Hi everyone,
VisualARQ 3.8 is now available for
download.
This is a maintenance release that fixes most of the critical issues and crashes reported by users. Please report any problems or suggestions here or send us an email to visualarq@asuni.com.
List of changes since 3.7.2:
Fixed Errors (2)
- DWG Export:
15143: Preserve dimension entities when exporting to DWG
- Performance:
14397: Improve the performance of wall-slabs intersections
Fixed Errors (52)
- API: Script:
14911: Error in the function AddRoofFromCurve. Roof Type parameter is missing
- Clashes:
15305: Duplicated intersection issues14441: Clashes report doesn’t work with blocks
- Crash:
15346: Rhino freezes after changing the height of two walls
- DWG Export:
15430: Imperial dimensions change format in the DWG Export15429: Missing geometry in the exported DWG15415: Detail View rotates after being exported to DWG15368: Rhino crashes when exporting multiple layouts to DWG15028: Text dimensions in the model space are exported in wrong size to DWG14658: Text size inside blocks is not preserved in DWG export13924: Dimensions are exploded in AutoCAD when I export in dwg format
- Grasshopper: Components:
15469: Crash after referencing a building in Grasshopper15309: Fail to explode a VisualARQ Object Style Component
- Grasshopper: Player:
15047: VisualARQ Objects don’t bake with the Grasshopper Player
- Help:
15337: Wrong syntax description in VisualARQ Help to display custom parameters in tag styles
- IFC:
9615: Wrong import of geometry in IFC
- Interferences:
15398: Update VisualARQ object automatically when an object used as interference is deleted15384: Rhino freezes when deleting a wall15165: Wall-Slab intersection not solved correctly14831: Roof-Wall intersection issue
- Object: Beam:
15527: Volume of beams is not properly calculated
- Object: Curtain Wall:
15340: Curtain wall is not extended properly15294: Curtain Wall’s center curve is not taking the Alignment Offset into account15239: Door doesn’t cut properly a curtain wall14964: Door doesn’t cut properly a curtain wall14575: Door in a curtain wall doesn’t generate well the opening14503: Curtain wall error when it is coincident with a window and a wall14498: Door doesn’t cut properly a curtain wall12602: Door doesn’t cut properly the curtain wall where it is inserted
- Object: Guide:
15508: Objects link to guides doesn’t work15405: Gumball in Guide Point is not Aligned with Guide even in Gumball Object Mode15227: “Perp” snap doesn’t work with guides15226: Wall doesn’t follow the guide
- Object: Plan View:
15445: Wall is not generated properly in a plan view15439: Guides in hidden layers are showing in Plan Views15121: Geometry disappears from plan view after update
- Object: Roof:
15495: Windows don’t detect the roof15494: Window in roof changes elevation when editing the roof15452: Roof doesn’t show up when you insert it15443: Roof changes elevation after update15363: After opening old files some roofs got projected to zero elevation15333: Gable roof breaks when another one intersects with it
- Object: Slab:
15344: Slab selection selects other walls15318: Rhino freezes after copying a group of slabs from one document to another
- Object: Wall:
15463: Wall layer wrap bug around a door15449: Visible wall miter join in section12676: vaFillet is not side sensitive to these walls12674: vaFillet changes the wall alignment
- Object: Window:
15380: Window doesn’t detect a roof
- Performance:
15237: Rhino freezes when updating some walls14944: Moving a window is slow in this file11876: It takes a long time to delete a column
Previous version:
Enjoy!
Enric
