com.
Here is the list of changes:
New Features (1)
  • Attributes:
    • 10877: Support Rhino 8 transparency
Improvements (1)
  • Level:
    • 13732: “Set Floor/Ceiling Plan” option doesn’t keep CPlane orientation
Changes (1)
  • Attributes:
    • 15160: Rename “Transparency” to “Opacity” in color properties
Fixed Errors (27)
  • API: Script:
    • 13107: GetSpaceCurve method is not returning any curve
  • Attributes:
    • 15083: Section style changes by Layer on VisualARQ objects don’t update automatically
    • 14141: Show background color (section styles) in Hidden display
  • DWG Export:
    • 15132: 2D geometry in DWG Export is not flattened
    • 15131: Errors in DWG Export of a section view
    • 15116: View with a Reflected Ceiling plan is not property exported to DWG
    • 15066: Hatch appears in a DWG export of a RCP plan
    • 15065: RCP appears in a wrong position after a DWG Export
    • 15054: Detail changes from Perspective to Parallel in a DWG export
  • Interferences:
    • 15124: vaExtractSolids does not extract solids properly
    • 14938: Core Slab Layer doesn’t cut wall normal layers
  • Level:
    • 14001: Elements located in other levels are displayed when activating the plan reference view
  • Object: Guide:
    • 14933: Guides can’t be stretched
  • Object: Plan View:
    • 15128: 2D Plan view doesn’t generate the Elevation mark 2D symbol
    • 15103: Wrong display color in some elements in a “Plan View” object
  • Object: Slab:
    • 15085: Error copying a slab from one file to another
  • Object: Space:
    • 15095: Space label has changed the alignment from one version to another
  • Panel: Tables:
    • 15025: Read only parameters can’t get the totals in the Table report
  • Print:
    • 15188: Hidden parts of an object in RCP are printed
    • 15159: Printing errors of a RCP
    • 15094: Printing multiple layouts is very slow
    • 14898: Wrong RCP print result
    • 14862: Wrong print result of a RCP view
    • 14850: Window openings are not printed well in a live RCP
    • 14703: Print issues of a RCP: Curve is not printed
    • 14357: Reflected plan views are not printed properly
  • View: Plan and RCP:
    • 15157: Wrong plan view after I Align Floor Plan in a Detail
Download links:
Previous versions:
Enjoy!
Enric
